At what point does over filling oil become dangerous?
Discussion in 'Technical Chat' started by sa1126, Apr 21, 2016.
  1. Apr 21, 2016 at 7:18 AM
    sa1126
    sa1126 [OP] Active Member
    San Antonio, TX
    2001 Prerunner 3RZ-FE
    I got an oil change a while back and they overfilled it quite a bit, seems to be pretty common and that is why I started doing my own oil changes.
    At what point does fatal damage start to occur? Ounces over? Half a quart? Full quart?
  2. Apr 21, 2016 at 8:28 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Only when it is so full it starts to contact the crank, which will aerate the oil and turn it foamy. Not NEARLY as good a lubricant then and the pump doesn't pump it as well. A quart won't be near enough.
  3. Apr 24, 2016 at 9:23 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Question you should be asking is did they drain my transmission and fill my oil?
    If it's overfilled by quite a bit I would be thinking that they fucked up.
    When you crawl under your truck the trans pan is right there looking you in the face, the oil pan is kind of hidden between the crossmembers for the front diff.
