Assistance Please - front shock, lower bolt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PzTank, Jul 31, 2020.
  1. Jul 31, 2020 at 12:10 PM
    PzTank
    PzTank [OP] Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Assistance please!!!!
    Got 5100s w the OME 883s pre assembled from HS. Just wanted an improved ride because I dont OR.
    They’re set at the lowest setting - looking for no more than an inch lift.
    Having a hellava time getting the lower shock bolt to line up. Shock is difficult to compress.
    Any ideas!
  2. Jul 31, 2020 at 12:12 PM
    tcjacado
    tcjacado Well-Known Member
    Pry bar or large flat head screwdriver under the eye while pushing/ stepping on the lca.
    Or use the bottle Jack to compress the lca
    $yoda$ and PzTank[QUOTED][OP] like this.
  3. Jul 31, 2020 at 12:14 PM
    PzTank
    Above the Notches
    Need a third hand ..
    Thanks :thumbsup:
  4. Jul 31, 2020 at 12:15 PM
    tcjacado
    Yeah that helps, but it can be done solo. Been there twice.
  5. Jul 31, 2020 at 12:15 PM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    This, or loosen up your LCA bolts. I don't have the torque value of those bolts readily available and if you don't mark your alignment tabs, you'll need a new alignment.
    -J
    PzTank[OP] likes this.
  6. Jul 31, 2020 at 12:22 PM
    PzTank
    Above the Notches
    Used a larger Phillips to align the holes.
    Thanks folks :thumbsup:
    tcjacado and JustAddMud like this.
  7. Jul 31, 2020 at 12:25 PM
    Hans_Gruber
    Hans_Gruber Well-Known Member
    Nick
    13 DCSB TX TRDOR 6MT
    All Stock
    I used a 6 ft piece of steel conduit, shoved that between the LCA and and either the front diff or t-case (can't remember what exactly I used) but then I sat my ass down on the other end of it to push the LCA down so I still had both hands free to work the shock and bolt.
    PzTank[QUOTED][OP] likes this.
  8. Jul 31, 2020 at 3:10 PM
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Like other say BIG phillips and a bottle jack
