Ask the Electrician
Discussion in 'Off-Topic Discussion' started by Alexb03, Jan 6, 2012.
  1. Jan 6, 2012 at 5:59 PM
    Alexb03
    Alexb03 [OP] Well-Known Member
    Alex
    New Mexico
    06 Tacoma Double cab
    3" lift, 285/75/16, navigation,
    So we have ask the plumber, how bout a ask the electrician. Im a licensed electrician and I know there are more on this site. If you have any electrical questions post em and ill do what I can to help out. Anyone else that is an electrician send a post so everyone knows. Hope this helps some people and save you some money!
  2. Jan 6, 2012 at 6:03 PM
    Alexb03
    Alex
    New Mexico
    I wouldnt try it! Electricity is not something to mess with! but as long as your not grounded you should be fine!
  3. Jan 6, 2012 at 6:08 PM
    Alexb03
    Alex
    New Mexico
    it will trip the breaker if everything working right and you will get shocked.
  4. Jan 6, 2012 at 6:11 PM
    sean266
    sean266 Mr. Clean Moderator
    Let him have this thread man. He's trying to help others out
  5. Jan 6, 2012 at 6:24 PM
    Alexb03
    Alex
    New Mexico
    electrical tape is not a good insulator so you can still get shocked.... so any real question on projects or something not working right in the house.
  6. Jan 6, 2012 at 6:26 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Even if you're not grounded, you don't want to complete a circuit across your chest cavity: i.e. one wire (or fork, whatever) in each hand.
  7. Jan 6, 2012 at 6:28 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Where online can I order a new mogul base socket for a 50 year old lamp?
  8. Jan 6, 2012 at 6:28 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    i had low voltage halogens installed in my living room. after a year or so, one of them isn't working anymore, even though i've replaced the bulb. what am i looking at to repair this? can i do it myself? i am electrically challenged.
    also, i have an old house with only 100 amp service. sometimes when the dryer is running, some lights in the basement are on, and someone is using a particular outlet, it will trip one of the circuits in the panel box and the lights go out . is there an easy fix for this?
    thanks.
  9. Jan 6, 2012 at 6:41 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    96 FZJ80
    OME, ARB, TJM
    Where was this thread a month ago???? I got it figured out now, no thanks to the local electrician.
  10. Jan 6, 2012 at 6:46 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Where were you a couple of weeks ago when I needed an electricians help? ;)
  11. Jan 6, 2012 at 7:46 PM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    I was in the garage telling you to check the breaker. ;)
    I'm a Red Seal Journeyman Electrician, going for my Masters in a few months.
  12. Jan 6, 2012 at 8:54 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    What causes a grounding loop in a residential wiring system ?
    When my fridge turns on I can hear a cyclic hum in my subwoofer .
    They are on seperate dedicated circuits , and on different phases .
    The only thing they have in common is they are both in my generator sub panel .
  13. Jan 6, 2012 at 9:02 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    harmonics maybe? :notsure:
  14. Jan 6, 2012 at 9:13 PM
    OZ-T
    Peter North
    British Columbia
    How do you mean ?
  15. Jan 6, 2012 at 9:19 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    certain types of loads produce harmonics, but its very rare on houses, its more common on industrial type loads, so I'm not really sure that is your problem, I could be way off....
    A bit of info about harmonics here
    http://www.cpccorp.com/harmonic.htm
  16. Jan 6, 2012 at 9:27 PM
    OZ-T
    Peter North
    British Columbia
    Thanks , I'll check that link out
    So basically , the fridge compressor would be causing the harmonic for some reason ?
  17. Jan 6, 2012 at 9:30 PM
    B ryan
    B ryan Well-Known Member
    Bryan
    Washington
    '00 3.4 sr5 4wd
    K&N intake, Flow series exhaust, bfg all-terrains, Line-X bed liner, 2.5'' leveling kit, diff drop(just to be safe), hard wired inverter, Delta tool box, high lift mounted in bed, Jerry can mount for in the bed, spidertrax wheel spacers, all-pro rear bumper, gray wire mod
    Hey man I do electrical work. you should go try out that paper clip idea and let us all know how it goes. But be sure to do it in your bathroom or kitchen outlets. (just joking, don't do this) I got a laugh from your comments though. Sounds like the thoughts of a 7 year old. :)
  18. Jan 6, 2012 at 9:31 PM
    StaticFilter
    StaticFilter Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
    I'm also an electrician, mostly commercial but residential sidejobs aplenty... subbed to help
  19. Jan 6, 2012 at 9:35 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    If I was right then yes, but honestly I'm shooting blind here, I would think its rare for a fridge to do that, I think they mostly use capacitor start - type of induction motors.
    If you turn off everything or mostly everything in the house, does it still happen?
  20. Jan 6, 2012 at 9:36 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    I WORK WITH 480V 3 PHASE AND 240V 3 PHASE EVERYDAY. BEEN SHOCKED BY 110 PRETTY GOOD BUT NOT ANYTHING HIGHER.
