at 160,xxx im finally going to get a lift
Discussion in 'Suspension' started by mcleod90, Feb 20, 2012.
  1. Feb 20, 2012 at 10:51 PM
    mcleod90
    mcleod90 [OP] 150,000 miles and counting
    sean
    modesto ca
    05 double cab
    i am planning on going with bilsteins up front at 1.75 and then aal in the rear, but since i doubt the rear shocks were ever replaced by the previous owner should i also get some new rear shocks? should i get new coilovers up front?
  2. Feb 20, 2012 at 11:12 PM
    GreenTaco28
    GreenTaco28 Well-Known Member
    Tyler
    Truckee, CA
    01 4x4 SR5
    ARB bumper-Icon 2.5 ext. travel coilovers with King coils and Total Chaos uca's-hella lights-2 12'' JL Audio subs- 285/75/r16 BFG AT's- Marlin Crawler 1.5 in. wheel spacers- Toytec AAL with 5100's in rear-Flowmaster dual exhaust- Black UWS Toolbox- Bushwacker fender flares- Viper alarm system.
    If you get coilovers for the front, it will ride better but they are also much more expensive. If you don't offroad a lot, the 5100's should do fine. For the back if you get an aal, you will need longer shocks anyway. 5100's for the back will work well and if you want to make the back ride even better, you can buy a whole new leaf pack.
  3. Feb 20, 2012 at 11:13 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Budget ?
  4. Feb 21, 2012 at 7:05 AM
    mcleod90
    sean
    modesto ca
    05 double cab
    Thanks for the info. Budget is right around 400-600
  5. Feb 21, 2012 at 7:07 AM
    mcleod90
    sean
    modesto ca
    05 double cab
    I also don't off road a lot since I have a prerunner but I drive off road just not rock crawling.
  6. Feb 22, 2012 at 8:07 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    Anybody else's thoughts?
  7. Feb 23, 2012 at 7:17 AM
    bassfan
    bassfan Well-Known Member
    Fort Worth
    2012 Super White Double Cab TRD Sport
    5100s Eibachs
    5100's all around
    AAL in back or new leafs because yours might be sagging bad after mileage if you haul a load at all
    Maybe eibach springs but I don't see where you said how much lift you are going for or if you want a lot of rake
    That should be close to your budget, not much else you can do and stay within it. Keep in mind you will need front end alignment as well.
  8. Feb 23, 2012 at 8:50 AM
    mcleod90
    sean
    modesto ca
    05 double cab
    If a aal with the front at 1.75" I will still be ass high right?
    Maybe I shouldnt aal right now and just wait to buy a whole new leaf pack that is at stock height that way when I put the front at 1.75" and the new leaf pack I'll be level.
  9. Feb 23, 2012 at 8:56 AM
    705 Taco
    705 Taco Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    I drove mine for 6 months with 2 inches up front (Eibachs and 5100's at .85) and stock rear TSB. Was a little nose high but barely noticable.
  10. Feb 23, 2012 at 5:25 PM
    mcleod90
    sean
    modesto ca
    05 double cab
    I think I'll just go with the original plan of billys on all four corners with the front at 1.75 and then get a 1.5 aal
