Are you supposed to use the parking brake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fgeorge097, Jul 1, 2018.
  1. Jul 2, 2018 at 7:03 PM
    #61
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Well, been following from the beginning cuz...I'm a 100% er.
    In my jurisdiction it is demanded as part of the 'fit' certification of your vehicle. It has to be functional to be deemed 'safe'. If one does not use it, it is the quickest path to becoming non functional, and no longer safe.
    Cides, if ya ever REALLY need to disable nanny features, handbrake is your friend. Think of it as .... fun.
    Oh, and all the tech responses are bang on also.
  2. Jul 2, 2018 at 7:15 PM
    #62
    DubfromGA
    DubfromGA Well-Known Member
    Greg
    2017 Black SR5 4WD
    Same here. Every time.
    hiPSI[QUOTED] likes this.
  3. Jul 2, 2018 at 7:19 PM
    #63
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    I started using it all the time now regardless of whether on a flat surface or incline. Read an article a couple of weeks ago about things you should do to make your car/truck last longer. Using the parking brake was one of the things in the article.
  4. Jul 2, 2018 at 7:25 PM
    #64
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  5. Jul 2, 2018 at 7:32 PM
    #65
    Marconis
    Marconis Well-Known Member
    New York
    2017 SR5 DCSB 4X4
    I'd like to ask again since I got buried -- had my drums adjusted last weekend (and other work), tech told me to use my parking brake all the time. Started doing so and my pedal feel is immaculate, like new. My pedal feel was shit after 5100 miles, at 7000 now and I like it. Thing is, clicks aren't consistent with the brake lever on level grade. I see in the manual it says 5-7. I sometimes have to pull all the way up for one, sometimes it gets 2-4. Sometimes, none. Problem? Parking brake engages firmly, as far as I can tell. I haven't noticed any drag symptoms, no pulsating pedal, drum hubs are warm but not hot when minimal braking is applied. I hit 28 MPG on my 32 mile commute to work this morning which I'm not sure I'd be able to achieve if they were hugging. Tech also confirmed they weren't overadjusted when I picked up my truck on Saturday. Curious for input. Thanks!
  6. Jul 2, 2018 at 7:37 PM
    #66
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Whether brakes or parking brake are simultaneously depressed, it doesn't matter as far as which brake system is holding the vehicle. The brakes are keeping the vehicle in position and the pressure OFF the pawl. You don't need to release the brake pedal before shifting into P, and the habit of keeping my brakes engaged also is useful when releasing the parking brake to keep the vehicle from lurching. In my earlier post, I described that I stop, hold the brakes, shift into N, set the parking brake, shift into P, then release the brakes. The vehicle doesn't budge or lurch forward, so I know the brakes are holding the vehicle.
    Marconis likes this.
  7. Jul 2, 2018 at 7:49 PM
    #67
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Go down a deserted side street at 10 mph. Coast and slowly pull your parking brake. You will then "feel" what your brake does. Personally I have no clue how many clicks. I just quickly pull it after turning the vehicle off. I know it will hold.
    Marconis[QUOTED] likes this.
  8. Jul 2, 2018 at 7:51 PM
    #68
    Marconis
    New York
    2017 SR5 DCSB 4X4
    Mines holding good, found that out when I was parked on a slope today and put it into drive and realized I wasn't moving as I didn't release brake all the way down.
  9. Jul 2, 2018 at 8:38 PM
    #69
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    Yep. Was grateful to have it on the Alero after blowing a brake hard line while coming up to a light.
    Joe23 likes this.
  10. Jul 2, 2018 at 8:44 PM
    #70
    Kabogski
    Kabogski Sport Rally Five
    Bote
    Los Angeles
    17' MGM - Anim na Piston.. Sport Rally Five
    Hi tuck Exhaust FalkenWildPeaks Blackout Badge
    Its one of your $35k investment.. if your brakes doesn't work while driving... :fingerscrossed:
  11. Jul 2, 2018 at 8:54 PM
    #71
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Auto and i always use it . Habit from when I drove manual but it's also good to use so it doesn't seize.
