ATF Change?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Silver Lake Taco, May 30, 2025 at 1:20 PM.
  1. May 30, 2025 at 1:20 PM
    Silver Lake Taco
    Silver Lake Taco [OP] Member
    Gordon
    2001 Silver Tacoma SR5
    Is there an ATF change/refill mileage recommendation? I’ve got a 2001 base Tacoma 2WD automatic with 89K miles. No apparent problems but i believe in service before problems occur. What’s your thoughts? Mileage or time? Flush service at a transmission shop like I’ve seen advertised? Is it a simple thing to do yourself (I’ve done it before on many occasions) or the usual sloppy job that needs a bathtub size drain pan to keep the garage floor in some semblance of decency?
  2. May 30, 2025 at 2:17 PM
    02hilux
    Planet: EARTH
    I drained and filled mine annually regardless of mileage. Valoline is cheap enough not to dent the wallet.
  3. May 30, 2025 at 2:18 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Mine every 20-25k
  4. May 30, 2025 at 4:34 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Check the transmission fluid level to make sure it's ok. If you remove the drain plug it should be around 4 quarts that drains out. Whatever comes out, just replace it. You can do it in 30 minutes.
    Some do it every 25k mi. and some just let it go over 100k mi. I think the recommended mileage is 50 or 60k mi.
    TN1000 likes this.
  5. May 30, 2025 at 7:03 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    If it were my truck I would drop the tranny pan, clean it and the 3 magnets replace the filter/screen then refill with new ATF and a bottle of LubeGuard
  6. May 30, 2025 at 10:49 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    with the little 2.4 you're only gonna get 2 qts out of the pan...
    thats about 20% (2rz~8.5qts)........thats what I do every year
    at end of 5yrs its pretty much turned over
    takes less than 10min
    might would double down an do every 6mo......for two or three changes to catch up
    flushes are from the the old big '8' days.....jap tranny's are electronic shift and dont need flushes
    the filter is just a coarse mesh screen.....you'd have to drive 300K for it to catch enough to mess with
    .....that is as long as you continue the 5yr cycle
    I recommend getting one of those magnetic inline filters and swap every 5yr
  7. May 30, 2025 at 11:13 PM
    MGMDesertTaco
    Never flush, drain and fill only. Multiple drains and fills will help.
  8. Jun 2, 2025 at 11:24 AM
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
