Assistance diagnosing noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wilson23, Jun 2, 2025.
  1. Jun 2, 2025 at 3:54 PM
    wilson23
    wilson23 [OP] Well-Known Member
    A friend of mine has a 2018 access cab 4cyl. Three summers ago, due to a negligent oil change place leaving the radiator cap off, They found themselves overheating far from civilization. They received some bad advice and drove the truck for at least 20miles while overheating.
    Since then sometimes on cold starts it makes an awful racket that sound like a dry valve train, like a diesel. as if there is no oil being pumpe, releases some smoke, noise stops and they carry on.
    She has taken it to the dealer twice and they have no idea what's going on. They told her it needed an oil change the first time and it was silent for a while after that. Of course, can't get it to replicate while the dealer has it.
    Anyway, second trip to the dealer and still nothing concrete and she asked for just a diagnostic. They mentioned possible cracked manifold issue. Nothing they say makes any sense.
    Well she just sent me another video of the noise and its totally changed. My first though is it sound like an impact drive going HAM. thinking through it a bit more, it almost sounds like the starter is trying to start? is this possible?
    https://youtube.com/shorts/01hBzc_X3l4?si=LiJABSfqXN2BM98U
  2. Jun 2, 2025 at 3:56 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like a bad headgasket is leaking a bit of coolant into the cylinder(s) while it sits. When the engine starts again it "chokes" on the liquid coolant in the cylinder for a couple seconds, then it runs better. The smoke is the coolant steam coming out the exhaust
    Engines can't compress water so it does indeed sound like a diesel until the liquid gets out of there. Now the sound is worse because damage has been done
    Does the coolant level drop at all?
    23Skidoo likes this.
  3. Jun 2, 2025 at 3:59 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    yeah, thats a really weird noise but then again, we have no idea of throttle position during the recording...
    she could be hammering down on the throttle...
    the hood isnt even up.....
  4. Jun 2, 2025 at 4:03 PM
    slater
    San Diego
    dude....:frusty:
    thats bit of a stretch.....
    I get your theory but ive never heard any head gaskets on the verge of hydrlocking make that much noise....
    maybe a lazy timing chain tensioner if it has a chain due to oiling issues, sludge, etc....?
    early stages of front crank dampner seperation?
    Doesn’t sound like crank bearings, but I’d believe that over head gasket…
    could even be cat converter internals coming apart & lose in the cat shell...?
    could be anything from that video, but head gasket leaking coolant making a catastrophic noise like that aint it....
    BillF1564 likes this.
  5. Jun 2, 2025 at 7:02 PM
    wilson23
    The truck is idling in the video
  6. Jun 2, 2025 at 7:07 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Get a long PVC pipe and CAREFULLY poke around with your ear at one end of the pipe. You should be able to determine where the loudest source of the noise is.
  7. Jun 2, 2025 at 7:09 PM
    slater
    San Diego
    sounds really fast for idle, maybe it was just started...
    A mechanics stethoscope is your friend here if you truly want to isolate...
    This is a hands-on deal to really know what the source is.....
  8. Jun 2, 2025 at 7:11 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    That sounds as bad as the advice given to continue to drive while overheating. Someone’s number should be blocked at the very least.
  9. Jun 2, 2025 at 7:33 PM
    Bishop84
    Bishop84 Well-Known Member
    Terrible advice.
    Wild ass guess, its the water pump chewing into the timing cover.
    But without a stethoscope its impossible to tell.
    It needs to see a qualified mechanic and left over a few days.
    RustyGreen and BillF1564 like this.
  10. Jun 2, 2025 at 8:55 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Again, it sounds like had a bad head gasket for a while. Problem happened only at startup, choking on liquid coolant for a few seconds then running normal.
    Noise and strange smoke would come only come back sometimes at startup. After sitting and getting cold.
    That's why I asked about the coolant level
    The video was taken after it did that for 3 years. "Ever since" it was driven for 20 minutes while overheating it has done those symptoms..
    Now something is much louder so he decides to post. Now the noise could be anything. Im just saying from the description it really sounds like he had a slow HG leak for 3 years
  11. Jun 2, 2025 at 9:56 PM
    gdr
    gdr Well-Known Member
    Bill
    Temescal Valley, Ca.
    2016 Inferno Tacoma TRD OR 4x4
    That sure sounds like the VVT rattle I hear posted on here alot. That solenoid valve has to be pretty gunked up from the over heating.
  12. Jun 3, 2025 at 12:24 PM
    wilson23
    I understand there is self cleaning fuel injector thing that same people are talking about in other forums. Any thoughts on that? I recieved video of the coolant level with the cap removed. I’ll post it up here shortly. It’s not clear pink by any means but not seeing oil
  13. Jun 3, 2025 at 12:31 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Not applicable to 4 cylinder engine. This engine only has port side injectors
  14. Jun 3, 2025 at 12:35 PM
    wilson23
    Copy, thank you!
