Ask the Grill guy!
Discussion in 'HomerTaco' started by HomerTaco, Feb 21, 2013.
  1. Feb 21, 2013 at 6:38 PM
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Go ahead! Got a Grill question? Post it up here & I'll do my best to assist. :D
  2. Feb 21, 2013 at 6:41 PM
    Large
    Large Red
    How do I get my grill up to temp faster :cool:
    Joking, do you have the hook up on getting them painted?
  3. Feb 21, 2013 at 6:43 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    sub'd.
    Since a certain someone, who shall not be named, isn't making 2012 satoshi's :D I'll be starting mine soon and will def have some questions!
  4. Feb 21, 2013 at 6:43 PM
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    Why you no make 98-00 satoshi???? :anonymous:
    :p :D just kidding!!
  5. Feb 21, 2013 at 6:43 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I have mine done by a Pro Body shop but I've seen some pretty good DIY paint jobs.
    I don't have the patience for it but for anyone who is interested this website has everything you need to do a color match paint job:
    www.paintscratch.com
    :D
  6. Feb 21, 2013 at 6:44 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Painting.
    Best paint/primer brand?
    How many coats?
    Tips to help make the paint last longer under various conditions/temperature.
    Thanks!
  7. Feb 21, 2013 at 6:45 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I am currently working on a mesh-only insert option for the 2012.
    I have not forgotten you guys.;)
  8. Feb 21, 2013 at 6:46 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Honestly I had a very difficult time with the properties of the thermoplastic used on that year grill. It did not agree with my process and was very difficult to form.
    I did one for MTgirl and that was it. :eek:
    I simply don't have the time to really take on more work either. :(
  9. Feb 21, 2013 at 6:51 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    Yea I've asked you this before but just making trouble... :p
    Anywho, I'm planning on getting some mesh from you sometime before this summer. Might try to tackle this project (finally). Although I don't think I like the deep dish look. How does one go about make it more of a shallower mount, but not necessarily "flush"? Do you just cut the inside of the grille in closer to the front so the mesh rests on it closer?
  10. Feb 21, 2013 at 6:51 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    If you are referring to how I do the inner surrounds the key is prep.
    Even if it is still a factory smooth surface I sand with 220 grit and prime with Rustoleum Filler Primer. cleaning with an air gun then wiping down with a tack cloth is a must! Three coats of flat black & it's all set to assemble.
    As far as temp - I heat up my shop nowadays just to be able to paint!
    As far as durability to the end user in extreme temps - I have had no complaints.
    I've shipped grills to all kinds of climates. :eek:
  11. Feb 21, 2013 at 6:52 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    You got it. ;)
  12. Feb 21, 2013 at 6:53 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    Awesome! Thanks, :homer:!!
  13. Feb 21, 2013 at 6:54 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    My grill is cold. Paint doesn't react to the cold in my experience. And we're talking well below zero temps a lot of the time.
    Speaking of that Craig I should have pics of it all very soon. It's at the paint shop finally :woot:
  14. Feb 21, 2013 at 6:55 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Thanks. My first paint job hasnt lasted as long i thought. The white paint is starting to stain from all the bugs and weather that its been exposed to. And no matter how much i wash it, its still stained an off white colour.
  15. Feb 21, 2013 at 6:55 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I look forward to seeing it Ben! :D
  16. Feb 21, 2013 at 6:57 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    For that I'd say this:
    If you decide to redo it go double on a good clear coat. That's the way to go.;)
    The shop that does mine puts a killer clear on them that is super easy to shine.
  17. Feb 21, 2013 at 6:58 PM
    ToyoTaco12
    ToyoTaco12 Member
    Vallejo, CA
    '12 Tacoma 4x4
    non, Stock
    Once you have those done please let me know. I'm definitely interested!
  18. Feb 21, 2013 at 7:07 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Question about the 05-11 thin lips. There is the mounting point thing on the bottom of the grill in the center, do you have to cut it? Thinking about going from full depth to thin lip but i have a grillcraft insert, wondering if you leave the mounting point and notch the mesh around it.
  19. Feb 21, 2013 at 7:10 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    If your referring to that stupid little guide pin in the center bottom of the grill go ahead & lop the damn thing off - it's useless other than centering the grill when you put it on the truck.
    I'm leaning towards removing them from every grill I produce.
  20. Feb 21, 2013 at 7:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    How do I get burned on chicken, off my grill?
