Ask the Apple Nerd!
Discussion in 'Technology' started by BBiggs, Nov 2, 2010.
  1. Nov 6, 2012 at 5:29 AM
    #601
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    I have an iPhone 4S working through bluegrass cellular. (A carrier that DOES NOT use SIM cards) I plan on dropping bluegrass and going to AT&T (A carrier that DOES use SIM cards) What do I need to do to my iPhone, if anything?
  2. Nov 6, 2012 at 5:42 AM
    #602
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Sell it and get an iPhone 5, you can still get good money for a 4s, especially if you might not have upgraded it to iOS6.
    AT&T requires a phone with a SIM card to function on the HSPA network, Bluegrass does not require a SIM card because it functions on the CDMA cell network. I think I have that right, someone chime in if I have that backwards.
  3. Nov 6, 2012 at 6:32 AM
    #603
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    That is correct. My wife works as a sales/service rep for AT&T. According to her, if Bluegrass is a CDMA network the phone will not work with AT&T's network because the internals are different. If you remember, Verizon (CDMA) had to wait to get their version of the iphone so that would work with their network. If you were coming from TMobile, it would have worked. Your only option is to get a new phone. The 5 is $199-$299, the 4S is $99 and the 4 is $0.99.
  4. Nov 6, 2012 at 7:08 AM
    #604
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Haahaahaa the 4 is .99 cents!!
  5. Nov 6, 2012 at 8:17 AM
    #605
    DanglingFury
    Keith
    2006 4Runner 4x4
    damn... well. iPhone 5 it is....
  6. Nov 6, 2012 at 8:20 AM
    #606
    Mrogers33
    Mrogers33 The way is open, the time is now
    Columbus, OH
    03 doublecab 4x4 grocery getter
    Here's a question. Seen any major flukes right out of the box for the Iphone5 or accessories? My charger broke on the very first use. The USB slot was so tight or stuck that the covering popped right off! Obviously I wasn't going to pull by the wire. The Apple store replaced free of charge no questions asked. Pic attached of the defect.
  7. Nov 6, 2012 at 8:22 AM
    #607
    SACTOWN
    Greg
    Good choice.
  8. Nov 6, 2012 at 9:05 AM
    #608
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    Question: how do i turn off wifi search once im connected to my network, i know what i want to connect to and its consistently searching for other networks
  9. Nov 6, 2012 at 9:09 AM
    #609
    Richard Cranium
    Richard Cranium The lice...they hate the sugar
    Ted
    Omaha, NE
    2013 Raven FR-S
    Forever sideways and smiling :D
    Once you're connected, you're connected it should stop searching. The exception to this would be if, for some reason, your wifi connection was constantly dropping while needing a data connection, in which case it would ask to join another network.
  10. Nov 6, 2012 at 9:12 AM
    #610
    FamouzStarz
    21 TRD PRO
    its a steady connection, i can connect to 3 access points from my office right now and it still says looking for networks, i know this has to be taxing my batt and i just want it to stop :) even if i plug into the network it says the same.
  11. Nov 6, 2012 at 9:22 AM
    #611
    hendooman
    Jeff
    KC
    Settings>wi fi> turn OFF ask to join networks. It would then stop searching for other networks unless you ask it to manually
  12. Nov 6, 2012 at 9:24 AM
    #612
    FamouzStarz
    21 TRD PRO
    already have that checked off, i only have it set to remember 1 wifi access point now which i am already connected it to. but still says looking for other networks. its quite annoying actually :mad:
  13. Nov 6, 2012 at 9:28 AM
    #613
    hendooman
    Jeff
    KC
    where does it say that? does it only say that when you go into settings and hit wi fi? If so that is normal, it is going to look for other services when you go into wifi settings. When you are locked in to a wifi network on a normal screen is it giving you a pop up that says, "do you want to join x network"
    If so I sense something is wrong. My try a hard reset and just see if it is stuck open all the time. When in doubt reboot!
  14. Nov 6, 2012 at 9:35 AM
    #614
    FamouzStarz
    21 TRD PRO
    so upon boot airport will connect to my wifi xxxxname
    i have the box unchecked to join other networks
    i removed all other networks that i have previously joined
    yet when i click on the wifi icon, it shows other networks available
    and consistently says looking for networks
  15. Nov 6, 2012 at 9:42 AM
    #615
    CDSurfPhotography
    CDSurfPhotography Well-Known Member
    Cody
    San Diego
    06 PreRunner
    Recently my MacBook charger has been messing up, and I'm not sure if anyone else has had this problem. When I go to plug my computer in the orange light that should come on never comes on and on my screen it just says Not Charging. About 15% of the time it will charge but the other times it won't do anything. This is really starting to annoy me, because I plug my computer in at night wake up in the morning and my computer is almost dead just like I left it at night.
  16. Nov 6, 2012 at 9:42 AM
    #616
    hendooman
    Jeff
    KC
    that is fine, when you are out of the settings it is not continuing to search, if it is not giving you a pop up to join another network you are fine.
  17. Nov 6, 2012 at 11:23 AM
    #617
    Richard Cranium
    Ted
    Omaha, NE
    2013 Raven FR-S
    This reminds me of Demitri Martin...he has a joke that goes "I'm a washing machine, not a show-you-how-I-do-it machine." Sounds to me as if everything is functioning as normal...IMO, it's only looking for other connections because you're looking at the connections tab.
  18. Nov 6, 2012 at 12:31 PM
    #618
    FamouzStarz
    21 TRD PRO
    true but seems to me it will continue to search for other signals maybe im still in my pc frame of mind
    apple so simple its complicated :D
  19. Nov 6, 2012 at 12:35 PM
    #619
    hendooman
    Jeff
    KC
    Right, it is like is the light in the fridge on when it is closed....are you having battery issues? I posted some battery tips a few pages back. See if any of these things might help you....
    One of the things that I have read to help battery life is to do a complete new phone restore. When you hook your phone to itunes and hit restore, when it is finished downloading the software it will ask if you want to set your phone up as new or restore from back up. Restore the phone from new. It will reset all your settings but it did help my phone, and lots of other folks who were experiencing battery life problems.
    Another tip is to go to settings>privacy>location services>system services, and make sure all those features are turned to off.
    And one more settings>general>about>advertising>turn on limit ad tracking
    The two tips above are new features for iOS6, and there has been a lot of discussion on mac forums that these are causing some constant searching and synching, therefore using much needed battery.
  20. Nov 6, 2012 at 12:42 PM
    #620
    FamouzStarz
    21 TRD PRO
    ugh its on my macbook not an eyephone lol
