Ask the Apple Nerd!
Discussion in 'Technology' started by BBiggs, Nov 2, 2010.
  1. Jul 7, 2013 at 9:06 AM
    #981
    mltaylo3
    mltaylo3 Army Retired
    Dallas, TX
    14 Pre-runner DCSB TX Edition MGM
    HID foglights, PIAA halogens, extang trifold tonneau, weathertech floormats, Alpine sound system
    A: Have you used this disk drive with this laptop before? I had one (USB SuperDrive that wouldn't work for certain models)
    Negative, but note, I am a little confused by your comment. Mine is an internal drive, you reference a usb drive above.
    B: can you get the install disk to boot at all?
    Yes, but when it is time to install snow leopard, hard drive is not listed. However, I can use the ubcd (live cd) to boot and format the disk--it sees the disk just fine. I've even copied a few files for testing purposes--all successful. To my mind, this indicates the hardware is good.
    C: model hdd?[/QUOTE]
    Same as original I believe, but I will have to go back in and check. It has that zif proprietary interface. My options were limited for this reason
  2. Jul 7, 2013 at 9:14 AM
    #982
    mltaylo3
    Dallas, TX
    Replaced hdd with hdd. That proprietary zif socket really didn't leave me many options.
  3. Jul 7, 2013 at 9:14 AM
    #983
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This may have been already asked, however, at 52 pages I don't feel like spending all day sifting through questions and answers that may not even be here..
    2011 mid year edition Macbook Pro, all is well minus the click function on the mouse, lately it has been less responsive for lack of a better word. It takes several tries to click on links, or anything else in general and actually get a result from it. Anyone know why?
  4. Jul 7, 2013 at 9:35 AM
    #984
    mltaylo3
    Dallas, TX
    Samsung HS081HA, 80GB, 3600 rpm.
  5. Jul 7, 2013 at 10:51 AM
    #985
    Gaberm
    Gaberm Apple Technician
    Gabe
    Quad Cities - Iowa
    Limited Barcelona Red Metallic
    roof rack, Step Rails, BAK Flip F1, Pop & Lock Electronic
    Your battery is swelling up or the set screw for the trackpad had loosened up. Try removing the bottom and removing the battery, if the click function is restored then its time to get a new battery.
    If the set screw loosened up you just need to slightly tighten it up.
    http://www.ifixit.com/Guide/Install...Unibody+Early+2011+Battery+Replacement/5116/1
  6. Jul 7, 2013 at 10:52 AM
    #986
    Gaberm
    Gabe
    Quad Cities - Iowa
    Shouldn't have any issues with that drive. Sounds like to may have an issue with the drive it self or the main logic board is failing.
  7. Jul 7, 2013 at 11:08 AM
    #987
    Gaberm
    Gabe
    Quad Cities - Iowa
    People that make fun of mac are doing so because they are just envious :D:D
  8. Jul 7, 2013 at 11:18 AM
    #988
    justPLANElane
    justPLANElane Active Member
    Lane
    Dallas
    Trd off road dcsb
    Hi there, I have a mid 2010 mac book pro and i hear there is a way to add a second hard drive by replacing the optical drive. Is that something you would recomend that I could tackle on my own or should i have someone do it for me? Keep in mind i have never replaced a hard drive on any computer.
    I'm also looking at replacing the 2 2 gig sdram with 2 4 gigs...is that pretty easy??
    thanks for the input :pccoffee:
  9. Jul 7, 2013 at 11:19 AM
    #989
    bigef12
    bigef12 Well-Known Member
    Eric
    Chattanooga, TN
    2004 4Runner SR5 4x4 V6
    Removed that stupid "Sport Bumper Trim"
    Don't format the disk unless you use Disk utility from the install disk.
  10. Jul 7, 2013 at 11:19 AM
    #990
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I was afraid you would say that. I read about the battery swelling up some. I leave it plugged in half the time so maybe I should ditch the battery altogether and just operate it via cord.
    Either way, I'll pull it apart in a little bit and check it out, thanks for the link! I am no stranger to dismantling this thing however, especially after the HD exchange :)
  11. Jul 7, 2013 at 11:23 AM
    #991
    bigef12
    Eric
    Chattanooga, TN
    Need to know a little bit to do the optical drive swap. Requires aftermarket hat drive caddy.
    Following link for RAM upgrade instructions.
    http://support.apple.com/kb/ht1270
  12. Jul 7, 2013 at 11:55 AM
    #992
    Gaberm
    Gabe
    Quad Cities - Iowa
  13. Jul 7, 2013 at 12:20 PM
    #993
    mltaylo3
    Dallas, TX
    Disk utility does not list the drive.
  14. Jul 7, 2013 at 12:32 PM
    #994
    mltaylo3
    Dallas, TX
    Apple nerds... Don't beat me up for this, but I find it ironic that a Windows based disc (UBCD) can see a drive on a MBA that SL cannot. Linux can as well (gparted live cd). What's up with that? I believe I've answered all the questions...
  15. Jul 7, 2013 at 12:45 PM
    #995
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Shoot, I think the battery is indeed swollen slightly, the mouse seems to be responding to clicks perfectly now that I am running it without a battery.
  16. Jul 7, 2013 at 1:09 PM
    #996
    Gaberm
    Gabe
    Quad Cities - Iowa
    Have you gone under SL disk utility under the menu bar and partitioned the drive as a Macintosh journaled disk yet? You can not I stall until you do.
  17. Jul 7, 2013 at 1:37 PM
    #997
    mltaylo3
    Dallas, TX
    Tried, but the disk is not listed for SL install disc. During initial troubleshooting, I formatted as hfs+journaled, single partition via ubcd however. (after a few unsuccessful install attempts, Google said SL may not see raw disks, and gparted live cd said the disk was raw format out of the box).
  18. Jul 7, 2013 at 4:51 PM
    #998
    Gaberm
    Gabe
    Quad Cities - Iowa
    Never personally had that problem. ou can format it as NTFS or Fat 32 and SL should see the drive. It will not let you install, but then you can use Disk Utility to format as journaled
  19. Jul 7, 2013 at 5:13 PM
    #999
    mltaylo3
    Dallas, TX
    Will give it a try and report results
  20. Jul 25, 2013 at 2:03 PM
    #1000
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    i have my MBP with 10.8.4 hooked up to our sony TV via thunderbolt (?) to hdmi adapter with hdmi going to the TV, i have the display set to not mirror, and every thing is working fine, but is their a way to get safari on the mac screen and iTunes visualizer on the tv? whenever i change screens on my mac it changes screens on the TV.
