At what point do I need to upgrade?
Discussion in 'Towing' started by Florida Man, Mar 5, 2018.
  1. Mar 5, 2018 at 9:09 AM
    Florida Man
    Florida Man [OP] Member
    Al
    2017 2wd dual cab plain jane
    None! (so far...)
    I have a 2017 SR double cab as stock as can be so no tow package or anything like that.
    At present I'm not towing all that much. A single-axle utility trailer with homemade stake sides and gate. I'm guessing about 1,100lbs or so empty.
    I believe I should be able to safely pull up to 3,500lbs gross weight, shouldn't I? Don't foresee approaching that with my current trailer.
    But I am considering a bigger trailer so what I need to know is at what point would I be well served in bulking up the leaf springs and possibly adding a transmission/motor oil cooler?
    I tend to keep a vehicle until the wheels fall off so I don't want to put a lot of unnecessary stress on this one. If I go to a larger trailer and come close to pushing the envelope I'll beef it up. But at what point do I need to start considering this?
  2. Mar 5, 2018 at 9:16 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    You can do any and all of that but it won’t increase the manufacturer weight and tow specifications.
    As long as you don’t exceed manu specs you are good. Adding the tranny cooler, oil cooler and better springs is a good idea especially if you are towing at or close to the limit. It will prolong engine and tranny life.
  3. Mar 5, 2018 at 9:21 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    If you do not have a tow package, how are you towing? Did you add a factory or aftermarket receiver? An aftermarket bumper with built in receiver?
    Your current tow capacity depends upon your equipment.
  4. Mar 5, 2018 at 9:33 AM
    Florida Man
    Al
    None! (so far...)
  5. Mar 7, 2018 at 7:41 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Florida Man[OP] likes this.
