Aspect ratio and winter traction
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NMTrailRider, Nov 23, 2015.
  1. Dec 15, 2015 at 8:14 AM
    #81
    Pigpen
    Dan
    Northwest Montana
    :facepalm:
    TacoMitch93 and BuzzardsGottaEat like this.
  2. Dec 15, 2015 at 8:16 AM
    #82
    tgear.shead
    tgear.shead Well-Known Member
    And if your property is on the wrong end of a snowmobile track? Then what... then you drive on a snowmobile track.
    Or what if you have a snowmobile that is BROKEN on the wrong end of a snowmobile track? Same thing, you're going to get it.
    End of story.
  3. Dec 15, 2015 at 8:20 AM
    #83
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    this this exactly this.
    skinnier tire digs in more
    fat tires float
    if you had studded bicycle wheels and tires as wheels you'd be completely unstoppable
    so, when opting for winter wheels skinnier is better
    my friggin yaris is crazy good on any wheel that has a snow tire on it, but I have a two sets, stock...and a smaller set
    with the same winter tire model michelin x-ices, (just 1 inch narrower) and it is noticeable when the little wheels are on ....it is beast-mode
    TacoMitch93 and TRDMountaineer like this.
  4. Dec 15, 2015 at 8:22 AM
    #84
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    This thread is hilarious. I just read through all 5 pages and I'm :rofl:
    :popcorn: for more.
  5. Dec 15, 2015 at 8:23 AM
    #85
    tgear.shead
    So decide if the type of driving you will be doing most will benefit more from floating above the snow or digging down into it. Are you driving on 3 feet of packed snow? Then you want flotation because if it digs in, you're stuck until spring. Or are you driving on 3 INCHES of packed snow? Then you want to sink down to the hard surface that you can grip on.
  6. Dec 15, 2015 at 8:41 AM
    #86
    tgear.shead
    Unfortunate thing about "common" sense, is that it is rare that it is actually correct. Some things are best left to physicists than the common folk. While the balance of your statement sure makes "common" sense, it is actually entirely incorrect.
    There are TWO forces at play, and you are only accounting for ONE of them.
    You are thinking only of the rotational force that is trying to accelerate the vehicle, but you are forgetting about the force of GRAVITY.
    So lets try to look at this from a slightly different angle. You say that snow is slippery, right? I totally agree. This is the reason why you want to get your tire up against the asphalt that lies UNDER the snow. Because asphalt is a much better (high traction) surface for holding off the rotational force being applied from the vehicle's wheel. The greater the surface area of the tire, the more it will float your tire above the asphalt, leaving its traction surface mostly snow. A skinny tire will allow the force of gravity to pull the vehicle down closer to the asphalt, giving you a greater traction.
    Snow is SO slippery, in fact, that 2 square inches in contact with snow will yield less traction than 1 square inch in contact with asphalt.
    "But but but... the snow is going to hold you up off the asphalt no matter what!!!!"
    Not so. Winter conditions are quite varied. There is this wet gooey stuff called "slush". Its thicker than water and will hold you up a "bit", but thin and fluid enough for you to find your way to the bottom of it when your equipment is appropriate.
    Q: Why do racing cars use different tires in the rain?
    A: To get the layer of water out from between the rubber and the asphalt. The loss in surface area yields greater traction in wet conditions than the greater surface area yielded by the slick.
    But only IF you are operating on a *high traction surface*.
    Darth_Yota likes this.
  7. Dec 15, 2015 at 8:45 AM
    #87
    tgear.shead
    Who said anything about running at the same pressure?
  8. Dec 15, 2015 at 9:13 AM
    #88
    TRDMountaineer
    TRDMountaineer Well-Known Member
    Ripley, WV
    2015 AC TRD Sport MGM 6-spd S/C
    TRD S/C, aFe Stage-2 Intake, Magnaflow 15315, Leer 100XQ w/ Tracker II Rack, General AT2 265/70R17, OEM skid, TRD FJ caps, Wet Okole Realtree seat covers, TRD grey shift knob, Weathertech floorliners, Weathertech window visors, Salex glove box+console organizers, Grid-It console lid mod, Lamin-X amber fogs, Craven Speed A-pillar phone mount, Debadged
    When you're talking about the effects of changing one variable, you assume all others are kept the same. Otherwise you can't say what gave you the results.
