Ask a Plumber.
Discussion in 'Off-Topic Discussion' started by Rusty 06 4x4, Dec 27, 2011.
  1. Dec 29, 2011 at 6:01 PM
    #181
    Steezyskis
    Steezyskis I ski I work I'm rad
    Spencer
    Lake Tahoe (west shore)
    Black 05 DC 4x4 sport SB
    Tuff country front bumper, Walker Evans 2.5 coilovers, Allpro 3" rear leafs with 5100s and an Allpro U-bolt flip kit, K&N CAI, 16x8 Raceline raptor wheels wrapped with 285 Toyo ATs, Sockmonkey bed decals, Softtopper camper shell, half debadged with black painted tacoma emblems, B.A.M.F rock sliders, GT covers, BHLM, PIAA lights and more to come.
    Pipe as in water lines, waste lines? Both? Replaced how extencivly? Every pipe going to each shower, faucet, water heater, toilet, ect.
  2. Dec 29, 2011 at 6:19 PM
    #182
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Gotta keep in mind that copper is hella expensive... About $12-$18 for 10 feet of copper! Thats I believe for 1/2" copper 3/4" is even more :eek: So you are looking for a lot just in materials...
    It is super hard to give accurate estimate over the internet. I would have to know how many feet of copper I would need, size of copper, how many joints would need to be soldered, etc...
    Honestly copper is super easy to solder. You have to follow few basic things... Rough each end with sand paper or roughing tool, apply flux on both ends to be soldered, heat up with MAP gas or acetylene (I don't use propane it is not as hot as MAP or acetylene) and apply solder all around... The number ONE rule of soldering copper is NO water CAN be in the line. If there is water in the line you wont get a clean connection and it WILL leak! To stop water use JET SWEAT and solder in a ball valve or use compression ball valve...
  3. Dec 29, 2011 at 6:30 PM
    #183
    Steezyskis
    Spencer
    This. ^^^^^ Copper where I am is 3$ a foot. That's what I'm charging at least. Since he's in FL. That's if there using copper. Might be pex or something else. Which we don't use up here. I've seen houses in warmer climates of Cali that are full PVC everywhere. Whole house. So like stated above my quote would probably be off for your location. Maybe a plumber from FL will chime in.
  4. Dec 29, 2011 at 6:54 PM
    #184
    tacundra
    tacundra Well-Known Member
    PC FL
    dcsb mt
    Thanks guys
    In FL, so typically PVC around here.
    All pipes from incoming water line to final waste line.
  5. Dec 29, 2011 at 7:16 PM
    #185
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    We talking sched 40 for supplies in the house ?
  6. Dec 30, 2011 at 1:35 AM
    #186
    Rusty 06 4x4
    Rusty 06 4x4 [OP] NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    if your in FLA i would go pex cut your cost by almost half and it is really easy to do
  7. Dec 30, 2011 at 2:16 PM
    #187
    Rusty 06 4x4
    Rusty
    West Georgia
    yes that is what he is talking about Im sure any thing less wouldnt pass inspection.
  8. Dec 30, 2011 at 2:23 PM
    #188
    acdronin
    acdronin Well-Known Member
    Class 200 is garbage, sched 40 is good.
  9. Dec 30, 2011 at 2:55 PM
    #189
    Rusty 06 4x4
    Rusty
    West Georgia
    AGreed
  10. Dec 30, 2011 at 3:19 PM
    #190
    OZ-T
    Peter North
    British Columbia
    Seems goofy to me to try and run that stuff everywhere for supplies .
    Just use pex .
    We have to use sched 80 fittings on anything under slab , is this the same down south ?
  11. Dec 31, 2011 at 2:19 AM
    #191
    Rusty 06 4x4
    Rusty
    West Georgia
    yep I agree with that for sure pex is easier and cheaper..
  12. Jan 17, 2012 at 9:23 AM
    #192
    SuperTacoma
    SuperTacoma Well-Known Member
    Clint
    Georgia
    2019 Double Cab SR5 4x4 Silver
    Can you convert a home toilet to be like a rest stop toilet?
    I mean no tank just the all in one valve setup. If so do you know it runs?
    Thanks
  13. Jan 18, 2012 at 4:35 AM
    #193
    SuperTacoma
    Clint
    Georgia
    Tired of dealing with leaking tanks. I was just wondering if a direct flush or some other option was available. I have one toilet that I have used 2 kits on and it still leaks between the bowl and the tank.
  14. Jan 18, 2012 at 4:37 AM
    #194
    Rusty 06 4x4
    Rusty
    West Georgia
    they sell one piece toilets can you post a pic of where its leaking maybe I can help you fix it for good. you tank could very well have a small crack too..
  15. Jan 18, 2012 at 4:39 AM
    #195
    Rusty 06 4x4
    Rusty
    West Georgia
    you can you just have to buy the bowl which is about 80-100 and the flush valve which runs 100 and you would have to run a 3/4 water line to the toilet a regular residential toilet only has a 1/2 line but it is doable
  16. Jan 18, 2012 at 4:54 AM
    #196
    eastcoastcowboy
    eastcoastcowboy just sittin' in the corner, havin' a beer
    Brian
    Redneckville, NB
    '15 Skewped!!
    Weathertecs, 265/70/17 Duratracs, Trifecta Tonneau
    You would be better off to buy a pressure assist toilet.
    It gives you the performance of a flush valve toilet but no additional plumbing necessary. Chances are, you don't have the 1" water line coming in to your bathroom that is necessary to operate a toilet flush valve.
  17. Jan 18, 2012 at 8:37 AM
    #197
    SuperTacoma
    Clint
    Georgia
    I don't have a picture but it seems to be around the where the flapper piece secures to the tank. I have tried tightening and I have tried two repair kits and they both leaked. If there is a crack I don't see it. I looking into replacing the tank but it looks like I would have to order it and could take a little while. I am going out to Lowes at lunch to take a look.
    Thanks
  18. Jan 18, 2012 at 12:53 PM
    #198
    Rusty 06 4x4
    Rusty
    West Georgia
    pm'd
  19. Jan 18, 2012 at 10:02 PM
    #199
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    I got a question for ya!
    So at my grandparents house, They have a basement and it has a spare room with a full bathroom in it, Mind you we have a water heater, Water softener and we run on a well, Not a main line like the city.
    Anyways, The sink and shower seem to have really weird piping because the shower will get really clogged up and the sink will too, And as soon as i let some of that drano sit in either the shower or the sink they both end up unclogging?! and a week or two later it clogs right back up! Not sure what to do...Seems like if i turn the sink on while the shower is running then it doesn't clog up in the shower as fast and vice versa.
  20. Jan 19, 2012 at 4:38 AM
    #200
    Rusty 06 4x4
    Rusty
    West Georgia
    do you know what kind of piping the drain work is.. the well water shouldn't have anything to do with the drains clogging up.. DO NOT use draino in the pipes as it is not good at all for them..if you get a chance to take a pic or two it may help me steer you in the right direction.
