Ask a Plumber.
Discussion in 'Off-Topic Discussion' started by Rusty 06 4x4, Dec 27, 2011.
  1. Oct 5, 2012 at 6:33 PM
    #441
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Found this on HD, got good reviews from 3 users:
    Bosch 12-Volt Max Lithium Ion Optical Scope Kit
    Model # PS90-1A Internet # 202716948
    $191.00 /EA-Each
  2. Oct 5, 2012 at 6:34 PM
    #442
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Welcome. Let us know.
  3. Oct 5, 2012 at 6:36 PM
    #443
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    If you're cutting a big hole,look to see if its a strap holding the pipe where ticking is coming from. Insulate the pipe and strap over insulation.
  4. Oct 5, 2012 at 6:39 PM
    #444
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Got it. Found a $8 stethoscope at Walgreens...I am going to use it to narrow down the location.......actually can't wait to do this fix as the ticking is making me a mental case. :)
  5. Oct 5, 2012 at 6:50 PM
    #445
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I guess I'm a mental case with the hissing I hear all the time:D
  6. Oct 14, 2012 at 2:24 PM
    #446
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Well after getting my Furnace fixed, thank to everyone that helped with it! I have another weird one. I have a wall furnace(natural gas)with no blower. I believe I have a thermostat issue, when I turn up the heat I can hear the thermostat click which usually fires up the furnace but now nothing happens, I jumped the wires which I know is not a good idea but it did fire up the furnace. I replaced the thermostat with a new one but it's doing the same thing, any ideas what would make this happen?
  7. Oct 14, 2012 at 3:53 PM
    #447
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    I hope another plumber with more experience chimes in to help. I haven't worked on a wall furnace in ages. But I'm usually better in front of the problem,hands on.
  8. Oct 16, 2012 at 6:49 AM
    #448
    Geode
    Geode Well-Known Member
    Illinois
    09 4WD TRD
  9. Oct 17, 2012 at 2:33 AM
    #449
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    A little advice to anyone attempting to do their own plumbing. I have to do a repipe at a house today . The customer is a retired electrician. He remodeled his bathroom 20 years ago and lowered his copper manifolds in the slab. He has a slab leak in that bathroom.so now I have to bring new hot line overhead and a drop to each fixture and another shower since it was getting hot from manifold in slab.
    Ugh.
  10. Oct 17, 2012 at 4:06 AM
    #450
    Geode
    Illinois
    09 4WD TRD
    Was the copper for a radiant heat system I'm guessing?
  11. Oct 17, 2012 at 4:52 PM
    #451
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    No,we don't have that much need for it down here. He didn't know what he was doing.
    It was all the domestic hot to 2 lavatories and 2 showers. But he only had one slab leak,but since he had all the manifolds in concrete,all had to be replaced.:mad:
  12. Oct 18, 2012 at 6:55 AM
    #452
    Geode
    Illinois
    09 4WD TRD
    I can only imagine the weird things you see. My 100 year old house sure has had its share of hacked jobs. Slowly I'm getting it straightened out, or so I think ;)
  13. Oct 27, 2012 at 7:57 AM
    #453
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    I have a Symmons Temptrol handle in my shower. It has begun leaking out inside of the wall. I took it apart and replaced all the washers with a kit (twice) but it still is leaking. I'm thinking the whole control unit needs to be replaced, but can't figure out how that can be done through the small access hole behind the trim.
    Any advice? I've been trying to get a plumber to even answer the phone for about a month now (southern VT area)
  14. Oct 27, 2012 at 8:10 AM
    #454
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    what's behind that wall? Often times your shower valve will back up to a closet or something where you can cut a large hole in the drywall to replace the valve and then patch your hole afterwards. Pretty much the only way to do it shy of pulling tiles and doing it from the front. (more repair that way)
  15. Oct 27, 2012 at 8:16 AM
    #455
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Your typical thermostat is nothing more than an automatic switch triggered by temperature.
    If jumping the wires to the furnace caused it to turn on, then a working, properly wired thermostat should do the same.
    Can you disconnect the wires from the thermostat and check for continuity between the two terminals you are connecting to when the thermostat is calling for heat?
  16. Oct 27, 2012 at 12:29 PM
    #456
    AeroCooper
    NH
    The outdoors is behind the shower valve. It is a stand up shower with plastic walls and a 'glass' door. I'm thinking either pull the whole stall out or cut a bigger hole in the shower plastic wall and then figure out how to patch that back up. Neither option sounds fun.
  17. Oct 27, 2012 at 3:48 PM
    #457
    joes06tacoma
    Joe
    Central Coast, CA
    A wall furnace produces it's own, small amount of power measured in millivolts. Since we are only dealing with about half a volt of DC power, any small amount of resistance in the wiring or connections will produce a problem. This means no splices with wire nuts, if the wiring is spliced it has to be soldered. It also means you have to use a thermostat that is designed to switch millivolts, they will have lower contact resistance. A forced air unit will have a 24VAC power supply and is much more forgiving of crappy connections and thermostat contacts.
    Also check the pilot flame to make sure the pilot generator (thing with the wires coming out of it that's right next to the pilot) is fully surrounded by flame. The pilot may be dirty, clogged, or out of adjustment. The pilot generator may be weak. A healthy pilot generator puts out around 400-500 mV measured with a standard DC voltmeter. This is measured with no load (thermostat off). It will drop when the furnace is heating.
    Me thinks you have the wrong type of thermostat, or a weak pilot generator.
  18. Oct 27, 2012 at 4:08 PM
    #458
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    My dishwasher gets the worst smell after about 3 days. I have tried everything. I even rinse the plates before I put them in cause I thought maybe it was food that was causing the smell. We also recently had the kitchen re-done and ran a new supply line cause the kitchen guy though maybe the way the supply line was routed was causing it. Still getting the smell.
    Any ideas?
  19. Oct 27, 2012 at 4:18 PM
    #459
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Where does it drain to? Where its connected? Is there an anti syphon loop?
  20. Oct 27, 2012 at 4:28 PM
    #460
    90YotaPU
    Union County, NJ
    It drains to the sink drain which is right next to it. When he ran the new lines for the dishwasher, it did drape it (not sure if that's the right word) to create something like a P-trap for the gases.
