ATF Cooler on 2022 Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRancher, Sep 17, 2022.
  1. Sep 18, 2022 at 10:25 AM
    #41
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    Interesting; does anybody have a picture or two of the plumbing for that system, or better still, a technical document from Toyota which shows a diagram of the system and its plumbing?
  2. Sep 18, 2022 at 12:02 PM
    #42
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the trans fluid is cooled in the radiator - been doing it this way for 60+ years
  3. Sep 18, 2022 at 12:06 PM
    #43
    kona61
    kona61 Well-Known Member
    J
    LR 2022 Tacoma TRD OR
    RCI Skids
    Yea. Almost every single auto car has this setup.
    I will say, the Taco still has the thermostat which to me is the most important part. You can add back a bigger cooler and not deal with the issues of ATF over-cooling (not serious like engine oil temp but high viscosity ATF still not great). It's my biggest complaint with out 5th gen 4Runner since you can't really add a cooler without having some tradeoff in cold temps. Only solution for those is an external thermostat or a cooler with a bypass tract (a-la Hayden Rapid Cool).
  4. Sep 18, 2022 at 12:11 PM
    #44
    RIX TUX
    there are 2 types of trans cooling they use, one is pipes in the radiator and one with a small air cooled radiator......on the window sticker they just are not specific what kind it is........in 2020 they switched what type they use
  5. Sep 18, 2022 at 12:35 PM
    #45
    RIX TUX
  6. Sep 18, 2022 at 12:49 PM
    #46
    RIX TUX
    EXACTY .......it is still a cooler, its just in the radiator(which always has a big fan blowing on it) .....toyota is not trying to be deceptive at all.......it may be better than an external cooler.....who knows......the ones wanting to sue toyota should move on to the transmission shift points or mpg
  7. Sep 18, 2022 at 12:56 PM
    #47
    RIX TUX
    here you go
    for that peace of mind you need
    Woodythebluetaco likes this.
  8. Sep 18, 2022 at 1:04 PM
    #48
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    ^^ sir I think you made your point.
  9. Sep 18, 2022 at 2:47 PM
    #49
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    They didn't switch what kind they used in 20. They stopped adding the secondary external cooler. Both have radiator cooler.
  10. Sep 18, 2022 at 5:55 PM
    #50
    Woodythebluetaco
    Woodythebluetaco Well-Known Member
    2016 Tacoma SR5 Blazing Blue
    Stacked plate transmission cooler Front: Custom Fabtech 2.25 Resi Coilovers, King springs, Eibach Tenders Rear: Fox 2.0 Resi, Custom OME Dakar Leafs, Caltracs Rebuilt 3.5
    My 16’s OEM cooler lines are thermostatically controlled, I would assume the updated cooler would be also. It’s what made me comfortable putting a fat stacked plate cooler in place of the oem unit. Gets cooler faster than the small oem unit but still operates by the stock thermal switch.
    Plus it looks cool imo
  11. Apr 4, 2024 at 8:31 AM
    #51
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Can someone clarify if the 3rd gen (maybe 4th gen also) automatics have a thermostat built into the transmission to control ATF cooling? And what temp does it open? Saw mention that it could be pinned open.
    the A750F in my 2015 doesn't so i added a oil 180F thermostat to control flow to my added air/oil cooler. Temp never gets above 175 and thermostat keeps it from running to cool in the winter.
  12. Apr 4, 2024 at 9:14 AM
    #52
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    Radiator ATF cooling has existed in my personal hands-on experience since the 1958 Chevy Nomad my Dad owned.
    In the 70s, every Toyota automatic I worked on as a dealership tech, had radiator ATF cooling.
    The difference: back then, water temps routinely operated at 165~180 degrees, which is ideal for ATF operating temperatures.
    The smoggers of today operate in the 210~220 degree range, meaning ATF temps are raised in a similar manner.
    Add in a tow load and a hot summer day, towing up hill and you have a recipe for high temps.
    I would like to add a ScanGuage tool to monitor my rig and keep ATF at 180 degrees.
    Sadly here in CA this is an open invitation to thieves to smash out a window and steal it.
    Tacoma2Tough and Topanga Taco like this.
  13. Apr 4, 2024 at 4:57 PM
    #53
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    the difference is the window sticker versus the sales brochure material.
    The sales brochure material is outdated
    Tacoma2Tough likes this.
