Ask a Plumber.
Discussion in 'Off-Topic Discussion' started by Rusty 06 4x4, Dec 27, 2011.
  1. Mar 12, 2012 at 6:43 PM
    #221
    Geode
    Geode Well-Known Member
    Illinois
    09 4WD TRD
    Cool, so first put on the Teflon tape, than the pipe dope?
    Here's an apparently loaded question I've researched quite a bit.
    Dialectic unions? I've heard a lot of bad things about them, and many say when joining dissimiliar metals such as my case of galvanized to copper to use brass in between the two....They say that brass is much more inert and will slow the corrosion. As you see from my photo I'm going from galvanized to brass. Then planning to plumb the house in all copper, I know many like pex, but I really actually like to solder/braze ;)
  2. Mar 12, 2012 at 6:51 PM
    #222
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Might have to flip that valve handle around so it doesn't hit the wall trying to close it ;)
  3. Mar 12, 2012 at 6:55 PM
    #223
    acdronin
    acdronin Well-Known Member
    I'm an irrigation guy (20 years), maybe a certed plumber can answer here, but the short answer I would go with is, yes you are supposed to have one BUT, if the galvi coming from the brass meter is not corroding and it's been that way for a long time, then you are probably ok with not using one.
    Yes, tape first, then dope, use the dope brush on the threads in the direction that keeps the tape tight or it will bunch it up and you will have to start over.
  4. Mar 12, 2012 at 8:32 PM
    #224
    Geode
    Illinois
    09 4WD TRD
    Will do! There doesn't seem to be a flow direction with these valves, is there a standard way to install them? For example would it be better to pull the handle downwards to shut it off and up to open it?
    I've been thinking of swapping out the 90 degree elbow for two 45 degree ones to minimize the pressure drop. And then do that on all adjoining tubing...How anal is that.....:( ???
  5. Mar 13, 2012 at 12:09 AM
    #225
    acdronin
    Too anal, not worth the extra work, and there is no right way per se, to set the ball valve, not until you pipe much higher pressures
  6. Mar 13, 2012 at 9:58 AM
    #226
    Geode
    Illinois
    09 4WD TRD
    I've scheduled to have my water service turned off on Monday, hopefully it will go smooth.
    A couple other questions. Is there a reason the piping exits the meter and then goes up and back over the meter? I'm thinking maybe to provide a bit of flexibility if things don't line up perfectly? Is this necessary?
    I work quite a bit with flow meters for my day job, and as a general rule you are supposed to have a minimum straight run length into and out of the meter so the flow is as smooth as possible for accurate flow measurements. Is this something I should add? I'm thinking so as the data sheet for the meter in question shows this.
    Thanks
  7. Mar 13, 2012 at 12:47 PM
    #227
    Geode
    Illinois
    09 4WD TRD
    I spoke with a fellow at the water maintenance division. He was very helpful and gave me a pair of 3/4" couplings! He also pulled the work order from when my water line was installed..... May 25th 1924.......wow...Might be a chance the installers were veterans from WW1..Weird to think about
    But for now I hope to get the old interior pipe/shutoff off without breaking the pipe. I'm all ears on ways to do this that would minimize the chances I'll snap it off.....The water guy suggested pb blaster and possibly lots of heat if needed.
    Thanks
  8. Mar 13, 2012 at 12:58 PM
    #228
    Steezyskis
    Steezyskis I ski I work I'm rad
    Spencer
    Lake Tahoe (west shore)
    Black 05 DC 4x4 sport SB
    Tuff country front bumper, Walker Evans 2.5 coilovers, Allpro 3" rear leafs with 5100s and an Allpro U-bolt flip kit, K&N CAI, 16x8 Raceline raptor wheels wrapped with 285 Toyo ATs, Sockmonkey bed decals, Softtopper camper shell, half debadged with black painted tacoma emblems, B.A.M.F rock sliders, GT covers, BHLM, PIAA lights and more to come.
    Just call the guy who installed it to come fix it. :D lol
    No but a couple pipe wrenches on those pipes should work just fine. Back everything up tho. So shut off the water, release the pressure in the pipes (open a faucet hosebib w/e), put your pipe wrench on the fitting your gonna loosen but put another pipe wrench on the pipe (opposite way) before what your loosening so it doesn't twist or break. Galvanized pipe is pretty tuff tho.
  9. Mar 13, 2012 at 1:27 PM
    #229
    Steezyskis
    Spencer
    Lol you could just put in a tee before the meter as a bypass and reconnect past the meter. Every so often use the metered water then shut a valve off before the meter so it bypasses around it for FREE WATER BABY!!! Lol just a thought.
