ATF fluid choice/HELP ASAP PLEASE!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Idrivetoys, Nov 20, 2010.
  1. Nov 20, 2010 at 3:10 PM
    Idrivetoys
    Idrivetoys [OP] Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    Okay so recently i flushed my Tacoma 2001 DC auto (drain and fill) with castrol for imports from Advance Auto and after serious hard shifting i did some researching and have found several threads where people say ONLY use Toyota T-IV or amsoil/mobil etc.
    ANYONE on here ever change with castrol for imports and have a problem?
    I need some input before i buy this transmission next week and swap it out, i had two shops check out my trans and both people said its higher pressure in the transmission than it should be. Does this sound right? Im sure a wrong viscosity liquid can cause pressure issues in a pressurized system so should i do a complete flush?? Thanks for your fast response!
    ryan
  2. Nov 20, 2010 at 3:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Id flush it and use what the manual calls for.
  3. Nov 20, 2010 at 3:31 PM
    Idrivetoys
    Yuma AZ
    Okay so im east coast and its too late to talk to the local dealership so i called a CA dealership and explained the problem and was told that they solve several different transmission issues from transmission slipping, to hard shifting to wobbles from incorrect fluid. He said they typically charge $144 for a full flush. So monday im going to call my local dealership and try and get it done asap. my theory is even though its a gamble and may not fix it im about to drop $1,000 on a 40k mile trans and fluid anyway so maybe it will work out! wish me luck
  4. Nov 20, 2010 at 7:02 PM
    Idrivetoys
    Yuma AZ
    Anyone else wanna chime in?
  5. Nov 20, 2010 at 8:44 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I flushed with 53k and had Toyota do it, every time I try to save a buck it bites me in the ass, so I bit the bullet and payed Toyota, I never was a fan of switching fluids , same goes for coolant!
  6. Nov 20, 2010 at 10:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I had the dealership do a flush with no ill effects, except to the wallet. Truck had 86K on it at the time.
  7. Nov 20, 2010 at 10:46 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I did a Drain and fill on my 02 auto. with M1 synthetic ATF. And I helped with my hard shifts.
  8. Nov 21, 2010 at 2:03 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    I bet your hard shifting is gone after you change the fluid. I always use oem trans fluid in toyotas. It is cheeper from the dealer than synthetic at discount auto parts.
  9. Nov 21, 2010 at 5:59 AM
    Idrivetoys
    Yuma AZ
    I hope thats the case, I dont like spending over $1,000 on a salvage yard trans and fluid if $150 will do, what did the rest of you pay for a dealership flush?
  10. Nov 22, 2010 at 8:32 AM
    Idrivetoys
    Yuma AZ
    just picked it up, drove about 5miles so far feels much better, ill know more when the engine is cold but it definitely helped a lot so far.
    $175 later, but thats better than a new trans
  11. Nov 22, 2010 at 9:16 AM
    gobias
    gobias as in Gobias some coffee
    02 Dbl TRD
    Had the dealership flush my tranny a while back & they used Valvoline Max Life.
  12. Nov 24, 2010 at 4:46 AM
    Idrivetoys
    Yuma AZ
    Runs amazing, like a new truck now. Not sure if anyone else has had or will have this issue but castrol for imports was not good for my truck. i will probably do the dealership route or the home made flush from now on but with M1, amsoil or Toyota T-iv
    its so nice to have my truck back
  13. Nov 24, 2010 at 8:44 PM
    ChavisT93
    ChavisT93 Well-Known Member
    Lexington, SC
    07 reg cab base
    I always use Valvoline Max Life. It's T-IV compatible.
  14. Nov 25, 2010 at 8:17 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Chemical compatibility is a measure of how stable a substance is when mixed with another substance.
    Why take a chance when a transmission overhaul can cost upwards $2500.00 just to save a few pennys! My $0.02
  15. Nov 25, 2010 at 9:38 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Make sure to recheck the fluid levels, as the FSM has it wrong on the amount of fluid needed, leaving it quite low if the tech just followed the book instead of bringing the trans fluid up to temp and checking/topping off.
  16. Nov 25, 2010 at 10:06 AM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    I am pretty sure (please correct me if I am wrong) your truck calls for dex 2 or 3. Just look on the tranny fill cap. If it does do yourself a favor and don't put in T-iv. Just go to the dealership and they sell valvoline dex merc that will work just fine in your truck. I paid 3.99qt at my local toyota dealership. Truck took a hair over 4 quarts, do the drain and fill a few times 500 mile intervals till the fluid comes out cherry clean.
    Actually they told me that if i brought my truck in for a tranny service they would be puttin in valvoline dex merc!
    good luck
  17. Nov 25, 2010 at 11:04 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    does anyone have a write up for the drail/fill on the auto tranny?
    does the same proceedure include the filter replacement?
  18. Nov 25, 2010 at 7:13 PM
    ChavisT93
    Lexington, SC
    07 reg cab base
    Just do a little research. Maxlife is running perfectly fine in MANY T-IV transmissions. Valvoline would not recommended it if it were not ok to use.
    As far as saving pennies. Last time I checked the price of T-IV at the my local dealership, the Maxlife is more expensive by nearly a dollar a quart. I just prefer it.
    From Valvoline specs
    Recommended for use where the following fluids are specified:Ford MERCON®, MERCON® V, MERCON® SP and LV
    GM DEXRON, DEXRON II, III and VI
    Toyota and Lexus Type T, T-III, T-IV and WS
    Allison TES 295 and 389
    Nissan Matic-D, Matic-J and Matic-K
    Honda and Acura ATF Z-1 (except CVT)
    Mercedes NAG-1
    Mitsubishi Diamond SP-II and SP-III
    Kia SP-II and SP-III
  19. Nov 27, 2010 at 5:11 AM
    Nowhereman04
    Nowhereman04 Well-Known Member
    Tar Hill Blue NC
    Silver 04 DC 4x4 SR5 TRD OFF ROAD
    Bilstein 5100's front, Bilstein 5125's rear
    I've heard horror stories about what has happend after people changed tranny fluid brands. I think there is a reason the factory uses a certain type, and you should not deviate from what is recommended. I've changed mine twice in 70,000 miles and put the stuff Toyota recommends back in it. Mine shifts great. Rumor is that the autotranny that is used for the 1st Gen trucks is a really great and reliable tranny. And i've seen trucks with well over 200K that is still shifiting and working great.
  20. Dec 4, 2010 at 12:02 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I recently purchased some MotoMaster ATF to top up my PS fluid...It says for use in vehicles previously service by Dexron III on the front and says suitable for use in vehicles requiring Dexron II on the back...Should I be using this type/brand? Thx Matt
