AT Habitat, Atlas, & Summit Pictures, ideas, aaand BS
Discussion in 'Tonneau Covers, Caps and Shells' started by excorcist, Feb 5, 2018.
  1. Oct 24, 2018 at 9:32 AM
    #801
    Graton
    Graton Well-Known Member
    Berkshires - Massachusetts
    jlow95 - I've had a Habitat on my Tacoma for about a 1.5 years in a number of conditions, but not snow.
    1- No room when folded, but we just use a double bag and roll it up and leave it in the truck bed - takes about 30 seconds. I might be possible to leave the sheets up there, if you figure out some way to strap it down - likely not worth it. Pillows have to come down.
    2- I think it would be difficult to get all the snow off, but I've not camped in snow with the Habitat. You could likely displace most of the snow from the inside, the height of the Habitat would make more difficult to clear everything off before folding. Hopefully some other owners have experience and can chime in. Given that the Habitat is just a tent, it will be cold - any plans on heating it?
    3- Habitat is very strong, no swaying or teetering when we are in it - me, GF, and dog.
    Given your needs, I'm not sure the Habitat is the best choice. Have you considered the AT Summit, Vagabond, or GoFast? Or even just get a camper shell - FWC for example - and keep it light.
    jlow95 and YF_Ryan like this.
  2. Oct 24, 2018 at 9:32 AM
    #802
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I can only really help with your first question. There is next to no space when you fold it closed. You could probably leave a fitted sheet on the mattress but that's about it. It folds tight. Also, if you don't have the full platform that makes the second sleeping area, anything on the bed that wasn't attached would just slide off the bed and into the truck bed when you are closing the Habitat.
    I've accidentally left the panel included with the habitat on the shelf over the cab and it was EXTREMELY tight to get the latch shut. And that's only like 3/4 or 1 inch.
    jlow95[QUOTED] likes this.
  3. Oct 24, 2018 at 9:35 AM
    #803
    YF_Ryan
    Kent, WA
    I'm going to second the AT Summit. Sounds like it would better fit the bill for that type of traveling.
  4. Oct 24, 2018 at 9:51 AM
    #804
    jlow95
    jlow95 New Member
    Josh
    Not worried about the cold that much. I have a -40 bag and a large down blanket. Hasn't been an issue in the past for sleeping.
    I've been looking at the wedge tops a fair amount as well. Hoping to make an upgrade to something that I can stand up inside which those cover, however the Habitat or a flippac would be nice for the extra room and ability to use the bed of the truck while my actual bed is available. Because of the cold I'm planning to build a small countertop in the truck bed (similar to the Goose Gear build) and cook inside.
    The choice between a Habitat and a wedge top is purely comfort and space unless y'all have some other suggestions/pointers/remarks.
    EDIT: The AT Summit has an optional thermal liner for the cold!
    Thanks everyone for the quick replies by the way!
    I guess a small follow-up question would be if the wedge tops allow you to keep your bedding "made" minus the actual bed being deconstructed?
    EDIT: AT Summit does allow you to leave bedding inside.
  5. Oct 24, 2018 at 9:56 AM
    #805
    jlow95
    jlow95 New Member
    Josh
    My other concern with the Summit was that it's priced the same as the Habitat. Why not choose the roomier option?
  6. Oct 24, 2018 at 10:02 AM
    #806
    excorcist
    excorcist [OP] Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    We camp the same way, pretty much moving camp every day.
    The wind will move the truck a little with habitat acting as a sail, if it gets too windy you always have the option of keeping habitat closed and sleeping in bed of truck.
    The trucks rear leaf springs will cause it to teeter a little with the weight on the fold out... but honestly its not worth worrying about imo. I move alot when I sleep and it has never bothered me. If it does you can always sleep with your heads towards the front of truck and that will negate most of the movement.
    With the cold temps, imo you will be fine packing the habitat away with a little snow / wetness still on the habitat as long as you don't plan on parking with it closed while wet for more than a couple days, just open it up and dry it out when you first get a chance.
