ATF filler & rear differential volume?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sign Guy, Mar 25, 2011.
  1. Mar 25, 2011 at 4:09 PM
    Sign Guy
    Sign Guy [OP] Well-Known Member
    Brian
    Everett, WA
    DrugRunner V6, 2wd
    Nice Rims, Big Tires, Carryboy Shell, Added Rosta Cruise Control & Ultraguage, 5100 Bilsteins All around
    I haven't had an Automatic in years, I just got my taco V6 w/auto and thought I'd change the fluid. I can't find a big fill neck for the tranny. I hate to use the dipstick tube, that'll take forever. Is there any other way???
    I also just drained the rear differential and used almost 3 qts of Mobil 1 synthetic and it still isn't full, how much does that monster hold?
    Thanks
    Brian in Everett
    feelin like a total gel-head:confused:
  2. Mar 25, 2011 at 4:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    3 quarts should have been plenty
  3. Mar 25, 2011 at 4:14 PM
    98tacoma27
    Ben
    Not Beech Creek
    He's posted in the first gen section.
  4. Mar 25, 2011 at 4:15 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    snap
    i never look never
  5. Mar 25, 2011 at 4:18 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yeah, but he could have posted in the wrong section. So there is still hope young Padawan.
  6. Mar 25, 2011 at 4:20 PM
    crf69
    Ohio
    ummm yeah
    do first gens have a dipstick?
  7. Mar 25, 2011 at 4:21 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes......................I think.................
  8. Mar 25, 2011 at 4:21 PM
    Sign Guy
    Brian
    Everett, WA
    DrugRunner V6, 2wd
    Thanks for that info Ben, I'll be printing that out to put in my file.
    How bout the auto trans fill tube? Is the dipstick the only way to fill that unit?:eek:
  9. Mar 25, 2011 at 4:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....dipstick is only way to fill the tranny in the first gens. also....my rear diff took a lil over 3 quarts when i filled it.
  10. Mar 25, 2011 at 4:23 PM
    98tacoma27
    Ben
    Not Beech Creek
    Oh there's more.................
  11. Mar 25, 2011 at 4:23 PM
    Sign Guy
    Brian
    Everett, WA
    DrugRunner V6, 2wd
    Thanks Will. I'm outta here and back to the driveway to get dirty:D.
  12. Mar 25, 2011 at 7:55 PM
    Sign Guy
    Brian
    Everett, WA
    DrugRunner V6, 2wd
    Got the tranny done - it took almost a full gallon and the rear differential took a shade over 3 qts. While crawlin around under there I broke out the grease gun on the u-joints. I'm sure the truck is a happy camper now! Thanks for all your help!
  13. Mar 25, 2011 at 7:55 PM
    98tacoma27
    Ben
    Not Beech Creek
  14. Mar 25, 2011 at 8:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good deal.
  15. Mar 25, 2011 at 11:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Your truck is thanking you. Do you hear it....its a quite but persistent voice...listen closely. :D
