At a loss, 2 years of trying to figure out bad shake while braking
Discussion in '1st Gen. Tacomas (1995-2004)' started by optionalstop, Apr 22, 2023.
  1. Apr 24, 2023 at 3:46 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    While driving in safe place pull the parking brake on "slowly" and see if it shakes. That will eliminate the rear brakes if it dosent.
  2. Apr 24, 2023 at 4:45 PM
    optionalstop
    optionalstop [OP] Member
    No, the LSPV was the last thing we tried without any change. It was very rusted away and I doubt it was working. I could try ordering a cheap one and throwing it on I guess.
  3. Apr 25, 2023 at 9:32 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I would reexamine from drive line .....back...
    what about rear wheel bearings...........and rear seals....
  4. May 8, 2023 at 6:26 AM
    optionalstop
    **UPDATE**
    The problem has been resolved and I wanted to provide update and thanks to all for the helpful information. As I said I tried two different brand sets of drums and shoes which were cheaper (but not cheapest). I spent the money and bought Toyota drums and shoes and now the problem is fixed. It just may be that you cannot rely on aftermarket drums for these trucks, I don't know. I'm just glad it's resolved.
  5. May 8, 2023 at 6:38 AM
    Madjik_Man
    Colorado Front Range
    Awesome. Glad you got it figured out.
    And thanks for reporting back. It helps with the information/database TW has become.
    Can you by chance update your first post to include “resolved, it was the drums” or “resolved: see post #24”
    It’ll for sure help someone in the future when they’ve come across your post in a search.
  6. May 8, 2023 at 11:04 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Thanks for the update!!
    I have heard of drum problems before on our Trucks.
    It might be some warehouses store the drums in the wrong position.
    Drums need to be stored flat in the Horizontal position was told this long ago by the different brake reps.
  7. May 8, 2023 at 1:22 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    You can also edit the title of the thread to something like
    2 years of trying to figure out bad shake while braking - fixed!
    Trandoshan-Tickler likes this.
  8. May 10, 2023 at 5:02 PM
    bellybones
    bellybones Member
    1997 2.4 tacoma
    You ought to see this video:
    https://www.youtube.com/watch?v=b125ZBJ3X5E
    I cannot imagine why you took off the tsp and lost it's function, especially if you haul a trailer.
    He talks about what will happen to braking when the tsp is not functioning. Maybe you can buy a used tsp online - https://www.amazon.com/Sensing-Proportioning-Toyota-Tacoma-1995-2004/dp/B07M5SKN5W
    Buy a roll of nickel brake line and good flaring kit.
  9. May 11, 2023 at 1:40 PM
    Bivouac
    Some of us learned to drive before these LSPV`s were every thought of.
    in all my years I have never had a Toyota 4x4 that the LSPV ever worked when the truck came to me.
    Most often the first attempt to bleed brakes broke things.
    Living in the Northeast USA.
    My trucks are used as trucks loaded heavy and towing.
    A simple job to adjust rear brakes for me with the manual valve at the master cylinder.
    If I wanted to be real fancy I could mount it in the cab like the old style brake controls .
  10. May 11, 2023 at 8:26 PM
    O'Silver_Taco
    MD
    Madjik_Man likes this.
  11. May 11, 2023 at 8:30 PM
    O'Silver_Taco
    MD
  12. May 11, 2023 at 11:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Last week I drove a Chevy that had a severely warped drum. As soon as you touched the brake the rear end would shake around so bad I swear the wheels were hopping off the ground
  13. May 12, 2023 at 11:20 AM
    Bivouac
  14. May 12, 2023 at 7:36 PM
    O'Silver_Taco
    MD
    Yeah I would not mind getting rid of that return line.
    I would rather like just flushing the drums out with fresh every couple of years instead of this....returning crap back into the system...
    Weight variance in mine is no more than fifty lbs......so it would be set and forget for me...
    If my load adjuster ever goes out....its not getting replaced..
