AT/Temp fluid temp mode to check transmission fluid level
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gabericks1, Jun 3, 2025.
  1. Jun 3, 2025 at 6:47 PM
    Gabericks1
    Gabericks1 [OP] Member
    Gabe
    2006 Tacoma Offroad
    None
    So I'm trying to check my transmission fluid level level. Trying to put my Tacoma in fluid temp mode. I've wired a slot 4 & 13 And shifted through other gears and gone between neutral and park multiple times. I can't get the light to come on AT Temp light to flash on and then stay on when it gets to temperature
    Could it be because my check engine light is on? The check engine light is on because of a catalytic converter code
    Thanks
  2. Jun 3, 2025 at 7:37 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Are you sure you have the right OBD pins jumped? I ask because some diagrams show the connector upside down from the actual orientation on the truck.
  3. Jun 3, 2025 at 7:48 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I over fill mine by a quart…shift through the gears,soon as the pan feels warm to the touch,I pull the check plug.
  4. Jun 3, 2025 at 7:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have scan tool or scangauge that you can read temp with? That's the easiest way, temp should be 97-115F to check.
    Micbt25 and HondaGM like this.
  5. Jun 3, 2025 at 8:20 PM
    RockinU
    RockinU Well-Known Member
    Texas
    I think the shift sequence is N to D 6 times then to park
    HondaGM likes this.
  6. Jun 4, 2025 at 11:22 AM
    Gabericks1
    Gabe
    2006 Tacoma Offroad
    None
    I'm using the correct pin locations
    My timing is exactly from neutral to drive as the video
    My biggest question is, will a Tacoma go into fluid temp check mode if the check engine light is on.
    I know a check engine light affects other things like cruise control.
    Thanks
    HondaGM[QUOTED] likes this.
  7. Jun 4, 2025 at 11:29 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    I can't answer that one,maybe somebody will chime in...but I've never done that method on any of my toyota's.
  8. Jun 4, 2025 at 11:37 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The CEL should not keep it from going into temp check mode, unless you have a a transmission related code.
    The easiest way to do it is with a scan tool. Well worth the money. But in your case, you kind of need this done “now”.
    Micbt25 likes this.
  9. Jun 4, 2025 at 11:47 AM
    ieizxxnsaeomeostfd
    ieizxxnsaeomeostfd Well-Known Member
    2014 Tacoma Base
    ARB Bumper Warn winch Icon lift 35s
    When I did mine (2014) I vaguely remember having to go faster between the gear changes than is shown in the video.
  10. Jun 4, 2025 at 12:14 PM
    Gabericks1
    Gabe
    2006 Tacoma Offroad
    None
    My diagnostics tool is borrowed at the moment so I'm going to run by advance Auto. Get them to clear my codes, get home quick and see if I can put it into temperature check mode.
  11. Jun 4, 2025 at 12:22 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    IF you take the Tacoma it will be too warm to put in temp check mode when you get back. You will need to do it first thing in the morning.
  12. Jun 4, 2025 at 1:21 PM
    RockinU
    Texas
    100% this. And they don’t cool down super quick.
  13. Jun 4, 2025 at 4:23 PM
    Gabericks1
    Gabe
    2006 Tacoma Offroad
    None
    Yes, you would be right on the temperature being too hot by the time I got home. I did borrow a scan tool that cleared the codes. Still can't get it into temperature check mode.
  14. Jun 4, 2025 at 4:28 PM
    Gabericks1
    Gabe
    2006 Tacoma Offroad
    None
    It just came on! No excuses, no explanations. I tried shifting fast, I tried shifting slow, and when I started shifting like I didn't care it came on, But it was blinking so it was too hot
    2015WhiteOR likes this.
  15. Jun 4, 2025 at 4:37 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    When I did my daughter's Corolla, I did the shift sequence then laid on the creeper near the tranny pan and kept shooting it with an infrared pyrometer.
    When I was in range with that, I pulled the plug and let the excess run out.
    Those infrared pyrometers are great for a lot of things like checking hubs from sided to side, the temperature of your oils and fats when making soap....... etc.
  16. Jun 4, 2025 at 5:53 PM
    spitdog
    You will always be able to do it now. Once you get it in temp mode you kinda figure something out and then you will always be able to do it.
  17. Jun 5, 2025 at 11:54 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    I never could get that temp mode to work either. Maybe it doesn't work on older Tacomas? Been using an IR thermometer on the transmission pan instead. Works fine and much easier.
  18. Jun 5, 2025 at 5:32 PM
    RockinU
    Texas
    Does anyone know if the procedure is the same for Fj’s? Need to do my daughter’s ‘07 this weekend…
  19. Jun 5, 2025 at 6:49 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I always use an OBD2 bluetooth reader and OBD Fusion app for the trans temp.
    BTO likes this.
  20. Jun 5, 2025 at 7:12 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea should be identical, I believe the 07-08 FJ has the wrong temp spec listed/programmed as well though just like 05-08 Tacoma's.
    Should be 97-115F instead of 115-130F.
    RockinU[QUOTED] likes this.
