Ask a Plumber.
Discussion in 'Off-Topic Discussion' started by Rusty 06 4x4, Dec 27, 2011.
  1. May 7, 2013 at 11:51 PM
    #501
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    Doing a slab cut and moving the drain is the only proper way to do it. U gotta remember that a tub has a waste and overflow, not just a simple floor drain like a shower. I don't know about the plumbing in Texas but in AZ if it was built in the 60's you've got cast iron under the slab, possibly transitioning to clay outside the footprint. I'd be really surprised to ever see clay under a slab unless it was under an addition. Just my 2¢ hope it helps in some way.
  2. May 8, 2013 at 3:10 AM
    #502
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    San Antonio
  3. May 8, 2013 at 6:10 AM
    #503
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    I know I have cast iron in the walls just didn't know under the slab because I've been told I have clay going to the house. I really want to get a new bathroom for my wife before she delivers in July and I can do it all except for the drain moving. Why can't we have any TW members close, lol!
  4. May 8, 2013 at 7:05 AM
    #504
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Then ya have cast under house, clay in yard. Post pics. Where in Texas are you?
  5. May 8, 2013 at 3:33 PM
    #505
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    Nah too ugly right now! I'm in Texarkana. Where's the DIY network's Bath Crashers when you need them?
  6. May 8, 2013 at 4:26 PM
    #506
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Well then,you're going to have to bite the bullit and get someone to do the drain. It'll speed things up. And when in wall check thevalve if its a true shower valve or tub and sh valve with tub spout plugged.
  7. May 8, 2013 at 4:27 PM
    #507
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Check your local paper for a one truck plumbing company. It'll save ya money. Or grab the phone book,and be ready to grab ya ankles:)
  8. May 8, 2013 at 5:52 PM
    #508
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    Give me some price estimates I should be looking for to remove the poured pan and cut the slab to relocate the drain. I can do the rest.
  9. May 8, 2013 at 6:10 PM
    #509
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    If the trap is right at drain opening ,you can just reroute riser over for tub,if trap is deep enough.2-1 1/2" 90s and some pipe. Should only take a few hours to move drain.
  10. Jun 21, 2013 at 4:13 AM
    #510
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Do you do boilers ? I am going to switch from oil to gas to save $$. I do have questions if you have answers. Thanks for any help. Curious George
  11. Jul 10, 2013 at 8:10 AM
    #511
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I have a plumbing question if this thread is still existent.
  12. Jul 10, 2013 at 8:13 AM
    #512
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    14
    That's the best answer I could come up with with the information that was given.
  13. Jul 10, 2013 at 8:16 AM
    #513
    JLink
    Josh
    Ocean, NJ
    Haha well I don't see how that's the answer, but ill share my situation in a minute. Photos are being sent to live
    Edit:
    Ok I can't post the pics on here with my phone, so here's the link to the first picture on Tw live. The next post down should be my second picture and the situation I'm hoping to resolve.
    http://www.tacomaworld.com/forum/off-topic-discussion/38939-tw-live-12486.html#post7142529
  14. Jul 10, 2013 at 9:10 AM
    #514
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    Wow. That's quite the conglomeration of fittings you have there.
    Most of that is not legal under any code I'm familiar with.
    The black pipe you want to drain into is too high to serve as a drain, but then again so is the pipe it's presently draining into.
    Basically, your building drain is too high to allow anything in the basement to be gravity drained into it. A legal installation would consist of an ejector pit with it's discharge pumped up into the building drain.
    That being said, if you want to drain your washer into the black pipe you should know that....
    A. The pipe is too small (it needs to be 2")
    B. The pipe is too high (your washer has to pump the water all the way up there and you'll likely have soaking wet loads of laundry as if the spin cycle never happened)
    C. A washing machine should really have about a 24" stand pipe above its p-trap because of the suds. This would make your discharge point even higher.
    In a nutshell, what I'm trying to say is that you've got quite the plumbing abortion going on here and a licensed plumber would have to reconfigure everything and charge you a lot of money to fix it.
    If it's working as it is now, you are not going to improve the situation by doing what you want to.
    I'm sure this isn't the kind of thing you wanted to hear, but it's the truth.
  15. Jul 10, 2013 at 6:39 PM
    #515
    JLink
    Josh
    Ocean, NJ
    oh its cool.. aparently according to all the local plumbers it costs $4000 to replace a water heater, so Im aware all plumbers hate working :D
    my washer can pump to a maximum height of 96". I will be installing a pedestal under the washer, raising it an additional 14", making the point I'll be pumping too roughly around 5' above the bottom of the washer.
    thanks for the help though... or whatever you want to call it... :notsure:
    :D
  16. Jul 10, 2013 at 6:48 PM
    #516
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    truth....
    standpipe code here is min 18"
    and he said the black drain is 2"
  17. Jan 18, 2014 at 5:12 PM
    #517
    Rusty 06 4x4
    Rusty 06 4x4 [OP] NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    nice to see fellow TW plumbers helping with this!
  18. Jan 25, 2014 at 11:46 AM
    #518
    Vann
    Vann Well-Known Member
    Garth
    Weisenburg, PA
    '04 x-cab 4x4, 2.7 5sp. "The Black Pearl"
    stock
    IMHO moving the washer to the 1st floor with a proper standpipe (2") tied in before the house trap might be the simplest solution.
  19. Jul 3, 2014 at 1:48 PM
    #519
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    Anyone know where to find those push-button hose spigots that you see at a beach or public park?
    Trying to get the water turned back on at our local dog park (85+ and no water available due to vandals turning it on and flooding it at night) but the parks and rec manager won't budge. If we can take a solution and possible donations from us that use it regularly, we are hoping the guy will reconsider.
  20. Jul 3, 2014 at 4:22 PM
    #520
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    http://www.plumbingsupply.com/chicagometeringfaucets.html