    Pillows and blanket definitely a no go.. We carry a tote with 2 full size pillows, a double sleeping bag, and a memory foam mattress topper.
    Lasty Imo I think your making the right choice as far as model, I couldnt trade the space in the habitat for one of the wedge style campers.
    jlow95 likes this.
  7. Oct 24, 2018 at 10:06 AM
    #807
    YF_Ryan
    Kent, WA
    I do think the Summit has its place. and the price is probably due to things like the window/skylight, and the different style bed platform and longer overhang over cab.
    But if @excorcist says the snow issue doesn't exist... GO HABITAT! The interior space is awesome.
  8. Oct 24, 2018 at 10:10 AM
    #808
    excorcist
    Reno, NV
    If the one consideration was capability in snowy situations, than definitely a hard top wedge camper would win... but taking everything into consideration Habitat FTW :)
  9. Oct 24, 2018 at 10:21 AM
    #809
    jlow95
    jlow95 New Member
    Josh
    Snow falls occasionally, but for the most part it should be dry. Bishop, CA is likely the snowiest place I'd be in the winter; someone already posted a picture of their Habitat rig there on here too.
  10. Oct 24, 2018 at 10:34 AM
    #810
    YF_Ryan
    Kent, WA
    @excorcist , Do you by chance have any pictures with your awning open? i just scanned through like 12 pages and thought it might be easier to just ask :)
  11. Oct 24, 2018 at 11:02 AM
    #811
    excorcist
    Reno, NV
    Just looked through my phone, don't have any from ground level but here are a couple from my drone
  12. Oct 24, 2018 at 11:11 AM
    #812
    YF_Ryan
    Kent, WA
    Was hoping for from ground level, but no big deal. Thanks for looking. Isn't it funny how you can go back through pics and be like... how did I not take a picture of that? I really need to get better about taking pics.
  13. Oct 24, 2018 at 11:45 AM
    #813
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    Check My build. I went HD Dakars with an extra leaf, may end up getting a custom deaver pack long term.
  14. Oct 24, 2018 at 11:58 AM
    #814
    tacofort
    Joe
    Cincinnati, OH
    I can open the tailgate with the hatch closed or vice versa. No worries.
    https://www.amazon.com/gp/product/B06XFM6LZ3/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    I ordered this but in black. Replace it once a year. Piece of cake. This was more flexible for opening that the supplied bulb seal.
  15. Oct 24, 2018 at 11:59 AM
    #815
    tacofort
    Joe
    Cincinnati, OH
    I too have experienced this. Lol.
    Thunderaz17 and YF_Ryan[QUOTED] like this.
  16. Oct 24, 2018 at 10:10 PM
    #816
    MacFly
    MacFly Well-Known Member
    2018 Cement Tacoma TRD Off Road AT
    OVTune, AT Habitat, Firestone RRs, ARB CKMA12 compressor
    Oops, forgot to reply, my bad. I have the 6 ft bed, I don't think I could ever sacrifice it for cab space. I figure I got a truck to move stuff, not people.
  17. Oct 24, 2018 at 10:15 PM
    #817
    MacFly
    Sooo.... I got word today about a tentative install date of 2 Nov!! :goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy::goingcrazy:
    YF_Ryan and excorcist[OP] like this.
  18. Oct 25, 2018 at 6:00 AM
    #818
    Built2Ride
    Built2Ride Who wants to ride out?! PM Me.
    JB
    Southeast
    ‘17 TacoTRDPro, ‘18 T4RTRDPro, ‘12 Tundra, ‘07 FJC
    All my rigs are purpose built. From crawling to camping. I also enjoy a nice stock truck for what that’s worth. Toyota’s are the jam!
    Thanks man. I will check it out for sure.
  19. Oct 25, 2018 at 6:27 AM
    #819
    corprin
    corprin Well-Known Member
    corprin
    Was like that for a while. Then I had a couple kids.
    YF_Ryan likes this.
  20. Oct 25, 2018 at 7:19 AM
    #820
    YF_Ryan
    Kent, WA
    Hey... that's a Friday... that mean you will be out camping with it that night, too?
