Are you using 5 and half quarts when doing oil change 4.0 V6?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazze2005, Jul 25, 2016.
  1. Jul 25, 2016 at 6:38 PM
    blazze2005
    blazze2005 [OP] Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Someone was telling me toyota revised the owners manual for the 2nd gen 4.0 trucks
    Now were supposed to be using 5 and half quarts when doing oil change with filter?
    Ive been using 5 quarts 10 ounces for the last 10 years with no problems,so not sure why I would change how much oil to put in. Anbody heard of toyota revising the owners manual to use 5.5 us quarts of oil? thanks for any info...
    Rambo MARINE Recon likes this.
  2. Jul 25, 2016 at 6:41 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I have always used 5.5 Quarts doing an oil change on my Taco's.
  3. Jul 25, 2016 at 6:42 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Always 5.5 quarts
  4. Jul 25, 2016 at 6:43 PM
    blazze2005
    South Jersey
    But doesn't 5.5 put us way over the full mark?
  5. Jul 25, 2016 at 6:51 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    My '15 PreRunner V6 is the first Toyota I've owned that has oil right at the full mark using 5.5 qts. According to my owners manual, some use 4.8 qts.
    Check the owners manual.
    yotaTom likes this.
  6. Jul 25, 2016 at 6:55 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    My owners manual (and Chilton's) says 5.5 with filter but capacities called out are approximate... you add as necessary to bring to appropriate levels. For the engine oil that's between the 2 marks on the dip stick. My truck takes around 5.2 quarts to get to the top line on the stick... 5.5 takes it over.
  7. Jul 25, 2016 at 7:16 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I usually put in 5 quarts and I'm right between the two dots on the dip stick.
    Sharpish and ColoradoTom like this.
  8. Jul 25, 2016 at 7:17 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Bingo
    Simon's Mom and ColoradoTom like this.
  9. Jul 25, 2016 at 7:25 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This, makes it especially easy when you buy 5qt jugs o oil... no half quarts laying around etc. Its about 1/4in below the top full mark and im fine with that.
    svocobra and ColoradoTom like this.
  10. Jul 25, 2016 at 7:29 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Fill until between the bolts, doesn't matter how much you need to add as long as the level gewd in the end
    Skunny likes this.
  11. Jul 25, 2016 at 8:10 PM
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    I do 5.5 and in 5k mi when I do it again I get 4.5qt out. Soooo I'll stick with 5.5qt. Honestly just personal preference
  12. Jul 25, 2016 at 8:13 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    About 5.25 puts it right at the full mark on mine.
  13. Jul 25, 2016 at 8:15 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    5.5 on the dot every time, puts it to the full mark on the dipstick.
    shakerhood likes this.
  14. Jul 25, 2016 at 9:03 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    4wd v6 and v6 PreRunner are 5.5 - other v6 (probably only X-Runner) has different oil pan for 4.8.
    yotaTom likes this.
  15. Jul 25, 2016 at 10:31 PM
    timothom
    I always dump some clean oil in when I have the plug and filter out, and let it run out the bottom clean. I count that out of the half, so, I guess mine is less than 5.5.....
  16. Jul 25, 2016 at 10:48 PM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    4.0 V6 here. First oil change I added 5.5 quarts as manual stated, was way over filled according to the stick. Next change added 5 quarts, checked it the next morning and was just above the top fill line. So 5 for me.
    Is the pan off or are the dipsticks off? I'm one that believes between the lines is better than over the line. @ 5 quarts I'm still just above the line but living with it.
  17. Jul 25, 2016 at 11:41 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    No, I do not use 5.5 quarts. I use 5.2 litres. It is not a 4.18 qt. engine, it is a 3.956 Litre engine. :ohsnap:
  18. Jul 25, 2016 at 11:51 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Sub'd!:thumbsup:
  19. Jul 26, 2016 at 2:52 AM
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Oil cooler on factory tow package trucks might make it a little different, too.
  20. Jul 26, 2016 at 3:24 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    I lift the front end slightly to make sure the drain hole is at the low point, then drain it warm. I get a 1/2qt. more out that way. It takes 5.0 US quarts, which puts it just below the full mark. I know guys who fill it, start it, check for leaks, turn it off, and immediately check it. Can't get a correct reading unless you let it settle. I check mine hours later, maybe even the next day. It doesn't need to be exactly on the full mark to be ok. That extra quart is expensive.
    svocobra and TACO TX like this.