  9. Dec 15, 2015 at 9:16 AM
    #89
    tgear.shead
    Air pressure is a variable though. Whatever the tire size is that you are running, you make your comparison *after* optimizing the air pressure.
  10. Dec 15, 2015 at 10:33 AM
    #90
    Lomez
    Lomez Well-Known Member
    Lomez
    AZ
    2015 Silver Sky DCSB 4WD
    Are you in the sciences field?
    TRDMountaineer likes this.
  11. Dec 15, 2015 at 10:39 AM
    #91
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    here is another thing about winter traction (all other things being equal, and no metal studs)
    snow tires that hold onto snow and keep it in the grooves (like michelin x-ice)
    grip better than larger lugs that don't get packed with snow
    tire engineers realized back when the blizzak was developed that the only thing
    that truly grips snow best, is more snow. that is why modern snow tires have
    closely spaced and extremely siped blocks....with some nice rain or water grooves in the middle
    to deal with the puddles....a part of that design is to hang into as much snow as possible in the tread, as it grips best.
    extreme siping is for gripping ice
    closely spaced blocks is to hold onto snow, to grip more snow
    center grooves are for water extraction for puddles
    and if you can add studs that certainly helps on ice
    there are a ton of variables and 55 different types of ice and snow
    but -in general purpose winter driving- the above is always true
    VE7OSR and TRDMountaineer like this.
  12. Dec 15, 2015 at 10:39 AM
    #92
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I think his point may be this. Your sketch implies that a shorter tire would have a longer contact patch then a taller one with equivalent pressures. Which isn't necessarily true. A narrower tire has a longer patch than a wider tire at equivalent pressures and diameters.
  13. Dec 15, 2015 at 10:41 AM
    #93
    TRDMountaineer
    Ripley, WV
    No, my sketch referenced WIDTHS. 245 and 265 are widths not heights. I agree with your last statement though.
  14. Dec 15, 2015 at 10:54 AM
    #94
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    You only need wide for floatation in snow deeper than your frame and then some. And guess what. No 285 or 315 is going to hold your truck above the snow.
    Wide tires are for people who prioritize looks over performance haha.
    Darth_Yota and TRDMountaineer like this.
  15. Dec 15, 2015 at 11:02 AM
    #95
    tgear.shead
    That depends on the snow.
    One of my old trucks had 10.5's (roughly 265's), and on hardpack (groomed snowmobile trails), it would float, not get stuck... most of the time.
    Also, your assertion that it is only beneficial for snow "deeper than your frame" is incorrect. If you had ever been stuck in the snow, you'd know that it takes a heck of a lot less than hanging it up on your frame to get stuck in. All it takes is 4 little divots for your wheels to sink into, without enough traction to climb out from. Remember that snow/ice is slippery.
  16. Dec 15, 2015 at 3:18 PM
    #96
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Yeah, man. I've been in the snow a whole lot. And I spend every single winter volunteering to pull people out of the snow after every single blizzard haha.
    BUT, this isn't about your or my little experiences here or there. I've admitted room for exceptions depending on circumstances in a previous post. But you know what, at the end of the day, you can like your fatties and I'll like me some skinnies (and I'll be more than happy to come pull you out of a ditch). ;)
    Pigpen likes this.
  17. Dec 15, 2015 at 5:10 PM
    #97
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    This whole thing went to shit.
  18. Dec 15, 2015 at 5:17 PM
    #98
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Mixing ignorance and facts always makes a shit stew here.
    TacoMitch93[QUOTED] likes this.
  19. Dec 15, 2015 at 5:21 PM
    #99
    TacoMitch93
    Mitch
    09 Tacoma SR5
    My new favourite saying
  20. Dec 15, 2015 at 5:31 PM
    #100
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think bottom line is if narrow tires worked for you and you think they ok with you that means your environemnt is not that bad and you can use narrow tires.
    but narrow tires never where better for the snow driving, thats why nobody who drives on real snow (including Icelander trucks that drive on snow and ice) use narrow tires.
    Now I understand somebody had seen Rally car on skinny tires but what they missed were studs in those tires. The big difference is that studs made out of steel can penetrate frozen ice while rubber can not. And if you driving in winter, 90% of the time under that snow there is ice. Studded tires vs rubber tires, it's apples to oranges.
    If you driving on rubber, than biggest patch with most edges is what you want. And that is a fact.