  14. Apr 4, 2024 at 5:22 PM
    #54
    Da Voke
    Da Voke Well-Known Member
    Canada
    2020 DCLB Sport (Stolen and recovered)
    That chart is outdated and not applicable to today’s semi-synthetic fluid and how it’s used in that transmission. Plus it was for extended time at those temps not like 10 minutes or so. The trans overheating alarm goes off at 250. So either people don’t trust Toyota engineers or they think there’s a master plan to sell a bunch of transmissions down the road.
  15. Apr 4, 2024 at 5:38 PM
    #55
    Tacoma2Tough
    Tacoma2Tough Well-Known Member
    Jaden
    Wyoming
    21 Cement Tacoma TRD OR
    Toyota TRD Lift Kit
    I’ve had a problem with my AT fluid getting too hot when doing simple trail driving. The truck read transmission fluid too hot or something and the truck started to not work correctly.
    Asked my local Toyota dealership and they said not to worry about it because how abnormally high the temperatures were in my city. It’s usually not this hot out but still kinda sketchy when you’re an hour away from cell service and driving a brand new truck, better yet brand new Toyota tacoma.
  16. Apr 4, 2024 at 5:54 PM
    #56
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    This is related to torque converter management in low gears,especially the lockup solenoid. To avoid, need to understand how the system works and avoid unnecessary heat.
    Tacoma2Tough[QUOTED] likes this.
  17. Apr 4, 2024 at 5:57 PM
    #57
    Tacoma2Tough
    Jaden
    Wyoming
    Toyota TRD Lift Kit
    I see, this was also when the truck was fairly brand new and it’s never done it since ‍♂️
  18. Apr 5, 2024 at 7:42 AM
    #58
    babylon5
    David
    Even if the fluid can withstand the temp you are neglecting the affect of increase temp on the mechanical components. You will notice that once you get into temps above 250F it mentions seals hardening and clutches burning out. I am not a mechanical engineer (my son is and many in this forum are also) but i have read many text books and articles regarding material sciences and there is a direct relationship between wear and temperature.
    And if the sensor that is giving the 250F warning is the one in the pan the temp in the converter is much higher. And recall that the Toyota WS fluid is a lower viscosity type which was designed to eek out a minuscule MPG increase. Now bring that up to 250F or higher and guess how thin it is then. And the 250F is saying its at least 250F. It doesn't say how much higher it is than that.
    And the Toyota engineers (or not) also came up with the brilliant idea of a sealed for life transmission to satisfy EPA requirements to reduce consumption and disposal of oils and lubricants. You wont find the majority of members here that agree with that one and neither do engineers..
    https://www.motortrend.com/how-to/129-1002-automatic-transmission-and-power-steering-filters/
    But as many have mentioned and I agree, its your truck and you can treat it however you wish. With the add on cooler I have my transmission pan temp will NEVER go over 180F and that is what i will stick with..
    On a side note during a co-op job at GM at the St Catherine's engine plant in Ontario I was working next to the Engineering group. It was way back when they were producing 2.8 Liter V6's for front wheel drives vehicles like the Citation. They had one on the engine stand. I commented to one of the engineers that it looks really nice with all the covers and components being hidden away but it looks like it would be hard to service. His comment was that they didnt design it to be serviceable , they designed it to look good. So you should that into account when you consider how and why things are designed.
    bgavin and BoomerGVNG like this.
  19. Apr 5, 2024 at 8:33 AM
    #59
    Vlady
    Issy, WA
    The tranny temp warning is linked to AT oil temperature No. 2 sensor. It is located in the valve body and usually registers high temps when the torque converter goes into fluid coupling state.
    Pan is No.1
    It is not a pan temperature sensor.
  20. Apr 5, 2024 at 10:07 AM
    #60
    Da Voke
    Canada
    I never said I operate my truck with the transmission temperature warning on. I don’t have the auxiliary cooler on my truck and the hottest the transmission gets is around 225ish going up long hills while towing and cools rapidly at the apex (Scanguage 3 trans temp 2) and I’m ok with that. I don’t need an auxiliary cooler. I also don’t let my transmission suffer trying to find the right gear. S mode all the time when towing. I don’t think think they removed the auxiliary coolers to “look good” and frankly Toyota engineers probably have a completely different set of goals than GM engineers do, if the last 50 years of automotive history are any indication.
