Asked for BFG AT 265/70R17 load C, got load E. What to do?
Discussion in 'Wheels & Tires' started by thegrandpoohbah, Aug 29, 2013.
  1. Aug 30, 2013 at 1:38 PM
    davidpick
    davidpick NWXPDTN
    David
    Everett, WA
    2004 Xcab 4x4 TRD
    you're right, 29psi is far too low. i'd start at 40psi and do the chalk test.
  2. Aug 31, 2013 at 5:03 PM
    LukeBo4x4
    LukeBo4x4 The more people I meet, the more I like my dogs.
    luke
    Big Island,Virginia
    03 TRD ext cab
    OME 882s, wheelers 5 leaf pack w/aal, ARB front bumper, 305/70/16 nitto mud grapplers,pro comp 7069s, Grey wire mod.
    I don't know why people say E loads suck on tacomas. I went from C load to E load tires and in my opinion the E loads ride a lot better.
  3. Sep 2, 2013 at 6:40 AM
    TAC1
    TAC1 Well-Known Member
    Petros "Peter" AGE: 43
    Miami, Florida
    DCSB 4.0 Auto PreRunn
    FRONT: OEM PreRunner coils, 5100's @ .85, MaxTrac Spindles, 1/4" Taco lean spacer. ground to fender base: LF & RF: 40"'s hub to fender base::::: LF & RF: 25"'s REAR: 2012 OEM 3/1 leafs, Wheelers 3 leaf AAL, 2" Tapered steel block. Bilstein F4-BE5-B110-T5 ground to fender base: LR & RR: 41"'s hub to fender base::::: LR & RR: 26"'s All mud flaps trimmed 4"'s shorter.
    For you guys running 275/70r17 "E" rated tires, are you experiencing any power loss? I have had BFG AT's in 265/75r16 E on OEM steel wheels for 1.5 years.
    I am looking at getting either:
    265/70r17 BFG AT's C or
    275/70r17 BFG AT's E.
    for my 6 spoke alloy FJ wheels & eventually my SCS Stealth 6 wheels when they come in.
    The 275 is 8lbs heavier (per tire) & 1/2 taller/wider. I do mild off-roading/mudding & I tow a 21' 4600lb boat (total weight with trailer) about once a month. Should I go with the 275's or 265's.
    FYI, My wife & I drove to Atlanta (10.5 hour trip each way) & she was fine & slept most of the way. The ride is firm but not bone jarring.
    I also have Billies with the fronts @ 1.75 & 3 leaf AAL on OEM 3/1 leafs.
    I/m just worried that going to a 275/70r17 may ber overkill.
    Also, I am running 32 PSI & with 18,000 miles these BFG's have even wear.
    Thanks
  4. Sep 2, 2013 at 8:37 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I like my 275/70/17 Hankook ATm's , I didn't notice any power loss when I switched to them from E rated 265/70/17 Hankook MT's
  5. Sep 2, 2013 at 10:30 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Do the chalk test. That'll determine what psi to run it at. Remember that load E tires go on one ton diesels. At 40psi it's going to feel like the flintstone car attempting the hammers.
  6. Sep 2, 2013 at 10:42 AM
    FATaco
    FATaco Meh
    Friends call me Ginger
    Fairbanks
    07' TRD DCSB
    Dakars w/AAL, OME/886's, All Pro Front Bumper, Rear bumper, IFS skid, and UCA's. Superwinch Tigershark. Magnaflow muffler... vrooom
    There would never be any reason to run them at 40psi unless you are carrying a load. I always run load range E on my 285 BFG's at around 30-32psi. Remember, the sidewall is stiffer as you have already noticed, so you should be able to run a normal pressure. The 10 ply will also probably last you longer if you keep them rotated. I do mostly highway and usually get between 65-75000 miles out of a set. I rotate religiously around 5-6000 miles. This is my 2nd set on this truck and I'm at around 40,000 mi with plenty of tread to go.
  7. Sep 2, 2013 at 11:06 AM
    TAC1
    Miami, Florida
    Good to know OZ-T. You going from 265/70r17 to 275/70r17's is the same as me going from 265/75r16 to 275/70r17's.
    FATaco, that is exactly how I rotate my tires & keep my PSI. As you said, stiffer sidewall on a light truck doesn't need such high PSI. Yes, they do last long. I was initially waiting to wear down my 16's before going to 17's but I can't wait so I am selling my 16's
  8. Oct 7, 2013 at 10:19 PM
    BDBSoCal
    BDBSoCal The Safety Guy
    Brad
    SoCal
    Silver 2008 SR5 V6 4x4 TRD Sport
    Just starting...
    I was running 265/75/R16 BFG AT KO on my 2004 TRD 4x4 and it was REALLY fun to drive. I miss it already. I put 265/70/R17 BFG AT KO on my 2008. They are actually the same diameter almost exactly, but handle smoother than the other truck. Not sure if this is just the way the TRD Sport is yet.
    But I head down to Mexico and like to find places to hike that are far from civilization. I can't conceive of a situation where I'd want a weaker tire when I'm in the middle of nowhere on my own.
