ASK US ANYTHING
Discussion in 'Baja Designs' started by Baja Designs, Mar 10, 2023.
  1. May 30, 2023 at 10:23 AM
    Baja Designs
    Baja Designs [OP] The Scientist of Lighting Vendor
    San Marcos, CA
    Hey @Desert Dog, We do sell the lights individually and those do not come with a wiring harness. One thing to note though is when the total comes out it will be cheaper to purchase the pair of lights with the wiring harness than two single lights without.
    Best,
    Brandon
  2. Oct 14, 2023 at 4:35 PM
    Mix 99.3
    Mix 99.3 Well-Known Member
    Can you tell me how the light output of the LP9 Pro Driving/Combo in white (1 pod) compares to the Onx6+ 20" in Driving/Combo white? How about the LP9 vs 30"?
    Also, does the Onx6+ bar have a high beam and low beam, like the LP9? I noticed on the spec sheet in mentioned High/Low when referencing the watts and amps of the bar.
    I'm planning ahead for when I buy a new ATV and the main thing I want to do is add some extra light. There's a perfect spot on the front of the quad for one LP9, but I could also add an Onx6+ to the front rack. Not sure which way I want to go yet, but I'm worried about power draw. I'm not sure what a Yamaha Grizzly 700 can handle as far as extra lights go. Ideally, if I could add BOTH an LP9 Pro and 30" Onx6+, I'd do that. But I'm not so sure the Grizzly could handle that much watt/amp drain. If not, I'd cut back to the LP9 & 20". But if still not, then I guess it's just one or the other.
  3. Oct 14, 2023 at 5:24 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I would first make a realistic decision on what kind of speeds you will most likely see. You may not need the power of the LP9 or the Onx6+ if you will only see 40-50mph tops. Use Baja Designs ELS to judge range. Then I use this website Speed Distance Time Calculator (calculatorsoup.com) to see what I might need for a given speed.
  4. Oct 15, 2023 at 7:55 PM
    Mix 99.3
    It's not so much speed (as the Grizzly is only capable of 62-64mph), but there's a lot of heavy forest/big mountains around me that I'd love to explore and I don't want to limit my exploration to daytime hours only. With something like the LP9 or Onx6+, or both, I could see myself going out into the deep woods all night long and having a blast. Not for racing, but just for exploring. (Though I'm sure with enough light I'd go max speed when possible)
    It seems like you're saying either option borders on being way too much light for what I'm doing, but if the quad can handle the power draw, I don't think it would bother me having that much light (unless it would totally blow my eyes out). Realistically I might do one first, and then see how it looks, and then if I feel like even more would make me happier, then go for the other too as long as the quad could handle it.
    I just need to figure out exactly how one LP9 Pro pod compares and contrasts to an Onx6+ bar (20" and 30"), in the white driving/combo pattern.
    (About me, I tend to be someone who leans into the "bigger is better" way of thinking, even if it's not necessary. I'm sure a single LP6, or even LP4 would be plenty of auxiliary lighting for my needs, but if the quad can handle an LP9.....why not. lol. This way of thinking seems to come from past experiences where I went with what was adequate and then still wished I had more. :p)
  5. Oct 16, 2023 at 11:25 AM
    01 dhrracer
    Still Shopping
    A simple ask of google and this popped up. Grizzly 700 charging system output? and extra lights? | Yamaha Grizzly Forum (grizzlyowners.com)
  6. Oct 16, 2023 at 2:22 PM
    Baja Designs
    San Marcos, CA
    Hey @Mix 99.3
    With the LP9 vs. our Onx6+, they both have their differences in light output. You will be able to get more light out of the Onx6+ 20” than the LP9 Pro. Our Onx6+ 20” will have a high/low function that runs 18,460 lumens at (12.0A) on the low setting and 24,920 on the high at (16.6A). With the LP9 you will have a high/low feature as well as an amber backlight and IPT to give you maximum spread. For the lumens count you are looking at 12,547 at 9A.
    An option I would suggest would be looking at our XL80 or even Squadron Pro. I know the feeling of being bigger is better, but with the proper lens pattern as well as aiming the light where you need is a key factor in getting maximum lighting output. Please feel free to reach out if you have any other questions or would like more information about our other lighting solutions.
    Linked below are some specs of both lights to give you some comparison as well as other options to check out.
    LP9 Pro (clear) Driving Combo
    OnX6+ Straight LED Light Bar - Universal
    XL80 LED Auxiliary Light Pod - Universal
    Squadron Pro Black LED Auxiliary Light Pod Pair - Universal
    Best,
    Bill
    Bill Sonevongxay | Forum Sales & Support 
    Email: Bill@bajadesigns.comPhone: (760)560-2252
    Mix 99.3[QUOTED] and 01 dhrracer like this.
  7. Oct 26, 2023 at 11:03 PM
    Mix 99.3
    Thank you. I want to go as big and powerful as I possibly can -without- risking draining the battery or overstraining the system. I've looked into it a bit more and it looks like as long as I keep the auxiliary lighting under 10 amps I should be good. The LP9 comes in at a grand total of 9.12A (when you count the side LPT lighting) so I should technically be good using that. Otherwise, for the Onx6+, I could do a 10" as it only uses 8.4A on high. One or the other but not both.
