Ask a Plumber.
Discussion in 'Off-Topic Discussion' started by Rusty 06 4x4, Dec 27, 2011.
  1. Dec 28, 2011 at 2:48 PM
    #141
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    Questions:
    1. installing new shower arm... using teflon tape, i bought the "pink" tape because it's a little thicker?, how many times can i wrap the tape around the threads? i ask because it seems to be a rather loose fit, and you can only get a fixed number of turns in to have it aligned properly..
    2. new toilet... i need to install a new toilet after my bathroom remodel (which i did 3 yrs ago!). i also installed new flange in floor (PVC, had to cut old one off, glue new one in), i used brass screws (there are 6 holes in flange) to secure to floor, but i broke one of them, ..i've got four screws holding it in - is this ok? also, any recommendations for toilet brand/etc? ...was thinking about an american standard cadet 3/4
  2. Dec 28, 2011 at 2:52 PM
    #142
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Is there a standard amount of asscrack that must be showing at all times while working on drains?
  3. Dec 28, 2011 at 2:53 PM
    #143
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    1, I wrap it 3-5 times and on 90% of threaded pipe connections I use teflon first then pipe dope as well. Havent had one leak yet.
    2, you should be OK. The glue is what prevents it from leaking, the screws only hold it to the subfloor.
  4. Dec 28, 2011 at 2:55 PM
    #144
    05RedTaco
    Tony
    Scottsdale
    Yes about an inch to inch and half.
  5. Dec 28, 2011 at 2:55 PM
    #145
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Is that rate dependent?
  6. Dec 28, 2011 at 2:58 PM
    #146
    05RedTaco
    Tony
    Scottsdale
    Yes cheap plumbers will show more butt crack then expensive plumbers.
  7. Dec 28, 2011 at 3:19 PM
    #147
    Steezyskis
    Steezyskis I ski I work I'm rad
    Spencer
    Lake Tahoe (west shore)
    Black 05 DC 4x4 sport SB
    Tuff country front bumper, Walker Evans 2.5 coilovers, Allpro 3" rear leafs with 5100s and an Allpro U-bolt flip kit, K&N CAI, 16x8 Raceline raptor wheels wrapped with 285 Toyo ATs, Sockmonkey bed decals, Softtopper camper shell, half debadged with black painted tacoma emblems, B.A.M.F rock sliders, GT covers, BHLM, PIAA lights and more to come.
  8. Dec 28, 2011 at 3:23 PM
    #148
    Steezyskis
    Spencer
    Aww what did I do wrong? :notsure:
  9. Dec 28, 2011 at 3:27 PM
    #149
    Steezyskis
    Spencer
    Damn iphone. It's worked before.
  10. Dec 28, 2011 at 3:48 PM
    #150
    wileyC
    Centerville, OH
    thanks!
    i didn't know i could use dope w/ the tape!
  11. Dec 28, 2011 at 4:47 PM
    #151
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    My hot water in my master bath takes forever to get warm. The thermostat on the heater is just below the highest setting. What can I do to get hot water up there quicker?
  12. Dec 28, 2011 at 4:48 PM
    #152
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Opps, two story 2.5 bath, the heater is in the garage and the master bath is up a floor and about 50' back.
  13. Dec 28, 2011 at 4:52 PM
    #153
    Rusty 06 4x4
    Rusty 06 4x4 [OP] NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    the only way to fix that would be to install a recirculating pump so that the hot water travels from the furthest point in the house to the water heater and it is almost instantaneous hot into each faucet other than that its just a waiting game because the water in the pipe from the fixture to the water heater has cooled down and has to travel the distance and most faucets are a 3/8 inch incoming line and the supply is 3/4 inch.. hope that helps
  14. Dec 28, 2011 at 5:26 PM
    #154
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Thanks. Now the fun begins.
  15. Dec 28, 2011 at 5:27 PM
    #155
    Rusty 06 4x4
    Rusty
    West Georgia
    if you have any ?'s let me know
  16. Dec 28, 2011 at 5:37 PM
    #156
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Do you guys insulate your hot water lines ?
  17. Dec 28, 2011 at 5:40 PM
    #157
    Rusty 06 4x4
    Rusty
    West Georgia
    no not me It does not get cold enough here my basement has heat so no need to
  18. Dec 28, 2011 at 5:41 PM
    #158
    Steezyskis
    Spencer
    Hot and cold mainly for freeze protection. And to help the water be a little warmer going into the water heater so it doesn't have to work as hard.
  19. Dec 28, 2011 at 5:42 PM
    #159
    OZ-T
    Peter North
    British Columbia
    I insulate the hot water lines , especially if using a recirc line
  20. Dec 28, 2011 at 5:45 PM
    #160
    Rusty 06 4x4
    Rusty
    West Georgia
    yeah If I had one of those I would for sure
