Are You SH!TT!NG ME!!!!????!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LBtaco, May 23, 2009.
  1. May 23, 2009 at 2:02 PM
    LBtaco
    LBtaco [OP] Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    so I thought about changing my front wheel bearings to fix the 'shimmy' at speeds above 60 , and called up my local toyota. $1300 fuggin dollars is what they quoted me!!!! OMFG!!! seriously?!!! this is a 2WD too!!!
    said they 'recommend' changing the hubs is why it costs so much.
    the bearings are like $100 each
    If I have to I suppose I could just buy the parts and do it myself.
    getting them old ones out will probly suck it tho..
    Mrtoytaco you saved a TON of cash doing the front yourself.!!
  2. May 23, 2009 at 2:21 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah thats why their called the stealership. You would think by buying a Toyota and keeping their company running they would cut you some slack but no, its the total opposite!!!:eek:
  3. May 23, 2009 at 3:56 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Bearings are an easy change, at least in my experience, just don't overtorque them. Come back a week later and re-torque.
    Have no experience with our setups though, thought it was an entire hub assembly.
  4. May 23, 2009 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Pretty easy to do your self.
  5. May 23, 2009 at 5:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its more money due to the ABS parts in the hub/bearing assembly, but a simple swap.
  6. May 23, 2009 at 9:25 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    anyone do a write up on this? or in the process of a write up lol
    so hubs are like $130 x 2 + $100 bearing x 2 = $460+-
    any other parts I need?
    I probly wont replace the hub...but Toyota 'recommends' it, just have to inspect it when its off I suppose
    then again, I could just ignore it cuz it's not really that bad (yet)
    I have 82k miles, how long are these supposed to last?
    stock size tires and stock rims have been on it for the life of the truck, so I assume all is normal wear.
    thanx for the diagrams too :headbang:
  7. May 23, 2009 at 9:39 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Stealership: $1300
    You: :lalala:
    Stealership: Yes, we're serious.
    You: :argue:
    Stealership: Would you like to set-up an appt?
    You: :annoyed:
  8. May 23, 2009 at 10:02 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    haha thats EXACTLY how it went too. I originally just called to price parts cuz I get theirs for %20 off, but then talked to service and there it was...
    I think I wil just ignore it for now and go wheelin
    :burnrubber::mudding:
  9. May 24, 2009 at 8:51 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  10. May 24, 2009 at 8:55 AM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    do you have a lift? was the "shimmy" due to the lift or was this normal for mileage?
  11. May 24, 2009 at 8:56 AM
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    hubs and wheel bearings are easy. and why are you going to the stealership? go to a napa or vato-zone.
  12. May 24, 2009 at 11:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On the second gens, pressing the bearings out is a PITA. BUT, getting the Hub/bearing assembly as one unit from the dealer, or another parts place, makes teh install realatively easy. :)
  13. May 24, 2009 at 11:24 AM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    yeah I got a 2"-3" lift, but those vibrations are fixed (pinion angle)
    since I bought the truck at 60k miles there has always been this shimmy at 65mph+ not terribly bad, but I notice it.
    I'll probly just buy the parts and install myself when it starts bugging me more. I don't usually go to a dealer for repairs, but I wanted a good chuckle. I usually buy my parts from toyota now cuz I get a 20% discount, even if it costs a bit more than napa or w/e I have piece of mind that the parts will be correct.
  14. May 24, 2009 at 12:03 PM
    mikey05
    mikey05 Member
    05 DC Shortbed
    Too many to list
    My bearings blew out at 38,000 miles and Toyota warrantied it under the drivetrain warranty. My truck is not stock by any means either. At the time I had the lift, bullbar, winch, etc. They claimed it was due to lack of proper grease. So factory part failure. But they did not replace the whole hub assembly only the bearings. Mine made a horrible noise and you could put your hand on the passenger hub after driving 50 miles(only warm) the driver side hub was another story I lost skin on 2 fingers as a result of that test. So hot I could not believe it.
