Arizona emissions
Discussion in 'Arizona' started by 05RedTaco, Jan 4, 2012.
  1. Jan 4, 2012 at 11:19 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I am thinking of getting set of JBA long tube headers, those delete front cats. I will get o2 sim so no check engine light. I am wondering if anyone with long tubes here in Phoenix Arizona has trouble passing emissions...
    Even if they would give me crap I can always put stockers back in, its only few hours of work and the LT headers are worth the BRAAAAAAAAAAP.
    Also how is it if you have cut exhaust? Will they give me any crap for that? My exhaust terminates right after rear axle. Again its not a big deal... I have the piece I cut and I can easily just clamp it back together...
  2. Jan 4, 2012 at 11:38 AM
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    This has to do with were the exhaust dumps. You technically can't have it under the vehicle, due to carbon monoxide .. bla bla bla.. passenger compartment .. even though no none rides in the bed.. You exhaust needs to be blown clear of the vehicle.
    I'm think I'm cut the same way you are. I come out just past the rear axle but it does not vent to "open air".
  3. Jan 4, 2012 at 11:39 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    i have long tubes....but have not gone thru emissions yet....but i really am not worried about it, it will pass :thumbsup:
  4. Jan 4, 2012 at 11:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All they do at emisions is check the fuel cap, and plug an OBDII reader into the diag. port. If no engine light, then your good to go! They dont care about headers, or anything else.
  5. Jan 4, 2012 at 2:25 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    If you are not throwing a code when they check then you are cool.
    However they will want to see the exhaust out from under the body.
    That is what I encountered many years ago with a Camero my son had.
  6. Jan 4, 2012 at 2:50 PM
    05RedTaco
    Tony
    Scottsdale
    Thanks for the quick responses! Nice to know that with long tubes and o2 sim I will be good to go! Gonna put the exhaust on I cut off with a clamp before I go...
  7. Jan 4, 2012 at 3:29 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Im actually qualified to do emissions for a fleet so its a little different than an inspection station. The law says the inspectors are supposed to make sure all of the factory supplied emissions equipment is still operable (cats, air injection system, purge assy, etc) but they never do. All they really do is plug in to OBD and make sure the light comes on and goes back off after starting. Now when the inspectors come by and do our testing they will fail me if I do not get under the unit to check the cats and other systems. So once again you will probably be ok, but AZ law states you must have all OEM emissions equipment to pass inspection
  8. Jan 4, 2012 at 4:20 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
  9. Jan 5, 2012 at 2:48 AM
    Aw9d
    Aw9d That one guy
    Yup, I used to work for the emissions here. Chris4x4 is right. Don't worry about it.
  10. Feb 2, 2012 at 1:04 PM
    05RedTaco
    Tony
    Scottsdale
    They didn't care about my cut exhaust, however my truck failed because the gas cap is bad...UGH!
  11. Feb 2, 2012 at 1:05 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    and let me guess, they took your money, then told you you didnt pass huh?
  12. Feb 2, 2012 at 1:10 PM
    05RedTaco
    Tony
    Scottsdale
    of course. its bullshit. you can run NO cats and still pass if you don't have check engine light on... retarded and waste of time
  13. Feb 2, 2012 at 1:12 PM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Sierra Vista, AZ
    It seems you have your answer now. I was going to say I had my subaru catless and ran through emissions with the code cleared and I passed.
    i have been running DT longtubes for the last... 3 years.... and JUST bought the o2 sensor from URD because I HAVE to take my 07 through emissions this month boo.
  14. Feb 2, 2012 at 1:13 PM
    Aw9d
    Aw9d That one guy
    Ha this is so true. I used to run my 99 civic , b16 turbo kit, 11psi Turbo setup, no cat at all.. They'd plug in the obd2, it'd pass, test my gas cap, I'm all set. Never even had to fire up the car, just turn on the ignition.
  15. Feb 2, 2012 at 1:15 PM
    05RedTaco
    Tony
    Scottsdale
    So in the goverment's eyes you can run catless, but if you gas cap is bad they fail you. Wonder whats worse... Running catless or bad gascap...hmmm
  16. Feb 2, 2012 at 1:18 PM
    Cr250jumper
    The moon
    50 shades of tan©
    A Cat just helps "trim" the emissions. If your check engine light is not on and you do not have a O2 simulator then you are not running high levels of CO or HC's. If your gas cap doesnt work you are venting fuel vapors to the atmosphere
  17. Feb 2, 2012 at 2:53 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    I am pretty sure if you fail you get two free attempts to pass before they charge you again.
  18. Feb 2, 2012 at 6:05 PM
    05RedTaco
    Tony
    Scottsdale
    New gas cap for $16.80 at a local dealer and the Taco passed... I thought of getting cheapo gas cap at O'reilys, but I like OEM parts on my Taco...