    Can you comment on the LP9 Pro (Driving/Combo) vs Onx6+ in the 10" (Driving/Combo) as far as light output and how they differ?
    I assume both of those are brighter and have more light output than the XL80 and Squadron Pro? I may consider the XL80 (5.5A) if I decide I want to save a few extra amps for a grip heater or something.
    On the Onx6+ page there is a spot that says: "NOTE: For basic on/off light function the applicable wiring harness is 640115. To access the High/low light function the applicable wiring harness is 640119."
    Does the harness with only the on/off function use the high fuction only? So no low option in that case? (That's fine with me)
  8. Dec 30, 2024 at 9:47 AM
    Lunar.tacoma
    Lunar.tacoma Semi-Pro Mallcrawler
    Kyle
    Oceanside, CA
    2023 Lunar Rock Trail Edition
    Bilstein 6112 (Front) Bilstein 5160 (Rear) 285/70r17 KO2 Stealth Custom Series F5 (Matte Bronze)
    Do you guys offer any type of warranty on second-hand bought Baja Design lights? I have a set of Squadron Sport's I bought second hand and was wondering if I shot myself in the foot down the line by saving a couple bucks.
  9. Jan 3, 2025 at 11:22 AM
    Baja Designs
    San Marcos, CA
    Shoot me an email at brahianh@bajadesigns.com !! I can take care of you.
  10. Jan 3, 2025 at 6:29 PM
    bigd9247
    bigd9247 Well-Known Member
    WA
    2024 TRD ORP, 2018 F150
    Hey, I see you guys are rolling out lots of products for the 2024 Tacomas. Have you looked at designing a mounting bracket to put Squadron SAE lights behind the lower valance? I like the Toyota OEM fog lights for the daily commute, but would like to have the yellow Squadrons for extra lighting when needed (heavy rain, fog, backroads, etc).
  11. Jan 6, 2025 at 3:12 PM
    Baja Designs
    San Marcos, CA
    If there is enough demand, there is always a possibility. With that said anything right now will need to be a custom application if you wish to add something to that location. Or possibly even going with our grill mount light bar.
    https://www.bajadesigns.com/product...-2024-on-toyota-tacoma/?vid=171627&sku=448262
    Best,
    Brahian Herrera | Forum Sales & Support
    Email: brahianh@bajadesigns.com | Phone: (760) 560-2252
  12. Jan 9, 2025 at 3:44 PM
    lynyrd3
    Bill
    East Central Upstate NY
    @Baja Designs
    Hello I’m looking to move my Squadron Sports to behind the grill of my 2nd Gen . Do you guys offer a mounting bracket of any kind ? Thanks
  13. Jan 10, 2025 at 11:27 AM
    Baja Designs
    San Marcos, CA
    Hey,
    We do not offer behind-the-grill brackets for the Gen 2 Tacoma. There is a handful of companies who do but they are for a light bar. Custom mounts will probably be the route to go.
    Best,
    lynyrd3[QUOTED] likes this.
  14. Jan 31, 2025 at 11:58 AM
    bigd9247
    WA
    Thanks for the reply. After searching around some more I found that SDHQ offers a mount for behind the lower grill. I ordered up their mount and a set of Squadron Sport wide cornering lights.
    With that said, I see the Squadron sports are rated at 2.2 amps. Can I wire both (4.4 amps) to the 5 amp 4th gen Tacoma Aux switch or should I play it safe and wire them to the 10 amp Aux switch?
  15. Feb 3, 2025 at 9:25 AM
    #35
    Baja Designs
    San Marcos, CA
    Completely up to you ... 5 amp will be fine!
    Best,
  16. Feb 4, 2025 at 5:43 PM
    #36
    Klinc207
    Klinc207 Well-Known Member
    Any idea when the S8 amber 20” combo will be available?
  17. Feb 4, 2025 at 5:46 PM
    #37
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Can you sell me plug n play one stop for driving lights for my ‘16 Tundra fog light area even if I don’t have factory fogs in place?
  18. Feb 10, 2025 at 11:48 AM
    #38
    Baja Designs
    San Marcos, CA
    If you are waiting specifically for 70-2013 S8 20-inch D/C amber, then the current wait time is 2-3 weeks out. I can always place an order for a 20-inch that is in stock and add the lens on the side for you. All you will need to do is swap it out. Please feel free if this sounds like something you wish to do.
    Best,
  19. Feb 10, 2025 at 11:56 AM
    #39
    Baja Designs
    San Marcos, CA
    We do not sell a conversion kit. Only kits for cars with existing fog lights. If you wish to add our light solution you will need to buy the OEM plastics in order to make it work. The vehicle most likely doesn't come with fog wiring so it will need a harness that connects to the battery.
    Best,
  20. Feb 10, 2025 at 12:05 PM
    #40
    Klinc207
    Found one in stock through another dealer- should be here today. Thanks!
