ATENTION ULTRA GAUGE USERS......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck 2.7, Feb 3, 2014.
  1. Feb 3, 2014 at 7:13 PM
    tacotruck 2.7
    tacotruck 2.7 [OP] Well-Known Member
    Katy TX
    09 cab and a half 2.7
    I would like to know is there a UG process for disconecting and reconecting your battery ? 09 taco 2.7 base ; Crazy question I know but ever since I installed this UG and for any reason I disconect my battery it seems I have to cycle turning it off and on and or disconect the UG otherwise my voltage drops to 11.7 and rpms drop to 460 and it has stalled. Perhaps I did not read all the instructions like I should have. One thing for shure it never did that before UG. Hell I even had the alternator bench checked it was ok thank God. Anyone else experienced this. ????? Let me know please. Thanks
  2. Feb 3, 2014 at 10:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Your question isn't making much sense to me.
    You are saying since you installed the Ultra Gauge when you disconnect the battery you battery voltage drops to 11.7 volts and the RPM Drops to 460 RPM.
    I don't know what you mean by cycling it off and on or disconnect the Ultra Gauge...
    See if you can word it a little different.
  3. Feb 3, 2014 at 10:27 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Disconnecting the battery for 10+ mins resets the ecu and everything
    Once you reconnect it the computer needs to go through all the sensors and checks it does so aka your rpms are low, voltage low and yea can cause the truck to turn off
    (Mine does this about every so often after reseting the ecu)
    It just something it does to get all the systems back up and running should go away after driving a good 7-15 miles or so
  4. Feb 4, 2014 at 7:00 AM
    tacotruck 2.7
    Katy TX
    Mr. Thank you very much I never noticed it before thus I thought the UG was suspect and making me go nuts. Thanks alot BTW how did come across this info is it in the owners man ?
