At what point do i need new rear shocks?
Discussion in '1st Gen. Tacomas (1995-2004)' started by boybands are lame, Oct 20, 2010.
  1. Oct 20, 2010 at 4:10 PM
    boybands are lame
    boybands are lame [OP] Well-Known Member
    california
    01 prerunner sr5
    at the moment i have bilsteins up front on the middle setting and the front sits slightly higher than the rear by about half an inch. I eventually want to move the billies in the front to the highest setting and add and inch to the rear hoping that it will sit in the same stance that it does now only and inch higher. i was thinking about a simple U-bolt and block would do the trick. Would i need to put in new rear shocks?
  2. Oct 20, 2010 at 4:12 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    If they ride fine then no. But you might as well. They are not too expensive and it's and easy install. And most will say to get an aal instead of a block.
  3. Oct 20, 2010 at 7:27 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    stand on your bumper and jump. if you can bottom it out then replace them..
  4. Oct 20, 2010 at 7:48 PM
    pittim
    pittim mittip backwards
    Mk7 TDI
    Permanent CEL
    you live in CA
    crank the fronts to the very top
    and lower the rear.
  5. Oct 20, 2010 at 7:51 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    You don't really need new shocks. As long as you don't fully compress your shocks before hitting the bumps you should be fine.
  6. Oct 20, 2010 at 11:11 PM
    scocar
    scocar Treat the cause, not the symptom
    Ricardo
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Dude, that's only Socal.
    OP, please tell us if you are from Socal or Norcal so we can be more helpful.
    Oh, wait, he does have a Prerunner..., so you are prolly right, pittim.:D
  7. Oct 21, 2010 at 11:46 AM
    boybands are lame
    california
    01 prerunner sr5
    i hate to say it but i am so cal :(
  8. Oct 21, 2010 at 11:49 AM
    boybands are lame
    california
    01 prerunner sr5
    so is there any really damage i can cause to my truck my not putting in new rear springs? or it just a matter of comfort and flex?
  9. Oct 21, 2010 at 11:52 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just do an AAL that should stiffen your ride up a little. then add some 5100's later.
  10. Oct 21, 2010 at 1:45 PM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    2004 PreRunner Xtra Cab
    STOCK
    agreed, unless your leafs got a nice frown in them. If thats the case, its time for a replacement pair.
  11. Oct 21, 2010 at 2:37 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Do you want a stiffer ride, or a smooth ride?
    You can reuse your stock rear shocks, but what can happen is you can sometimes feel them top out (reach full extension) after lifting the rear. That is why most people also get longer shocks with the rear lift.
