Are you running the same size spare?
Discussion in 'Wheels & Tires' started by AllenOne1, Oct 26, 2019.
  1. Oct 28, 2019 at 11:56 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    When I moved from 265/70-16's to 285/75-16's I bought five wheels and tires. I rotate the spare into the fold at every rotation.
    :anonymous:
  2. Oct 28, 2019 at 12:05 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Yes, same size spare. When I went from stock 16” to BBS 17” wheels, I purchased a spare 17” steelie wheel from CL and mounted 5 new 17” tires.
  3. Oct 28, 2019 at 12:58 PM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    I dunno. Just got them mounted a month or so ago and the tire shop put it in there. They voiced no complaints, however.
    pro2aaf[QUOTED] likes this.
  4. Oct 28, 2019 at 1:04 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Does size really matter for temporary use?
    What does matter is proper lug nuts. had to save a set for my spare since wheel different on spare.
    3JOH22A likes this.
  5. Oct 28, 2019 at 1:27 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Definitely. Especially if you have a long way to go to get home or to an accessible road and/or poor terrain to get there across.
    If it’s your DD and you never leave 10 miles of your house, there’s nothing wrong with that, and an inch smaller spare will work.. but if you’re doing few thousand mile road trips with a lot of back highways and off road trails to get to remote camping spots, etc. there’s no way I’d roll with a smaller diameter spare.
    asuchemist[QUOTED] likes this.
  6. Oct 28, 2019 at 7:41 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    About 33", but that's OK. If you're doing trails that require anything bigger, you'd likely destroy the spare at the factory location coming off ledges, etc.
  7. Dec 1, 2019 at 11:34 AM
    SemperFiDevil
    SemperFiDevil Member
    M
    19 Taco TRD Pro Voodoo Blue
    Where did you pick up the spare tire wheel?
  8. Dec 1, 2019 at 11:35 AM
    oneleglance
    oneleglance Active Member
    Lance
    '17 TRD Inferno
    I am running Cooper ST Maxx 255/85/16 and always buy 5 so I can rotate them all and then my spare is just a normal tire in the mix.
  9. Dec 1, 2019 at 11:58 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If the 4 tires on the ground were 2-3" taller than the spare I'd upgrade the spare. But in this case he's talking about 1/2" The 4 tires on the ground will be more than 1/2" smaller than the spare even if you started with 5 identical tires and the 4 on the ground had 25,000-30,000 miles on them and the spare were still new.
    I've had 5 identical tires and done a 5 way rotation in the past, but in this case you're worrying about nothing. I keep an air compressor in the truck along with plugs and tools. In the last 20 years I've patched at least 20 flats, mostly for others. I've only had to put the spare on one time. Even those times where the tire was ruined plugging it and airing up got me back to a tire store. That is a lot easier, safer, and faster than having to change tires. But I wouldn't go out without a spare. There is always the possibility it is going to be too damaged to plug.
  10. Dec 1, 2019 at 12:12 PM
    Joe.Dirt
    Joe.Dirt Well-Known Member
    Colorado
    '19 Cavalry Blue TRD Off Road DCLB
    255/85/16 in the spare
    Tainted likes this.
  11. Jul 18, 2021 at 12:13 AM
    NightHawkTaco420
    NightHawkTaco420 Well-Known Member
    DFW, TX
    2017 SR5 Access Cab
    - Ceramic tinted windows all around - Morimoto XB headlights - Spyder tail lights - TRD grill - TRD OR charcoal/machined wheels - interior chrome delete - interior LED bulb switch - weathertech mats (F/R) - MESO Customs Ultimate 3rd Brake Light (BD3 Model) - Tuff Skinz Door Sill Protectors Planning a 3/1 lift/level project and a few other future mods
    reviving this thread. just paid for 5 tires. all same size, 265/75/r16. falken wild peak at3w
    I didnt consider the spare size vs the size of spare wheel. Suggestions on how to go about this? Someone mentioned to me they bought a used tire and kept that as a spare bc it didn't make sense to them to put a brand new tire under the truck. Last spare I bought was brand new and I stuck in under truck for 4ish years until about a month ago and its mostly discolored but still works for temporary use. I do somewhat agree with this gentleman's thought but I wanted to pick other brains on the matter. I kinda prefer to go same size spare tire in case I resort to using it at some point a few years down the road. Current spare may be a half inch smaller but feels funny at times.
    Also, will a 265/75/r16 falken wild peak even fit on the stock spare wheel of a 2017 sr5? I do not remember the original stock tire size as I upgraded to a 265/70/r16 (TRD OR takeoffs). Not sure if any of this info will help determine an answer
