Assembled Bussmann RTMR Fuse Panels For Sale
Discussion in 'Buy / Sell / Trade' started by JeffRoyJenkins, May 16, 2022.
  1. May 16, 2022 at 1:35 PM
    JeffRoyJenkins
    JeffRoyJenkins [OP] Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Edit: 1 sold, still have 3 available.
    Hey everyone, I've made a few of these in the past so I figured I would put my tools and resources to use and take some of the leg work out for anyone that is looking to add an auxiliary fuse panel to their truck. I currently have 4 built and available to ship less any extra bundles you might want.
    So here is what I am offering:
    Assembled RTMR Fuse Panel for $265 shipped USPS Flat Rate includes:
    -Fuse panel completed with Hi-Temp TXL and GXL wire
    -Five 2-pin (power and ground), relay controlled power pigtails for accessories
    -One 5-pin signal input pigtail (12VDC signal from switches to activate relays)
    -One 2-pin "always on" power pigtail
    -Five Micro SPST 12VDC 35A Power Relay
    -Six 10A Mini Fuse
    -One 8ft 22ga 5-wire Signal Bundle (connects to switch panel) with expandable sleeving
    -One 6ft 14ga 2-wire accessory power bundle with expandable sleeving
    -One 30in 8ga power supply wire (Battery to breaker/fuse)
    -One 8in 8ga power supply wire (Breaker/Fuse to Panel)
    -One 20in 8ga ground wire (Panel ground to Body Ground)
    -Includes loose connectors and contacts for any pigtails that you do not order mating bundles to connect to.
    Additional accessory bundles can be ordered to go along with.
    -6ft or less - $12
    -Longer than 6ft - add $1.50 per foot
    -Includes expandable sleeving and fuse panel end connector installed
    All bundles have connectors installed on the fuse panel end and have been left unterminated and heat shrinked on the other end to allow for routing through firewalls and tight areas as well as to accommodate your build at the connecting end.
    I have tried to do my best to make these as "plug and play" as possible while still being able to be adaptable to different builds. The assumption is the person using these is going to have a pretty good understanding of what they are doing installing it but just wants some of the leg work taken out.
    Right now I am not planning to build a ton of them as they are actually more work than I had originally expected. I currently have 4 built and ready to ship out less any additional bundles you want built. Being as this is more of a downtime project, I'm not planning to take orders or do anything custom other than building add-on bundles to length. If I decide to make some more I will post them up as available once they are complete.
    All of that said if anyone has questions or suggestions on modifications should I decided to build some more in the future feel free to let me know.
    SigBoy, Wulf, Big Foot and 2 others like this.
  2. May 16, 2022 at 6:53 PM
    Big Foot
    Big Foot Well-Known Member
    Washington
    2014 DCLB
    Pm’d
  3. May 21, 2022 at 5:33 PM
    JeffRoyJenkins
    Jeff
    Lake Stevens, WA
    One sold, 3 still available.
  4. Jun 2, 2022 at 7:50 PM
    TacoTuesdayNJ
    TacoTuesdayNJ Well-Known Member
  5. Dec 14, 2022 at 9:30 PM
    r3k
    r3k Well-Known Member
    still have 1?
  6. Dec 15, 2022 at 5:02 AM
    JeffRoyJenkins
    Jeff
    Lake Stevens, WA
    I do, still have 3 actually. I haven't been very proactive about getting them sold, haha.
    elephantears09 likes this.