    I've seen a few people's who no longer works because it was never used and seized up to the point it didn't work anymore. Good to keep it working if your brakes ever failed you'd still have that at least. That's what I've always been told.
    Besides means you're not relying on the transmission only. I'm convinced it's easier on it too .The odd time I take it off earlyor put it on after taking foot off the brake and you get that slight roll, I've noticed you'll feel a slight resistance compared to when the weight of the vehicle isn't on the transmission, when you shift into drive .
    This could be because my driveway is sloped so I always have the roll of brake isn't on. So I'll continue to use it.
    Now what about the hold while engaging as to not wear the ratchet of it?
  12. Jul 2, 2018 at 8:55 PM
    #72
    Joe23
    Same for me and I swear it's easier to put it in gear when you do this vs if you don't.
  13. Jul 2, 2018 at 8:58 PM
    #73
    Joe23
    Was that the thread where the guy went ape shit because his building towed his truck claiming he didn't get the memo they were repaving the parking lot
  14. Jul 2, 2018 at 9:02 PM
    #74
    Joe23
    I think there was one guy who bent an axle because of this. He lived in the mountains. Supposedly a common thing if it's a above freezing then drops suddenly the brake can get frozen on? And he thought putting on diff lock would work better lol.
    If I remember right locals said he should've hit the drum a little too brake the ice if anything.
    I had one stuck years ago .Even though I always used it the cables rusted out and it wouldn't release the brake. But who knows that was shortly after I got the car used, for all I know previous owner never used it and that's what caused it to seize even I put it on.
    But only cases I've ever heard of it sticking
  15. Jul 3, 2018 at 9:05 AM
    #75
    tacoboy69
    tacoboy69 Well-Known Member
    How come when applying parking brake and then releasing foot brake on a hill, the vehicle may still shift slightly? Shouldn't the brakes be one in the same?
  16. Jul 3, 2018 at 9:07 AM
    #76
    Spillproof
    Spillproof Well-Known Member
    Ken
    Nova Scotia
    2018 Inferno AC OR
    Parking brake only engages rear brakes. Releasing the pedal would take any brake load off the front tires, which you might feel.
    Riding Dirty likes this.
  17. Jul 3, 2018 at 9:31 AM
    #77
    MillCreek
    MillCreek Well-Known Member
    Snohomish County, Washington USA
    2016 TRD Sport 4x4 DCSB AT
    In my 40 years of driving manual and auto transmission cars in the Seattle area, I engage the parking brake every time. And if I am parking uphill at a curb, I turn the wheels away from the curb and if parking downhill, I turn the wheels toward the curb, as a further backup.
    tonered likes this.
  18. Jul 3, 2018 at 9:43 AM
    #78
    fgeorge097
    fgeorge097 [OP] Well-Known Member
    Northeast
    2018 OR AT
    I think this is a good point that has not gotten many comments. What do we all thing? Release foot brake pedal before shifting into P?
  19. Jul 3, 2018 at 9:44 AM
    #79
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    IMHO, I would use it every time. Growing up, a friend of mine had an old Ford pickup. He never used the parking brake, just slapped it in P. One day, I saw him panicking driving past our house. The brakes failed and the parking brakes were frozen from lack of use.
    Beyond that, it takes stress off of the transmission, esp ATs, if you let them fully decouple before engaging.
  20. Jul 3, 2018 at 11:23 AM
    #80
    Riding Dirty
    PlastiDip
    Below should help.......
    Brake pedal engages front and rear brakes, parking brake is in rear only.
    I don’t, I keep both sets of brakes engaged until after shifting into P. If for some reason my parking brake fails before or during my shift into P, I won’t roll anywhere or harm my transmission. Plus, it keeps my vehicle rock steady until my brake is set. That’s just me though. You do what you think works best.
