Asymmetry with front wheels... crashed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zebinator, Sep 24, 2016.
  1. Sep 24, 2016 at 5:59 PM
    Zebinator
    Zebinator [OP] Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    So - i did a small lift and installed 33's and the left side has been rubbing but not the right. I originally thought it might just be a slight difference in alignment, but it finally dawned on me to actually look at how different the right and left are from each other, and the left side is 1.5" further back in the wheel well than the right! Anyone else notice this on their trucks, or am i likely the proud owner of a crashed truck? Argh!
  2. Sep 24, 2016 at 6:02 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Did you get an alignment post lift?
    It is completely possible to be out of alignment and have your wheels located in different parts of the wheel well.
  3. Sep 24, 2016 at 10:44 PM
    Zebinator
    Norcal
    I did... But I'm going to crawl under it tomorrow and check where the camber adjusters are set...
  4. Sep 25, 2016 at 12:24 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    from what points are you measuring? like from the hub to the bottom of the wheel well or from edge of the tread on the tire to the bottom of the wheel well? 1.5" is alot of difference in ANY case on ANY measurement in my opinion.
  5. Sep 25, 2016 at 1:48 AM
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    When I tried out some spidertrax on my 06.. I noticed my right one would rub ALOT and the left one would rub less..
    I'm thinking it was just poor quality control in the mounting of the inner fender liners in those years......
    I would take measurements from the center of the hub, to the nearest frame cross connect.. those should be exactly perpendicular to the main frame rails..
    Don't trust the cab mounts.....
  6. Sep 26, 2016 at 10:22 AM
    Zebinator
    Norcal
    ah - frame seems to measure out to an 1/8" or so... but the adjusters are totally different, so I'm going to chock it up to that... hoping next time i get it aligned we can fudge the caster so it doesn't rub.
