Ask the Apple Nerd!
Discussion in 'Technology' started by BBiggs, Nov 2, 2010.
  1. Dec 9, 2010 at 10:14 PM
    #141
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    for vista it would be the clipboard if it follows Microsoft standards. If you are totally out of luck and do a ton of screenshots, SnagIt is the best program in the world.
  2. Dec 9, 2010 at 10:17 PM
    #142
    AZtacoma05
    AZtacoma05 Well-Known Member
    Austin, TX
    17 DCSB TRD Off Road
    I tried pasting into paint and PS... I don't do a TON of screenshots but ill check it out! thanks
  3. Dec 9, 2010 at 10:27 PM
    #143
    Dem1
    Dem1 Well-Known Member
    Demi
    California
    06 Tacoma TRD
    Leer Camper, Thule racks, Cobra Cb
    Im both a Mac guy and a PC. Use my mac for torrents and movie/ media editing. Then I have PC for all the other important shit.
  4. Dec 9, 2010 at 11:07 PM
    #144
    AZtacoma05
    Austin, TX
    Exactly.. plus I have Adobe master collection for windows and rhino will only run on pc (for now) so i duel boot
  5. Dec 12, 2010 at 6:01 PM
    #145
    Chickenmunga
    Keizer, Oregon
    It's quite possible. You have to check if the computer will support the upgrade for starters (you may have it maxed out with equal or larger RAM sticks as is). I don't think manufacturers do this anymore, but it used to be that some motherboards had a cap on how much RAM could be added as well.
    This is a fairly easy question you can take to the Genius Bar and get a free answer.
    Note there's two other things worth mentioning
    1. Your computer might be heavily fragmented, the hard drive is really full, or you have a bunch of bloaty programs running. If you have a full drive, delete some stuff; if you are running lots of programs try closing them or even try restarting the computer.
    2. At some point computers top out on how fast they can go. If you have an older or lower end computer, it may be time to upgrade, as hard drives, graphics cards, and processors also play into a speed consideration.
  6. Dec 13, 2010 at 8:26 AM
    #146
    Chickenmunga
    Keizer, Oregon
    found a tool for you to try.
    m
    Oops, forgot that was you. If the full backup doesn't work you might just go about moving important files individually and move on with life. Really hard, but it soon becomes the only option.
    Some would say that you don't need to. In fact, Apple says that it's unnecessary based on how the OS is built to handle file fragmentation, and, "Hard disk capacity is generally much greater now than a few years ago. With more free space available, the file system doesn't need to fill up every "nook and cranny."" However, I don't believe this too much.
    Even if they do a good job with file fragmentation, it doesn't sound like they care about disk fragmentation (where the files are stored on the HDD). A heavily fragmented drive is slow because the read head on the HDD has to physically move greater distances. Additionally, bigger hard drives means more area to search.
    To do defragmentation and other tasks, read through this article
  7. Dec 13, 2010 at 6:25 PM
    #147
    Chickenmunga
    Keizer, Oregon
    Ah, sorry that the prog didn't run. I was doubtful it would.
    Cleaning up files and defragging is seperate topics. Imagine a vinyl record and you managed to 'erase' the second and 4th song. When you wanted to play the record, you would have to play the first song, then pick up the needle and move it to the third song, etc. It would be much easier if you could somehow push the all the songs together, right? That's what defragmenting does - HDDs are much the same, just that they use magnetic platters.
    I should also mention that you only really need defragmenting on a drive that's been regularly kept at max capacity, you won't see as much of a change on near empty drives. Also if you buy a program don't let it do auto defrags, it will really kill performance. From the looks of it, iDefrag is your best choice.
    My advice based on what you are doing is this:
    1. Once you get the new HDD in, give it another test to see how pictures load and edit. If it's still going slow toss in the extra ram.
    2. Once you have the new drive in, no need to worry about the defrag unless you are nearing the full mark again or working with really large files continuously.
  8. Dec 13, 2010 at 8:06 PM
    #148
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    whats growl? i have an update for it :p
  9. Dec 13, 2010 at 8:17 PM
    #149
    bromagen25
    bromagen25 Well-Known Member
    Stock
    Rear Breather
    you know anything on the ipad 3g?
  10. Dec 13, 2010 at 8:28 PM
    #150
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    yeah its pissing me off
  11. Dec 16, 2010 at 12:23 PM
    #151
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    when will steve jobs get off his high horse and allow adobe to build a product to support flash on the ipad, etc???
    not a serious question:D
  12. Dec 20, 2010 at 5:40 PM
    #152
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    what program do you guys use to rip .avi's to mpg4 or .mov?
  13. Dec 20, 2010 at 6:35 PM
    #153
    MUDFISH
    MUDFISH Well-Known Member
    Syracuse
    12 Double Cab SR5
    I use Visual Hub, and love it...
    There is also Handbrake, Wondershare, and Toast...
  14. Dec 20, 2010 at 6:49 PM
    #154
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Handbrake works great, MacTheRipper is good also.
  15. Dec 20, 2010 at 7:00 PM
    #155
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    Are these pc programs? I dont have mac...
  16. Dec 25, 2010 at 12:33 PM
    #156
    BBiggs
    BBiggs [OP] Well-Known Member
    Brent
    Canada
    05 SR5 Access Cab
    I just got it!
    Flash is on its way out the door. HTML5 is on its way in. Not right away, it'll still be several years before flash is phased out completely, but as compared to even just a couple years ago, flash is already considerably less popular. It's still a cheap alternative for small companies to make flashy websites, but other than that I don't see much point to keeping it around. HTML5 video is far superior.
    Handbrake is what I use, it works the best, a bit confusing maybe at first but all the options you'd want are included.
    Handbrake has a PC version I think.
  17. Dec 25, 2010 at 4:13 PM
    #157
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    handbreak is the best.
    Also I bought a Ipad for my grandpa but on the GPS it says I am in england and Im pretty sure im in california. On my moms ipad it puts me where I actually am, but the other one goes to the same spot in europe every time. Ive tried updating it turning it off and everyhing i can think of.
  18. Dec 28, 2010 at 3:05 PM
    #158
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Alright Apple Nerd, need you to solve this.
    I want to record Sirius radio on NYE. I used to have a program on my PC that could do this and cannot remember the name. Do you know any OSX programs that will allow you to record streaming internet radio?
    Help.
  19. Dec 28, 2010 at 6:46 PM
    #159
    zeroendless
    zeroendless Well-Known Member
    Dallas, TX
    Stock
    You are so confused about standards and have no clue what you are taking about.
  20. Dec 29, 2010 at 6:42 AM
    #160
    hendooman
    Jeff
    KC
