AT Drain and Fill - 2018 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nl_tacoma, May 29, 2023.
  1. May 29, 2023 at 5:09 AM
    nl_tacoma
    nl_tacoma [OP] Well-Known Member
    Newfoundland
    2018 Tacoma TRD Sport DCLB
    The transmission / torque converter shudder on my 2018 Tacoma is getting worse so I'm going to do a drain and fill. My local garage is doing this for me. It's a good garage that I trust more than my dealer.
    Question - Is it necessary to pin the transmission cooler thermostat open?
    I've watched a few videos and read a bunch of threads on the topic but I don't have a clear answer on whether it's necessary on my 2018.
    I had the garage check the driveshaft u-joints. All are good. And my mechanic used his scanner to see what the truck is doing when the shudder happens. No misfires recorded. Hopefully the drain and fill fixes the shudder.
  2. May 29, 2023 at 5:15 AM
    Friend of Crows
    Friend of Crows Well-Known Member
    2022 Tacoma SR
    Painted steelies black
    The pin is only relevant if doing a full flush to get all the fluid out. A drain and fill doesn't require messing around with it.
    hokiehunter19 likes this.
  3. May 29, 2023 at 6:39 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    You dont know if you are low on fluid to begin with, so a drain and fill with the same amount would still leave questions.
  4. May 29, 2023 at 6:50 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Yes, pin the thermostat. Here is old Tundra procedure that calls for it. Not sure why Tacoma procedure does not mention it
  5. May 29, 2023 at 11:53 AM
    Abominator
    Abominator Well-Known Member
    2018 Cement TRD Off Road W/ Premium & Tech package
    Blackout , Tonneau, bed mat, bike rack, all weather mats (OEM), LED low beams, Blue LED cabin lights, more stuff to come.
    I pinned mine on my 2018. I did several drain and fills. In between each one I idled the truck and ran through the shifter a couple times. I put in 12 qts of Redline so I got a good % exchanged and it was nice to know my fluid level was good.
  6. May 29, 2023 at 1:18 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    unless you have already addressed it, while up on the rack have them shine a light on the coolant crossover pipe behind the motor. passenger side you can get a visual on the pipe where it connects to the motor. look for pink corrosion.
  7. May 30, 2023 at 4:41 AM
    nl_tacoma
    Newfoundland
    Thanks for replies folks. Got it done. Fluid looked clean coming out. Surprised at how clean it looked actually.
    Transmission shifts are much, much smoother now. The torque converter shudder at low RPMS is also not as bad. At low speeds and RPMS, the transmission will shift down a gear much sooner and before the shudder gets a chance to happen. It's not totally gone but a big improvement.
    I think I will do another drain and fill next week to see if it improve things more. And I'll a look at the crossover pipe then. Thanks for the suggestion.
