AriZonaD54's SPBlack Build...
Discussion in '2nd Gen. Builds (2005-2015)' started by AriZonaD54, Sep 7, 2009.
  1. Nov 16, 2011 at 9:56 PM
    #621
    blackphantom09
    blackphantom09 Newbie
    V.B., VA
    09 Double Cab TRD-Off Road SB
    TRD Exhaust, Black badges, Jason Rage tonneau bed cover, TRD S/C, OEM roof rack, Avid Light Bar
    Just wanted to know what size crossbars and fairing did you get from Thule? Thanks.
  2. Nov 17, 2011 at 9:30 AM
    #622
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    The set up off my truck is for sale in the for sale section.
  3. Nov 28, 2011 at 10:43 AM
    #623
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    hey Andrew hope all is well with you! and i have a question, where the hell did you get your gaskets for the doug thorley's!!
  4. Dec 9, 2011 at 7:22 PM
    #624
    AriZonaD54
    AriZonaD54 [OP] BANNED in 49 states...
    Andrew
    Valley of the Sun
    rockauto homey!
  5. Feb 16, 2012 at 8:14 PM
    #625
    tacosunday
    tacosunday GoldMember
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Hey nice truck man, Question: Did you have to do the cab mount chop to fit the 295's? And, how much plastic did you have to trim? I really want to throw the 295's on my whip yo.
  6. Feb 16, 2012 at 9:33 PM
    #626
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    He doesn't get on here much anymore. He got rid of his truck. But I asked him the same questions a year or so ago. He didn't cut his cab mount and the plastic trimming on the front fenders is minimal. He also had a 3'' lift. He said it only rubs a little sometimes at full lock on incline/decline.
    I ended up getting 295's too. As far as fitting my 295's, everything he said was right. I have a full 3'' lift. I didn't cut the cab mount. Just had to trim a little plastic at the front and back of the fender, nothing that you can see unless you look in there. It only rubs a tad if I'm at full lock on an inline/decline; which is about 1% of normal driving. You can always have the cab mount cut if that bothers you, but it's not hurting anything. The only other thing I can think to add is having 4.5 backspaced wheels.
  7. Feb 16, 2012 at 9:35 PM
    #627
    tacosunday
    Josh
    San Tan Valley, AZ
    4x4 OR DCSB
    Ok cool, thanks for the info. Much appreciated
  8. Feb 16, 2012 at 9:41 PM
    #628
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    you shut your mouth! :D
    Miss ya around here man!
    This is STILL one of the most BAMF builds on this site :cool:
  9. Feb 17, 2012 at 1:05 AM
    #629
    DevL
    DevL Well-Known Member
    I almost got the same wheel and tire set up. Rims, 17x9 Artillery, are still on order and I went 285/70R17 Trail Grapplers because what these guys are not telling you is that you will rub the fuck outta the cab mount with a standard chop under compression when wheeling. No cab mount chop? Hope you don't wheel much. 285s still require the cab mount chop to eliminate rubbing when the wheel is turned during full compression. Sure if you have a mall crawler or won't compress your suspension unless going straight you wont have a problem. You gotta have 285/70R17s if you want to TOTALLY eliminate rubbing under ALL conditions. I did not want to chop my cab mount INTO the hole or accept rubbing on turns under compression... so I had to go 285 instead of 295. Up side? 295s have a lower speed rating, weigh more, cost more fuel, cut more power, and cost $100 more per set. .4" in height and .16" in width just was not worth it for me. Whatever you choose, I'd seriously look at over 33" tires on people's ACTUAL trucks before deciding. The .25" extra I would have to cut does not sound like much till you see what it means for what actually needs cutting.
  10. Mar 1, 2012 at 3:44 PM
    #630
    AriZonaD54
    Andrew
    Valley of the Sun
    First off, use paragraphs. Please. It makes posts, including the one you just made, easier to read.
    You make valid points, but your logic only applies to those with the exact SAME suspension components as you. At full compression, I barely rubbed the cab mount. That being said, when I had 285s, those also rubbed. Though, they certainly rubbed less.
    I chose the 295s because when I selected the Nittos nearly 2+ years ago, Nitto was not producing anything smaller than the 295s. I was able to get a fantastic deal on the Nittos and ultimately pursued a purchase of 5 Trail Grappers in 295. If I had to do it all over again, I would have changed nothing.
    Again, thanks for your input and don't forget next time you want to junk up my (old) thread... use paragraphs.
  11. Mar 1, 2012 at 3:48 PM
    #631
    AriZonaD54
    Andrew
    Valley of the Sun
    Alive...Barely.
    A Wildcat... Until I DIE!
    People (DevL) that junk up my threads without using proper writing structure, e.g., paragraphs... Pisses me off.
  12. Mar 1, 2012 at 3:51 PM
    #632
    Aw9d
    Aw9d That one guy
    awesome build man! looks good!
  13. Mar 1, 2012 at 3:55 PM
    #633
    AriZonaD54
    Andrew
    Valley of the Sun
    A big-gas-guzzlin'-V8 2007 Denali. We still have the X5 too.
    Biding my time until I get find my next major build -- whatever that might be.
    Here's the Denali. If you see me rolling around the Valley, feel free to wave at me (middle finger wave excluded);
  14. Mar 1, 2012 at 4:02 PM
    #634
    AriZonaD54
    Andrew
    Valley of the Sun
    Sadly, I got rid of the M3. Stupid decision. I'm still kicking myself over that move. :mad:
    The good news is that we consolidated from 3 vehicles down to 2. Insurance was brutal with 3 vehicles.
    Next major move? An attempt to stop buying "toys" and buy a new house. My girlfriend (of forever) has been ill for nearly 2 years, so I've been busy keeping her spirits up. My hobbies and interest have taken a backseat to her health and happiness.
  15. Mar 1, 2012 at 9:34 PM
    #635
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Sorry to hear about your girlfriend. I hope things get better!
    I do think it's time for another Tacoma though. :)
  16. Mar 9, 2012 at 5:34 PM
    #636
    KingOfTacomas
    KingOfTacomas BadAss
    Jeff
    Colorado, Breckenridge
    2003 SR5 Tacoma
    New build page to come by the Fall of 2014
    :eek: why would you sell the Taco!!! and then the M3:confused::confused::confused:!!!
    Sorry about your girl man :(
    Hope you don't mind if I use some of the ideas on your old taco? That things looked liked a beast and it could do some serious off-roading!
  17. Mar 15, 2012 at 6:51 PM
    #637
    AriZonaD54
    Andrew
    Valley of the Sun
    Thanks brother.
  18. Apr 4, 2012 at 9:18 PM
    #638
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    how do you like your TRD CAI?
  19. Apr 4, 2012 at 9:46 PM
    #639
    PLC721
    Patrick
    Chandler, Az
    i believe he "liked" it for the time being :)
  20. May 4, 2012 at 12:25 PM
    #640
    AriZonaD54
    Andrew
    Valley of the Sun
    IMO, a waste of money. Spend money elsewhere. The stock Toyota intake is pretty damn good already. If anything, work on your headers back.
