Ashtray Ham Radio
Discussion in '1st Gen. Tacomas (1995-2004)' started by Johndeere40, Jul 6, 2021.
  1. Jul 6, 2021 at 6:04 AM
    Johndeere40
    Johndeere40 [OP] Member
    '03 TRD Off Road
    I'm looking for a Ham radio that will fit in the ashtray of a 1st gen, anyone know of any that fit?
    I've seen guys do it with CB's and @Willbeck stuffed a 25w rugged radio in there that appears to be out of stock everywhere.
    On that note, anyone have a RM25r from Rugged Radios they're looking to part with?
  2. Jul 6, 2021 at 10:17 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Alot of the rugged radios are just rebranded chinese radios, might have better luck figuring out which is which and searching for those.
    Johndeere40[OP] likes this.
  3. Jul 6, 2021 at 10:22 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
  4. Jul 6, 2021 at 10:25 AM
    Johndeere40
    '03 TRD Off Road
    Awesome! Thanks guys!
    The B-Tech version of that rugged radio I was initially looking for is the BTech UV-2501.
    @TMFF I was looking at that one, good to know it'll fit!
  5. Jul 6, 2021 at 10:35 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    I recommend you get a externa speaker too, it's a little quiet in the dash.
    The RR kit isn't bad ready to run at $300.
    https://www.ruggedradios.com/collec...5-watt-waterproof-dual-band-amateur-radio-kit
    Edit: GMRS kit is a little cheaper if you don't need the HAM channels.
    https://www.ruggedradios.com/collec...s/products/rugged-gmr25-mobile-gmrs-radio-kit
  6. Jul 6, 2021 at 10:38 AM
    Johndeere40
    '03 TRD Off Road
    @TMFF Noted. How bad was it to program the BTech version? Also where did you end up mounting your antenna?
  7. Jul 6, 2021 at 10:39 AM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    I used Chirp to program, easy enough to do.
    I have a mag mount that I put up when I'm using the radio.
  8. May 1, 2023 at 4:32 PM
    Natenite
    Natenite Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
  9. May 1, 2023 at 6:06 PM
    De_Birria
    De_Birria Active Member
    1997 Tacoma 4x4
    Run a fused power cable from the battery through the firewall. Hopefully these radios have gotten better. I bought one years ago when they first came out to stick in my commuter car but the firmware was so terrible I returned it.
    Natenite likes this.
