Assistance Running Lockers and Wifey Kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Thorian, Jun 10, 2020.
  1. Jun 10, 2020 at 3:20 PM
    Thorian
    Thorian [OP] Well-Known Member
    Marco
    Los Angeles, CA
    2017 4x4 White Tacoma
    Kings 2.5 Front and Rear, Baja Kit UCAs, Dakar Medium Leaf Pack, SSO Slimline Bumper
    Hey so I’m in need of some assistance and hope someone on here has the insight or has ran this set up before.
    So I have an arb twin compressor.
    which I will be using to run my lockers but also bought the wifey kit from rago.
    however I’m a bit confused because the set up for the wifey shows them running their own braided hose straight from the compressor to their manifold, like this:
    But since I’m running lockers I need to incorporate the arb manifold:
    8B32FAE8-A789-44B5-AB3E-B5E874B5C2AF.jpg So this is what I’m thinking....Run the arb braided hose From the compressor straight into the blue circle (inlet one of arb manifold) then run my locker solenoids off the red circles (obviously) and then run the wifey braided hose from the yellow circle (inlet 2?) straight the the wifey manifold.
    would that work? Anyone have a better suggestion?
  2. Jun 10, 2020 at 4:39 PM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    You can run the wifey kit before or after the ARB manifold. There's no real magic to the manifolds. You could not run the ARB manifold at all and just accomplish the same thing with the right fittings. The easiest way to add it in may be to just use that port on the wifey manifold that you aren't using next to the gauge, and just add a 90 from there to the ARB manifold. What's that blue fitting at the end of the wifey manifold?
    Thorian[OP] likes this.
  3. Jun 10, 2020 at 4:40 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Yes, that should be fine. It's just a reservoir tied to a reservoir.
  4. Jun 10, 2020 at 5:27 PM
    Thorian
    Marco
    Los Angeles, CA
    so the wifey manifold has a shut off valve before the incoming port. So if i ran it before the arb manifold then I would need to always have that shutoff valve open.
  5. Jun 10, 2020 at 5:31 PM
    Thorian
    Marco
    Los Angeles, CA
    Blue fitting is the sliding valve
  6. Jun 10, 2020 at 5:40 PM
    tacomarin
    Bay Area
    2018 DCLB TRD OR
    Then yeah, if you don't want that system pressurized all the time your lockers are pressurized then run it to the ARB manifold first and put that shut off valve in between the ARB and Wifey manifolds.
    Thorian[QUOTED][OP] likes this.
  7. Oct 6, 2021 at 4:11 PM
    jayrome
    jayrome Well-Known Member
    2020 Tacoma TRD Off Road - DCLB
    King 2.5 Front Ext Travel Coilovers with Adjusters and SPC UCAs King 2.5 Rear Ext Travel with Adjusters 17" Method NV Wheels BF Goodrich K02 275/70/17 RCI Steel 3 Pc. Skids and Diff Cover All Pro Rock Sliders Victory Strike Front Winch Bumper with Warn Evo 10K Twin ARB Compressor with Rago Mount Wifey Air System
    I have the same Rago mount, with wifey block and wifey system. Are you enjoying having no access to the fuse box as much as I am?
    I should have gotten the Slee and I would have been able to mount the wifey and ARB manifold to it, without losing access to the fuse box
  8. Oct 6, 2021 at 4:57 PM
    Thorian
    Marco
    Los Angeles, CA
    thankfully i have not had a reason to go in there but If I ever do it’s gonna be a pain in the a$$
  9. Oct 7, 2021 at 1:55 AM
    Laelius
    Laelius Well-Known Member
    Chicago
    2021 TRD PRO LR
    Leitner ACS, Decked, CBI Sliders, Skids, Air Bags, Gizmos
    Why not tee off the arb and send one line to wifey and the other to the locker manifold, that way they can both call for air independently.
  10. Oct 7, 2021 at 4:56 AM
    Thorian
    Marco
    Los Angeles, CA
    Yeah that’s what I ended up doing actually!
  11. Oct 7, 2021 at 7:11 AM
    RedZeppelin
    RedZeppelin Well-Known Member
    Skip the sliding valve and save yourself some money. Get a regular NPT ball valve. Works exactly the same
  12. Oct 7, 2021 at 10:07 AM
    jayrome
    That slide valve (the one the wifey guy has in the parts list for doing the wifey system) is only like $9 on Amazon
    Unfortunately, every one I received from Amazon failed to work so I had to go with a standard ball valve
