AT Habitat, Atlas, & Summit Pictures, ideas, aaand BS
Discussion in 'Tonneau Covers, Caps and Shells' started by excorcist, Feb 5, 2018.
  1. Sep 4, 2020 at 9:48 AM
    #2481
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Ah yeah, i see that now. I doubt that would be very effective on the habitat due to the volume of the internal space.
  2. Sep 4, 2020 at 9:53 AM
    #2482
    Graton
    Graton Well-Known Member
    Berkshires - Massachusetts
    Exactly, that's why I'm thinking of doing a half liner, which would end just a little past the bed and I would run the Propex heat pipe into that - but I would really like something that could heat the entire volume, that way we could go XC skiing or snowshoeing and come back to the Habitat and warm up for a bit.
  3. Sep 4, 2020 at 9:54 AM
    #2483
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    AH that would be sweet!
  4. Sep 4, 2020 at 10:28 AM
    #2484
    Shellshock
    Iowa
    that’s what XO did. They had a divider made and then piped heat into the half they were sleeping in. It’s in one of their newer videos with the trip they just did up north
  5. Sep 4, 2020 at 12:08 PM
    #2485
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Do you know what size rivnuts would be best?
    sawbladeduller likes this.
  6. Sep 4, 2020 at 12:23 PM
    #2486
    andrewtheadventurer
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Depends on what you are mounting but you can check the base of your center inner support pole for the size AT uses.
  7. Sep 4, 2020 at 1:49 PM
    #2487
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    i've used the 1/4-20 steel, the length of shaft is slightly longer than 1/2 inch
  8. Sep 4, 2020 at 2:00 PM
    #2488
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Ok cool. And they attach to the inside walls pretty well? The surface seems like it is a fairly soft honeycomb style material.
  9. Sep 4, 2020 at 3:54 PM
    #2489
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    on my Habitat, there is an aluminum sandwich panel, the honey comb is 'waxy' looking and easily displaced with a bit. The riv-nut crimps up on the back side of the surface. The drill size for the riv-nut is debatable imo. I found that a step bit gave me better control over hole size and depth. On a section of inside wall I placed an aproximate 24"x24" plywood panel with six riv-nuts. on the panel i have mounted several pounds of electronic devices. so far the panel holds.
    excorcist[OP] likes this.
  10. Sep 4, 2020 at 4:58 PM
    #2490
    excorcist
    excorcist [OP] Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    I was kind of wondering how the panels are adhered to each other (or rather how the honeycomb is is attached to each panel holding them together).. I have some l track attached with rivnuts on inside hab wall and some things hanging from it like camp chairs and the water heater. Has been solid but in hindsight it would probably have been smarter to sandwich the two panels with the l track.
  11. Sep 4, 2020 at 5:15 PM
    #2491
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    agree. i thought about drilling thru completely, attaching L-track both sides as the most secure means of hold down. However....my experience with drilling thru panels is that HANDHELD...I can not accurately angle the bit...to get accurate holes...therefore impossible to do. a portable Milwaukee magnetic drill press would do it consistently...but on aluminum?
  12. Sep 10, 2020 at 4:55 PM
    #2492
    Babish_SD
    Babish_SD Well-Known Member
    Brian
    2016 Quicksand Tacoma TRD Sport
    finally got install confirmation date for my Atlas! October 27th this is about to be a long month and a half
  13. Sep 11, 2020 at 1:56 PM
    #2493
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    Hey guys, long time no talk. Looks like I'll be getting a bigger truck, so I gotta get rid of the Habitat... where's the best place to list it?
  14. Sep 11, 2020 at 2:44 PM
    #2494
    Shellshock
    Iowa
    Here, B/S/T and expedition portal
    MacFly[QUOTED] likes this.
  15. Sep 12, 2020 at 3:03 PM
    #2495
    excorcist
    Reno, NV
    sawbladeduller and HomerTaco like this.
  16. Sep 12, 2020 at 3:27 PM
    #2496
    corprin
    corprin Well-Known Member
    corprin
    I used to roll up the window on my old rooftop tent, rest my 21lb .260 rifle on my pack, while staying snug and warm in my fart sack.
    The forward end end of the hab would make a great blind.
    Shellshock likes this.
  17. Sep 12, 2020 at 6:52 PM
    #2497
    excorcist
    Reno, NV
    It would, I had the same thoughts on an elk hunt a couple years ago, but I gave up trying to figure out if it was legal or not here in nevada to shoot from the bed of a stationary vehicle.
  18. Sep 23, 2020 at 4:38 PM
    #2498
    Babish_SD
    Brian
  19. Oct 6, 2020 at 7:07 PM
    #2499
    STravis
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    For everybody with an Atlas... Do you sleep with your head towards the front of the truck or the rear?
  20. Oct 6, 2020 at 7:41 PM
    #2500
    1G3_Tommy
    1G3_Tommy Well-Known Member
    MGM DCSB TRD OR
    Towards the front. Mostly because its easier to climb up and down right into sleeping position. I do like the crossbreeze from the windows being right by your head with my feet facing forward. Thats my hangout position lol.
