Ask a Plumber.
Discussion in 'Off-Topic Discussion' started by Rusty 06 4x4, Dec 27, 2011.
  1. Jun 11, 2012 at 6:47 AM
    #361
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Thats weird to me, never heard of the PRV being buried. Around here they are normally right by the water meter inside the house. I would think it it is close to there, cause the point is to reduce the pressure to the whole house. So it is placed where the water comes in. So thinking that way, it would have to be close to your meter somewhere, and if pressure is ok at meter, then guess its time to follow the pipe off the meter.
  2. Jun 11, 2012 at 6:49 AM
    #362
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This ^^^^
    The PRV should be accessable
  3. Jun 11, 2012 at 6:49 AM
    #363
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    I can see a drip coming from the bottom of the unit (it's sitting on some bricks :rolleyes:). Definitely not coming from the drain valve or the pressure release.
  4. Jun 11, 2012 at 6:50 AM
    #364
    acdronin
    acdronin Well-Known Member
    I'm not going to be able to hang out and chat on this one until much later tonite but if I read this correctly, the pressure was checked at the meter? How was this done exactly? Did they remove the meter and check the incoming pressure after the angle-stop valve?
    Just to be clear because a lot of folks confuse this one:
    Pressure (PSI), is the amount of pressure that is pushing the water through the pipes. There is static pressure (Where no water is actually moving through the pipes), and Dynamic (measured while water is moving through the pipes).
    Flow, (defined as gallons per minute or GPM), is the amount of water moving through the pipe.
    So if the static pressure was measured at the meter and then at the house, what are the two numbers they got? The most common way to measure house pressure is at a hose bib.
    If a pipe is restricted (damaged but not leaking), or is restricted with smaller diameter pipe, there will be no change in static pressure, it will read the same from after the meter clean through to the back yard. Are you confusing what you think is a lack of pressure with what is actually a lack of flow?
  5. Jun 11, 2012 at 6:51 AM
    #365
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    so why electric? what kinda heat u haz.....
    also i have herd good things about kenmore but have never installed one?
    i do mostly gas / oil
  6. Jun 11, 2012 at 6:52 AM
    #366
    acdronin
    Usually plumbing codes out here put the prv on at the house where the main comes in.
  7. Jun 11, 2012 at 6:52 AM
    #367
    OZ-T
    Peter North
    British Columbia
    John Woods are good electric tanks
  8. Jun 11, 2012 at 6:53 AM
    #368
    OZ-T
    Peter North
    British Columbia
    But buried ?
  9. Jun 11, 2012 at 6:55 AM
    #369
    acdronin
    not usually
  10. Jun 11, 2012 at 6:56 AM
    #370
    acdronin
    Maybe he could have a plumber yank the meter and run a camera up the main
  11. Jun 11, 2012 at 6:58 AM
    #371
    Enigmaaron
    PA
    1st gen superiority
    My house is purely electric. No gas lines, even in the street. The one that is there is a Kenmore and lasted about 16 years, seems pretty good. :notsure:
    Still runs fine and provides good heat, enough to take a shower with a washer going. Looks like it was a "10 year" unit (had a 10 year warranty).
  12. Jun 11, 2012 at 7:04 AM
    #372
    brutalguyracing
    F.U> GUYZ
    broken mods
    yea you got your moneys worth then.....esp. if u have well water.....
    u must live in the boonies:rolleyes:
    you have city sewers or cespool / leech field
  13. Jun 11, 2012 at 7:04 AM
    #373
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    The meter is by the street.
    The only thing between the meter and PRV is straight 1" pipe.
    The PRV and homeowner shutoff valve are accessible near house in a ground box.
    I'm just saying that's how it is around here and I had the same problem of not knowing where it was. I figure his would be similar to mine since we're in similar climates.
  14. Jun 11, 2012 at 7:09 AM
    #374
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Interesting, I guess cause the warmer climate. Never heard of a meter being by the street. our water comes in below the frost line, and meter is in basement of house, right where the water comes in.
  15. Jun 11, 2012 at 7:10 AM
    #375
    brutalguyracing
    F.U> GUYZ
    broken mods
    this ^^^^^^
  16. Jun 11, 2012 at 7:20 AM
    #376
    Enigmaaron
    PA
    1st gen superiority
    Well not my money (only been in the house 2.5 years) but yeah. And I do have well water although it's good enough I only need a sediment filter, but still I know it's rough on heaters/pipes. The previous owner swapped almost all of the plumbing out for cpvc, just a few bits left in the walls and for the outside hose spigots which is nice.
    Yes, I live in the boonies, I have a cesspool. Only thing running down our street is electric and cable/phone lines, all of which are buried.
  17. Jun 11, 2012 at 7:24 AM
    #377
    brutalguyracing
    F.U> GUYZ
    broken mods
    NICE WELL IF U NEED A HAND ITS $85 AN HOUR AND THAT INCLUDES TRAVEL TIME.......PAYMENTS ARE EXCEPTED IN BEERS AS WELL
  18. Jun 11, 2012 at 7:49 AM
    #378
    Lazylegs
    Lazylegs Well-Known Member
    Craig
    Southern Maryland, USA
    2011 Red Toyota AC Sold
    Tint (35%), a must. Step bars, Bull bar, Bull lights,4x4 light mod, Flip down 10" DVD player, De badged, Color match front emblem, color matched bumpers., black out tails, Cobra cb, Flashlight mod,bed-light mod,
    Why dont thye make toilet openings larger. For those Taco Bell dinners? That meat can't be good for me!
  19. Jun 11, 2012 at 8:02 AM
    #379
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    :laughing:
  20. Jun 11, 2012 at 8:54 AM
    #380
    Superdavert
    Superdavert Well-Known Member
    Dave
    Athens, Ga
    '09 TRD Sport DC SB
    MB Legacy wheels 285/70 17 BFG KO2s ProComp 2" leveling kit, Foglight anytime mod, Sockmonkey TRD Sport bedside decals, Extang Trifecta tonneau cover, Toyota bed extender, Aries black nerf bars, Pop & Lock
    The house is 15 years old.
    Three different plumbers said its a pressure issue. They all said its half of what it should be. They measure it on my side of the meter (which was ok) and the hose outlet (which was half the pressure).
