Aries Brush Guard Install Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PeteK, Apr 25, 2009.
  1. Apr 25, 2009 at 6:53 AM
    PeteK
    PeteK [OP] Well-Known Member
    Brockton, MA
    2017 Cement Truck
    Call me crazy, but I've been playing with all types of combinations and the top brackets I got with the Aries Modular Brush Guard just do not seem to fit.
    The install doc is here: http://ariesautomotive.com/applications/PDF/grillbrush/2054.pdf
    My questions are:
    1. Do I have the right parts (see pic below)?
    2. In the photo below, which part attaches to the brush guard, and which attaches to the frame of the truck? Ends A or B?
    3. Also in the photo below, which goes on the drivers side, and which on the passenger side? C or D?
    There just isn't a combination that seems to work.
    Saw a thread on another forum by an inactive user who had to heat up and bend his top brackets to get them to fit. Here: http://www.toyotanation.com/forum/showthread.php?t=127839&highlight=aries+tacoma
    Any help would be appreciated. Would be great if you could take a photo of where it attaches to the frame. I'd love to get it installed this weekend!
    Thanks,
    Pete
  2. Apr 25, 2009 at 7:29 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    looks to me that A goes to the truck. Starting from that info. put it in position and see if it lines up with an existing whole. I imagine that you have already done so. Sorry I have been not much help.
  3. Apr 25, 2009 at 7:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The pic they have in the directions sucks. I belive "A" goes to the frame, but for what side, Im not sure. Like Rtrn2taco said, try both and see which lines up best.
  4. Apr 25, 2009 at 8:37 AM
    PeteK
    Brockton, MA
    2017 Cement Truck
    Ooooh. I may have figured it out. Will take photos if true. Toughest part is getting the first 6 nuts off the frame as they are hella tight.
    Will post my results.....
  5. Apr 25, 2009 at 3:57 PM
    PeteK
    Brockton, MA
    2017 Cement Truck
    Here is the secret to the top brackets. This is the drivers side. Passenger side is the same. Turns out part D is the drivers side one and part C is the passenger side. End B goes on the frame and end A goes on the brush guard.
    Hope this helps someone in the future!
