ATF Cooling Line Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LiveNM, Jun 5, 2016.
  1. Jun 5, 2016 at 2:45 PM
    LiveNM
    LiveNM [OP] New Member
    2009 Tacoma V6 4WD
    Hi Everyone - First post here.
    Mice love the cooling lines for the automatic transmission fluid on my 2009 V6 4W. I've replaced them once before, but this time, I was an idiot and removed both the hoses on the radiator side. As a result, I'm guessing which hose goes to which line.
    I'm running them "inside to inside" right now, meaning the inside line coming off the engine side goes to the inside line on the radiator side (right in pic below). Outside goes to outside (left in pic below). In other words, they don't cross each other as they make the jump from the hard lines at the side of the engine to the hard lines at the radiator (front bumper) side. Do I have this right? Also, I taped them in a probably futile attempt to keep from having to do this a third time. Thanks!
    Rambo MARINE Recon likes this.
  2. Jun 5, 2016 at 3:18 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    remove tape
    sprinkle hot chile powder onto new strips of tape
    rewrap lines. end of mice eating them
  3. Jun 5, 2016 at 3:26 PM
    LiveNM
    2009 Tacoma V6 4WD
    Good idea, 127. Any thoughts on the routing of ATF cooling lines?
  4. Jun 5, 2016 at 3:55 PM
    whipper
    whipper Well-Known Member
    2007 PreRunner
  5. Jun 5, 2016 at 4:02 PM
    LiveNM
    2009 Tacoma V6 4WD
    Steve - Spot on! That's a great find. Thanks a ton!
  6. Jun 5, 2016 at 4:04 PM
    whipper
    2007 PreRunner
    You're welcome.
    Good luck.
