ASSHOLE PARKING
Discussion in 'Off-Topic Discussion' started by maxboi, Jul 2, 2015.
  1. Nov 10, 2023 at 12:03 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Let me explain the scenario, line for Costco gas, all out cluster, lanes blocked, horns blowing, it was actually quite amusing to be just sitting and watching it. Guy in the grey SUV sat there for at least a minute, it was interesting
    Cpl. Punishment likes this.
  2. Nov 11, 2023 at 10:03 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
  3. Nov 11, 2023 at 3:00 PM
    picturethis
    picturethis Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
    Obviously handicapped!!
  4. Nov 13, 2023 at 7:41 PM
    skippyscage
    skippyscage Well-Known Member
    2023 Tacoma TRD Off Road
    2 of them that can't be bothered - even the ones in the distance are pretty crap
  5. Nov 14, 2023 at 5:51 AM
    Barsoom
    NW GA OTP
    It's Fords, they barely made it to parking lot before they died. Did you hang around to see if they needed a jump?
  6. Nov 15, 2023 at 8:26 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Learn your driving laws. Areas hash marked and bound by blue lines such as this is all available handicapped parking. Handicapped placard properly displayed. What seems to be the issue?
  7. Nov 15, 2023 at 10:00 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I've never seen that written anywhere, where did you find that info?
    williams63 and Barsoom like this.
  8. Nov 16, 2023 at 5:39 AM
    Barsoom
    NW GA OTP
    Triggered your PTSD? You drunk again?
    Learn federal ADA regs:
    https://www.ada.gov/resources/restriping-parking-spaces/
    For starters, there is an actual marked Handicapped parking spot right next to the hashed line.
    "Parking space identification sign with the international symbol of accessibility complying with 703.7.2.1 mounted 60 inches minimum above the ground surface measured to the bottom of the sign."
    There was a car parked in the proper, marked handicapped spot (bottom right, you can see just the front of it). Across from it Kia was parked in the unmarked, striped non-parking area.
    Second, hash marks are used to mark the ACCESS to the parking spot, not the parking spot itself.
    "Boundary of the access aisle must be clearly marked so as to discourage parking in it"
    Blue striped areas are not parking areas, they are either van unloading or wheelchair access or parking spot access areas.
    Thirdly, that long hashed area is an access route to a larger parallel parking HC spot to the right of it. Spot built to accommodate oversized HC vans or short HC accessible buses (cut-away buses in industry lingo).
    Now that HC long spot cannot be used by a longer vehicle.
    "Van-accessible parking spaces incorporate the features of accessible parking spaces on the previous page and require the following additional features: a “van accessible” designation on the sign; different widths for the van parking space or the access aisle; and at least 98 inches of vertical clearance for the van parking space, access aisle, and vehicular route to and from the van-accessible space."
  9. Nov 16, 2023 at 5:01 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    In the wild today I saw a wheelchair van with a sticker on that side's window.
    The graphic was of an open van door, ramp out with wheelchair on the ramp.
    Text was "if you block my ramp I will ding your ride"
    Sad it has to be pointed out to people but love the reminder of how the vans work.
    TartanEagle, ETAV8R, wilcam47 and 3 others like this.
  10. Nov 16, 2023 at 5:44 PM
    Barsoom
    NW GA OTP
    It is sad.
  11. Nov 22, 2023 at 1:10 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
  12. Nov 22, 2023 at 2:40 PM
    skippyscage
  13. Nov 27, 2023 at 5:36 PM
    FMRAV4
    FMRAV4 Well-Known Member
    Al
    Detroit, MI
    Dreaming
    actual parking spot I couldn't use, because....
  14. Nov 27, 2023 at 5:43 PM
    skippyscage
    all too common these days - either people can't drive or they don't care cause it's all about them
    FMRAV4[QUOTED] likes this.
  15. Nov 27, 2023 at 6:35 PM
    Breknraj
    Breknraj Well-Known Member
    Roger
    2017 Tacoma TRD Off Road
    Eibach mild lift Relentless Stingray low profile bumper w/ Warn 8000S Warrior Products Roof Rack RRW Sliders
    The Rolls / Bentley looks to have been able to park in a civilized manner, but the Dodge guy was obviously clueless.
  16. Nov 27, 2023 at 6:45 PM
    skippyscage
    they got the end spot, and still messed it up.....
    RustyGreen, hack4875 and FMRAV4 like this.
  17. Nov 28, 2023 at 9:00 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I mean if they would have just backed up in those other spots I would have given a pass, but nooo haha
    eeehhhhh, yes they are not straight into the spot, bbuuuuttt they are technically within the "generously spaced" parking spot and (from what I can see) not infringing on others
  18. Nov 28, 2023 at 11:22 AM
    unclewede
    unclewede Well-Known Member
    'Nard
    23 TRD Sport 4x4 Lunar
    "Pardon me, but do you have any Grey Poupon?"
  19. Nov 28, 2023 at 12:47 PM
    mit88
    mit88 Well-Known Member
    Planet earth
    Don't let @RustyGreen see this :boink:
    RustyGreen likes this.
  20. Dec 3, 2023 at 3:32 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The Rolls Royce can park correctly but not the Dodge guy.. :facepalm:
    And yet another Dodge guy:
    Superdave1.0, JGO, hack4875 and 4 others like this.
