Armageddon Armor by Southern Style OffRoad
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SouthernStyleOffRoad, Feb 20, 2020.
  1. Mar 24, 2020 at 9:40 PM
    #241
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    Well, Amazon is pretty much dead for the next month or two (1-2 month delivery time on most things for me that normally come same day).
    I'll make my own isolators with some coolant hose or something. Will be cheaper for sure!
    Bertw192 likes this.
  2. Mar 26, 2020 at 9:25 AM
    #242
    cheuer
    cheuer Well-Known Member
    Utah
    2016 DCSB TRD OR 4x4 Blazing Blue Pearl
    Leer 100XR, Mobtown Offroad Sliders
    I am really intrigued by this kit, but I have a couple questions. I have never welded a thing in my life, but I am very comfortable with DIY projects and vehicle maintenance etc. If I pick up a welder and some scrap metal to practice with, will I be able to tackle this bumper as my first real project? Also, is a cheap Harbor Freight flux core welder good enough or would I need something more high powered?
    shane100700 likes this.
  3. Mar 26, 2020 at 9:36 AM
    #243
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Make sure what ever welder you get can tackle the thickest metal of this bumper which I believe is 1/4". The super cheap welders aren't rated for metal that thick.
  4. Mar 26, 2020 at 9:48 AM
    #244
    calebc
    calebc Well-Known Member
    I don't see why you wouldn't be able to tackle this eventually. Generally bumpers aren't a critical piece (meaning if a weld fails while driving down the trail, it's not going to be much more than in inconvenience). The only part you would want to make sure to be very careful/sure of is the shackles as though could have a lot of weight/stress placed on them. These bumpers are made in a way that the joints are all simple clean fitting joints. That simplifies a lot. You also grind down most of the visible welds so you wouldn't have to worry too much about having ugly welds. However, I would do more than just get some scrap and stick it together before starting this. If you have a community college nearby, many have basic welding classes you can take for cheap. There's also lots of online resources to teach you how to weld. I would go get some instruction from a competent weldor before jumping in to this project.
    As for the welder you're asking about. I personally wouldn't buy a HF welder, but that's me. I'd stick to the "brand names" like Miller, Lincoln, Esab, Hobart, etc. Even one of the smaller (135ish range) welders from the brand names could handle this with someone knowledgeable on welding. The bigger machines make it a bit easier to not be as good.
  5. Mar 26, 2020 at 11:11 AM
    #245
    toofast4u752
    toofast4u752 Well-Known Member
    carlos
    2018 TRD-Sport 4X4
    i wouldn’t do this with a flux Core.. most flux core wouldn’t have enough power.
    I have the Hobart handler 140, I welded at full power and kept my wire speed down to get sufficient heat. I would take this as an opportunity to buy a decent welder. Find some scrap metal, watch some YouTube, practice then attempt the bumper. My welder was reasonably priced, I think about $600 plus tank and accessories.. but I bought it 8 or so years ago.
  6. Mar 26, 2020 at 11:17 AM
    #246
    toofast4u752
    carlos
    2018 TRD-Sport 4X4
  7. Mar 26, 2020 at 11:54 AM
    #247
    calebc
    Flux core will provide better penetration generally. So using fluxcore shouldn't be an issue.
    Here's a decent article on the two (from a trusted source):
    https://www.millerwelds.com/resourc...rsus-flux-cored-wire-when-to-use-them-and-why
    I do agree with the sentiment that generally speaking, bigger is better. However, I would take a 135-140 miller over a 210 HF. There's also considerations, if you don't have a 220V plug near your working area, that rules out a bigger machine.
    toofast4u752 likes this.
  8. Mar 26, 2020 at 11:59 AM
    #248
    calebc
    I finally got the last of the parts I've been waiting for so I got mine all buttoned up. I ended up painting it instead of powder coating because I actually ALSO bought the new SSO hybrid. So once that arrives (planning 3-4 months), I'll swap this out and sell this. I'm also planning to swap out the red shackles for some that are not red (probably black or grey) :D. Those are just what I had.
  9. Mar 26, 2020 at 1:23 PM
    #249
    cheuer
    Utah
    That is a problem, I don't have a 220v plug anywhere except in the laundry room and I don't think the wife would let me set up there, not to mention it's way too small. Same with the kitchen.
  10. Mar 26, 2020 at 1:46 PM
    #250
    calebc
    Couple things, depending on how close your laundry room is to your garage/workspace, many people have made extension cords to use the dryer outlet. If it's too far though, the loss would be too much. Second, I just noticed you're in Utah, what part? I'm in the Riverton area and (if you're not too far) would be happy to weld it up for you, then you could take it home and grind it down/paint/coat/whatever.
  11. Mar 26, 2020 at 2:08 PM
    #251
    cheuer
    Utah
    It's not even on the same floor, I'd have to run an extension out the window down to the garage and I'm sure that wouldn't be worth it. My basement is unfinished so I could potentially look at running an outlet to the garage.
    Thanks for the offer, I was sort of hoping to use it as a learning opportunity but if I change my mind I'll let you know. Got some more research to do for now...
  12. Mar 26, 2020 at 2:12 PM
    #252
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    The Harbor Freight Titanium Mig 140 (120 volt) handles up to 5/16 which would be fine for this bumper. It is $399 though, but there is a 20% coupon floating around the interwebs right now.
  13. Mar 26, 2020 at 2:21 PM
    #253
    Alfamua
    Alfamua Well-Known Member
    Alfa
    Sacramento
    17 TRD OR
    Fox 2.5 coilovers dsc. Fox 2.o with dakar. SSO slimline stage 1 and 2
    If anyone need a welder in Sacramento area. Youre more than welcome to come to use it. Just bring six pack of CORONA
    Taco_Coma likes this.
  14. Mar 26, 2020 at 2:28 PM
    #254
    Alfamua
    Alfa
    Sacramento
    17 TRD OR
    Sold my 220v lincoln mig for the titanium unlimited 200 120/240 multiprocess.
  15. Mar 26, 2020 at 2:30 PM
    #255
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    I've heard good things about that machine.
  16. Mar 26, 2020 at 2:50 PM
    #256
    Sand_In_My_Taco
    NOR*CAL
    Flux core is perfectly fine to use, and has greater penetration that solid wire.
    If your using a smaller welder, flux core would be even better to use because it stretches the machines capability.
    Also, I went through about 2.5lbs of .035 flux core for reference. And I typically did a stringer with some light side to side, slow and hot, for the vital points. After it cooled a little, I went back over it with a wide weld to build some strength.
    And remember... In the world of welding you are an expert in 1 of two things.
    You're either an amazing welder, or an amazing grinder :)
    TacoManOne and shane100700 like this.
  17. Mar 26, 2020 at 7:21 PM
    #257
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    calebc likes this.
  18. Mar 26, 2020 at 8:02 PM
    #258
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
  19. Mar 26, 2020 at 8:06 PM
    #259
    TacoManOne
    Paul
    Liberty Lake, WA
    I was looking at a Lincoln then found that. Great value.
  20. Mar 26, 2020 at 8:09 PM
    #260
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    Agreed. Multi process is where it's at.
    Alfamua likes this.
