ATF drain time in the Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Motorshooter, Nov 1, 2010.
  1. Nov 1, 2010 at 8:24 AM
    Motorshooter
    Motorshooter [OP] Motorshooter
    VA-Northern VA
    16 double cab, short bed, 4X4 SR5, Towing pkg. Inferno Orange -What a great color!
    Weather Tech stone guards, Undercover SE bed cover, Rhino running boards, modded N-Fab light bar with two Hella 7" Driving lights, 2 Ridged cube fogs, fresh coat of wax. I really miss my Indigo Ink Pearl 07' DC -RIP-she saved my life. Thank you blue beast!
    The old odometer shows 58,000 on my 2007 prerunner, getting close to the time to service the ATF.
    I plan on doing this service myself…I really don’t trust any of the stealerships in my area. I have Mobile 1 synthetic ATF in my Corvette and really like it. Has anyone here used Mobile 1 synthetic ATF in their Taco’s automatic Trans?
  2. Nov 1, 2010 at 9:47 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Use only Toyota ATF-WS. It's a synthetic by most accounts and well worth it if you want it to shift correctly.
  3. Nov 1, 2010 at 9:47 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
    you dont need to change it until 100k. Save your money and wait a little while
  4. Nov 1, 2010 at 9:59 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Yep, I would say it's time for an oil change....ever since Toyota changed the interval to 60k from 100k.
    DON'T use the Mobile 1 or anything else besides the recommended ATF from Toyota. This oil in approved for and is safe for our transmissions, other brands of oil could do damage. You can pick it up at your local dealership.
    However Mobil 1 is great for engine oil and diff oil's, transfer case.
    Hope that helps.......
  5. Nov 1, 2010 at 10:28 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    No harm in changing the oil. I think it's horrible that Toyota doesn't recommend this until 100k miles and even worse that some dealerships are saying don't change it at all. Oil wears out over time. A little oil is much cheaper than a damaged transmission.
