ATF flow direction to cooler
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Masmohs, Dec 10, 2023.
  1. Dec 10, 2023 at 5:32 PM
    Masmohs
    Masmohs [OP] Member
    08, access cab, 4.0, Auto
    I have a 2008 Tacoa, 4.0 automatic transmission WITHOUT tow package.
    Can please someone confirm the following:
    Lower line front transmission takes ATF to upper part of cooler
    And
    Bottom line from cooler brings the ATF back to the transmission using the upper transmission line.
    I am replacing my transmission cooler lines, everything is rusted shut , working in a small unheated garage, in Minnesota, with current tempeture of 20f, and I am getting over surgery of my broken wrist with plate in it and possibe nerve damage!!!
    I will not miss 2023...
    Thanks
  2. Dec 10, 2023 at 7:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Masmohs[OP] likes this.
  3. Dec 10, 2023 at 9:16 PM
    Masmohs
    Masmohs [OP] Member
    TnShooter,
    Thank you. I think I got it right. The only thing that thread did not address is the cooler. I think the hose at the bottom of the cooler returns the ATF back to the transmission. Can you confirm that please?
  4. Dec 10, 2023 at 10:04 PM
    TnShooter
    Deogee
    STOCK
    According to the parts diagram in the link below, The top is the inlet.
    It is on page 21
    https://www.tacomaworld.com/threads...numbers-with-list-prices.347123/#post-9265148
    Masmohs[QUOTED][OP] likes this.
