Armor front bumper ok on OME 887 sport shocks?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AJC84, Nov 25, 2016.
  1. Nov 25, 2016 at 3:07 PM
    AJC84
    AJC84 [OP] Well-Known Member
    Andy
    2011 DC LB V6 4X4 MAG GREY
    I am interested in putting an aftermarket front bumper on my 2011 dclb. I have an old man emu lift with 887 sport shocks up front. At the time I lifted it I was told if I wanted to add a heavy bumper up front with possibly of a winch I should get 886s.
    Can I get away with adding an aluminum front bumper or steel front bumper without having any issues with the 887 sport shocks?
    The Pelfreybilt I am considering is about 60-65lbs in aluminum or 105-115 in steel.
    I should mention I am also planning on doing rear steel bumper at about 85lbs. I have OME dakars in back.
    Any help would be greatly appreciated!
  2. Nov 25, 2016 at 5:13 PM
    Pigpen
    Dan
    Northwest Montana
    You can do this. An aluminum bumper will have minimal effect. A steel bumper will compress the springs more. Adding a winch to either will add to the amount of compression. A steel bumper with a winch isn't recommended on those springs.
  3. Nov 25, 2016 at 6:02 PM
    AJC84
    Andy
    Thanks Siesta. I will probably go with aluminum then. That said would a 60lb aluminum front bumper have much effect on ride?
    Also curious if I go aluminum if that would allow me to pull off getting a winch at some point?
    Thanks in advance.
    AC