  10. Mar 13, 2012 at 8:32 PM
    #230
    acdronin
    Well, it's not too big of an issue with meters i would think as far as how much straight pipe. IMO, if you hired me to do that job I would rip everything out and mount that meter vertically with the Nibco ahead of it. Measure what the length of the meter, it's fittings (minus nipples), and the ball valve. Those fittings are a type of thread union, meaning there is a ring that slides up and threads onto the ends of the meter. IDK why this guy mounted it this way, it looks like there may be enough room to do everything vertically. Unthread and remove the meter first, then go after the fittings on top of the gate valve, if they don't want to move, then be prepared to cut them off, but first, BEFORE you pass the point of no return, MAKE DARN SURE THAT FITTING BELOW THE GATE WILL THREAD OFF FIRST. Put one wrench in the opposite direction of the other wrench and pull with equal force on both, you break that sucker and next step is hammering out part of that wall.
  11. Mar 13, 2012 at 8:34 PM
    #231
    acdronin
    Is that fitting, the elbow at the very bottom, is that brass or galvi?
  12. Mar 14, 2012 at 6:57 AM
    #232
    Geode
    Illinois
    09 4WD TRD
    Thanks I really, really like the idea of mounting the meter vertically. I spoke with someone at the water company about the orientation and he thought mounting it horizontally was required. The data sheet indicates it can be mounted in any position. I'll attach it here in case I'm misunderstanding. I have a friend who is an independent housing inspector that mentioned he doesn't recall seeing a meter vertically. But he also pointed out "who reads the instructions anyway"......
    I've got a nice SDS hammer-drill for the wall.....lol
    I really appreciate the suggestions/comments
  13. Mar 14, 2012 at 6:59 AM
    #233
    Geode
    Illinois
    09 4WD TRD
    It is galvanized also, in fact all my plumbing is for the time being.
  14. Mar 14, 2012 at 7:30 AM
    #234
    Geode
    Illinois
    09 4WD TRD
    The galvanized line coming through the wall is not level, it is pitched up slightly. The first 90 degree elbow off the main is pitched towards the wall about 1/2" for every 8". So I would need to straighten this out first. How can I do that? I think I remember seeing couplings with slight bends from straight?
  15. Mar 14, 2012 at 7:54 AM
    #235
    Geode
    Illinois
    09 4WD TRD
    I've never bent 3/4" copper before. Seems a little big for a spring bender?
    Maybe cap it off and fill it with sand, then bend it by hand to a perfect vertical?
    I could put this short bent piece of copper before the first shut off or after, I'm thinking after would be better.
    I could solder a npt fitting to the 3/4" copper, tighten it into the shut off valve, bend it vertical, cut it off and sweat on another npt fitting and I'd be good to go?
    I'll be using 3/4" copper for my trunk line in the future as I replace my galvanized.
  16. Mar 14, 2012 at 8:54 AM
    #236
    acdronin
    I'd be really concerned about putting too much stress on the bottom fittings by trying to bend stuff. Maybe if you wanted to, sweat the fittings on the bench and bend the pipe in a bench vise first and then thread it on. Older galvi my look good on the outside but inside it's just particles of rust holding hands, you won't know until you put a wrench on it.
    Ya know, the more I think about your project, the more I think you should use a dialectic union now. The reason is the ground and copper creates an electrical current that if it has galvi will make it rust 'quickly'. You may want to ask the water guy that question.
    the next point of concern is getting that bottom elbow off, there looks to be room to get wrenches on everything above it off, but there doesn't appear to be room behind the elbow (going into the wall), to counter wrench. Galvi that has been on for years rarely comes off nice and easy. You may want to get everything off above it, thread on a union and go with that.
  17. Mar 14, 2012 at 8:58 AM
    #237
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    looks like your gonna have to pull the bonet off the old valve to turn it...."i could be wrong hard to tell from pic"
    and as for the dieelecttric union not needed on the meter as the unions on the meter should have a fiber washer / gasket in there
    and im not sure what all the talk is about bending pipe
    just use an elbow....
    dont over enginerr anytghing
  18. Mar 14, 2012 at 9:00 AM
    #238
    acdronin
    He wants to go to copper before the meter, he still needs a union there right?
  19. Mar 14, 2012 at 9:02 AM
    #239
    brutalguyracing
    F.U> GUYZ
    broken mods
    you mean he wants to put a male adptor 3/4" ip x 3/4" copperand then sweat a valve on then the meter then another valve???
    or is he getting a new main pulled in in copper
  20. Mar 14, 2012 at 9:06 AM
    #240
    acdronin
    Galvi comes through the wall, not going to be replaced, galvi thrdxthrd elbow may or may not come off the incoming pipe, if not, leave it, thread galvi nipple from elbow to dia union, then brass nipple to nibco ball valve/nipple then meter and off to copper from there
