AT Habitat, Atlas, & Summit Pictures, ideas, aaand BS
Discussion in 'Tonneau Covers, Caps and Shells' started by excorcist, Feb 5, 2018.
  1. May 20, 2018 at 11:47 PM
    #321
    ethompson02
    ethompson02 Well-Known Member
    Castle Rock, CO
    2017 TRD Off-Road Tacoma and 2018 TRD Off-Road 4Runner
    Tacoma - RCI Bed Rack, RCI IFS Skid Plate, RCI Rock Sliders, Odin Designs RTT, ICON Rebound Wheels, 275/70/17/ BGF KO2s, TRD Pro Grill, Prinsu Roof Rack, ARB 2500 Awning 4Runner - TRD Pro Wheels, 265/70/17 Duratracs
    What are people using to cut their Prinsu rack to make it fit? I don't really want to sell the rack and want to make it work somehow.
    excorcist[OP] likes this.
  2. May 21, 2018 at 8:32 AM
    #322
    excorcist
    excorcist [OP] Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    I used a jigsaw.
    tacofort likes this.
  3. May 21, 2018 at 12:55 PM
    #323
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    There are a couple of ways to make this happen.
    If you have a plasma, you can build a jig to easily trace/cut the entire section off. Then you'll use a deburring tool or a sanding block to make it nice again.
    The other choice would be to use a band saw. The bigger the blade the less it'll wander, and then you can use a square aluminum extrusion as a sanding block.
    A jigsaw is doable, but I know I suck pretty bad and at keeping things straight, so I'd like to stick w/ whatever sure thing that's reasonable for me. I picked up a used plasma, so that's probably going to be my choice.
    ethompson02[QUOTED] likes this.
  4. May 21, 2018 at 1:29 PM
    #324
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    You could also use an angle grinder with a cutoff wheel, leave some excess on your cuts, file and sand until correct.
    Edit: Also if you have access to a notcher, shear, nibbler, mill or iron worker.
  5. May 21, 2018 at 1:45 PM
    #325
    kalieaire
    Santa Clara County
    :rofl:
    tacofort[QUOTED] likes this.
  6. May 21, 2018 at 1:47 PM
    #326
    tacofort
    Joe
    Cincinnati, OH
    Legit, I have access to any of these, just need to make a phone call, but most of them are an hour away.
  7. May 21, 2018 at 10:12 PM
    #327
    ethompson02
    Castle Rock, CO
    I have a feeling I would royally mess all of this up If I tried it myself. Maybe I'll just end up selling the Prinsu and going a different route.
  8. May 21, 2018 at 11:55 PM
    #328
    kalieaire
    Santa Clara County
    oh yea, a router bit w/ a ballbearing w/ a jig probably works better than a plasma for this since it's chipping away at the aluminum vs melting it. should be a cleaner choice. if you cut using a jig w/ things properly bolted down, it should be pretty quick and easy.
  9. May 22, 2018 at 5:00 AM
    #329
    corprin
    corprin Well-Known Member
    corprin
    Abrasive cut off and grinding/sanding wheels gum up with aluminum.
    Best way using a commonly owned tool is a fine-toothed jigsaw. Bolt down the sidemplates to a piece of plywood that you can sacrifice and cover in blue painters tape.
    Should take no more than 2min each side.
  10. May 22, 2018 at 8:48 AM
    #330
    Moogle
    Moogle Dyslexic Stanist
    Glen
    Alameda, CA
    07 Silver TRD Sport DCSB 4x4 6-speed
    Blood of virgins
    If it's aluminum why not just use a chop saw with a non-ferrous metal blade.
  11. May 22, 2018 at 8:54 AM
    #331
    corprin
    corprin
    Is he trimming or hacking the end off?
    If just hacking, chopnsaw or metal blade on a band saw.
  12. May 22, 2018 at 11:00 AM
    #332
    Moogle
    Glen
    Alameda, CA
    Blood of virgins
    Oh, I was assuming he was going to cut the rear half off.
  13. May 24, 2018 at 10:39 AM
    #333
    IanAlpinist
    IanAlpinist Active Member
    1999 Tacoma V6 super charged, 2016 Tacoma TRD Off-road DCLB
    I am about to pull the trigger and order my Habitat but was wondering if there are any add ons that you wish you had gotten or wish you had not? So far this is what I am thinking: hatch door on either side, L track on roof (I will build my own rack), and paint. I will run my own electrical and put in my own carpet once that is done. Looking forward to your thoughts?
  14. May 24, 2018 at 10:48 AM
    #334
    tacofort
    Joe
    Cincinnati, OH
    The awning is pretty great, but can be bought later. My buddy has it and I recently ordered it. I got windows front and rear, to each their own. I think you have a pretty solid list. Where are you out of?
  15. May 24, 2018 at 10:53 AM
    #335
    kalieaire
    Santa Clara County
    There aren't any add-ons that I couldn't "add-on" myself. That said, getting the base model was perfect.
  16. May 24, 2018 at 11:23 AM
    #336
    IanAlpinist
    Yeah the awning look pretty cool but somethings are hard to commit to without seeing it first. I live in Durango, Colorado. Thanks for the reply.
  17. May 24, 2018 at 11:30 AM
    #337
    Moogle
    Glen
    Alameda, CA
    Blood of virgins
    Haven't seen this awning, is it the Nemo one on their sight?
  18. May 24, 2018 at 11:40 AM
    #338
    tacofort
    Joe
    Cincinnati, OH
    Yup. Pretty easy to rig off of any side of the habitat, or straight out the back end of the overhang. I'll take some pictures when mine comes next week after I set up. It's hand for more basecamp stuff to get some shade. Won't use every trip, but on a rainy or high sun trip, could be worth it's weight in gold.
    Edit: We'd tie his straight off the end of the roof rack when the habitat was opened.
  19. May 24, 2018 at 12:04 PM
    #339
    tacofort
    Joe
    Cincinnati, OH
    Also there has been 3 iterations of side hatch doors I've seen. The older version white ones that open downward used in Expedition overland and early builds. A newer aluminum panel I have seen on more recently built habitats that looks slick and has a gas strut opens up. Lastly, there looks to be a new window that opens outward and upward for the rear I saw in a few pics that they are putting on the Summit (AT Overland's wedge style camper), not certain how this works but may have removable screen due to below article.
    https://expeditionportal.com/first-impressions-at-overland-summit-camper/
    What does everyone think of the summit?
    (I'd still get a habitat)
  20. May 24, 2018 at 12:48 PM
    #340
    IanAlpinist
    Mario at AT and I have been exchanging emails the new hatch door it composite and is made by the same company that is making their new window. The idea of having a window sounds nice but I like the security of no window besides doesn’t the tent have a ton of windows anyway? A11FDE3D-77B1-4D76-9A29-05373A83A8A3.jpgB09296B5-F21E-422C-B50D-EE179C37A2C5.jpg
    I had a wildernest for awhile on my 1st gen back in college before I bought the camper shell and have 4 friends that have flippacs and the habitat just looks far superior to all of those. The new summit looks nice but I can’t see giving up the internal space and external awning the habitat is going to provides.
