Assistance needed for my truck
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99tacoma2wd, Aug 13, 2025.
  1. Aug 13, 2025 at 8:22 PM
    99tacoma2wd
    99tacoma2wd [OP] New Member
    Benny
    Hello, all! May your Tacoma live forever.
    When I got home, I noticed that some smoke came from the engine. It has a burnt smell (most likely oil leaking from the old valve cover gasket which is long overdue for a new one). No coolant leaking. To be honest, I don’t really have the time and am mostly procrastinating. But I am looking to find a genuine valve cover gasket for my automatic 99 Tacoma 2.4l 2WD . Where can I physically buy one?
    I drive on the highway every weekday to work, so I do need to do an oil change, replace spark plugs and air filter more often.
    Also, I do feel like this truck struggles uphill, which is probably expected, so my first guess is to replace the fuel filter (if I can find it). Second guess are either replacing transmission fluid and filter, and/or changing differential fluid. Transmission and differential fluids are original. Currently have 282k miles.
  2. Aug 14, 2025 at 9:04 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Your fate is probably already sealed
    Old contaminated fluids act as a cutting fluid......especially at temp
    you're eating all your seals in the tranny and rear wheel seals...
    however if you fresh fluids now either may start leaking
    precarious position........no good choices
  3. Aug 14, 2025 at 9:41 AM
    Glamisman
    Glamisman Well-Known Member
    Fuel filter is under the intake manifold and can be difficult. While you might be able to get away with using 2 open end wrenchs tubing wrenches is preferred. If you round out the corners of the hardline you are in a world of hurt.
    A 2.4 and an automatic is not the fastest thing out there.
  4. Aug 14, 2025 at 10:10 AM
    O'Silver_Taco
    MD
    Would not be a bad idea to check compression numbers
