Arizona Inspections
Discussion in 'Arizona' started by Elow007, Nov 19, 2015.
  1. Nov 19, 2015 at 7:32 PM
    Elow007
    Elow007 [OP] Well-Known Member
    Nick
    1996 tacoma 5vz
    Hello all, I will be moving to Arizona soon and I'm bringing a 1996 tacoma v6 (fvz-fe). I'm originally from Kansas and lived in Colorado for a spell, neither state required me to do vehicle inspections in the counties I lived in. I'm curious as to what I need to have in order for the inspection. I understand that I will have to pass smog inspection, I am not too worried about this as the engine is sound and runs well. However I can't say the same for the suspension, steering components and body parts.
    Will a comprehensive inspection be performed where the play in tie rods and rack and pinion steering is assessed?
    Will I get dinged for the crack in my windshield?
    Both the front diff seals are leaking a bit, problem here?
    Its got a little rust, will that be a problem?
    What can I expect and what should I be prepared to face bringing an older vehicle to AZ state inspections.
    Thanks in for your time. I will be moving to Glendale Arizona (NW Phoenix area).
  2. Nov 20, 2015 at 5:40 AM
    robu
    robu Well-Known Member
    Rob1224
    Cottonwood, AZ
    TRD sport debadged
    kings front and rear 3" expedition deaver pack 700lbs in front. lighted 4x4 switch and fixed temp console
    Hi
    it depends on where you live Maricopa county is the only one that requires a smog test if I'm not mistaken, so any where else you should be good:thumbsup:
  3. Nov 20, 2015 at 8:52 AM
    flying_az
    flying_az Well-Known Member
    Scottsdale, AZ
    2014 TRD Off Road, 4X4, MT
    Old Man EMU, Avid sliders, Pelfreybilt skids, winch mount bumper & winch, 265/75-16 BFG KO2s, fiberglass tonneau cover, flexible mud flaps, locking tailgate, debadged, decals removed, breather relocate
    I would suggest going to an Authorized 3rd Party Office. I believe they charge an additional $30, but just the amount of time you will save, NOT standing in line, is worth it!
    I registered an out-of-state car (170k, a cracked windshield, and various drips) last month; other than the emissions test, which takes about 5 minutes, no one even looked it.
    Side note...since you are transferring registration from out of state, if you want things to go very smoothly, have your title with you (in addition to current registration, proof of insurance, emissions test, etc.). They may not ask for it, but it seemed to help things along when I did it.
    http://azdot.gov/mvd/hours-and-locations
  4. Nov 22, 2015 at 8:16 AM
    Brodie3az
    Brodie3az Member
    Tempe
    93 X'cab
    Maricopa and Pima (Tucson) Counties require Emissions testing.
    Arizona does not currently have a vehicle safety equipment inspection program, ended in the 60's.
